Old 22nd August 2015, 15:08   #32641  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
Originally Posted by Fadeout View Post
Windows Media Player gives a similar result to MadVR, it's only Yadif that makes things less smooth. And this is a problem because I'm trying to encode the video to progressive, but the only options for the decoding only produce results that look like Yadif, and so everything is less smooth.
Yadif is fast CPU deinterlacer, madVR and WMP use DXVA deinterlacing (GPU-based).
If you want proper offline deinterlacing - use QTGMC.
Old 22nd August 2015, 15:54   #32642  |  Link
Fadeout
I need to convert a video to 1080i to 1080p, but the quality is TERRIBLE.
Is there a way to get a similar input quality that I see in MadVR/WMP and use it in StaxRip or MediaCoder? Can't they use DXVA for decoding as well?
Fadeout is offline   Reply With Quote
Old 22nd August 2015, 18:20   #32643  |  Link
e-t172
Are you sure you're using Yadif in "double framerate" mode? If not, that would explain why you find Yadif less smooth.
Old 22nd August 2015, 18:32   #32644  |  Link
Fadeout
Yeah, that seems the case.
When enabling Yadif within LAV Video options at 50/60 video mode I get the same smoothness I have normally, whereas in "film" mode I get the standard Yadif I usually see.
The problem is I cannot encode that properly.
Old 23rd August 2015, 01:08   #32645  |  Link
Dogway
Has nnedi (doubling) some limitations? I can use it with the internal iGPU, but it fails to load with the nvidia card. The CPU is a N3540 and the card is a GT 820M.
Old 23rd August 2015, 01:59   #32646  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
It requires feature (D3D9 OpenCL interop) that nvidia recently removed from drivers (at least for Windows 10).
http://forum.doom9.org/showpost.php?...ostcount=32210
Old 23rd August 2015, 02:05   #32647  |  Link
kuchikirukia
Is there a way to get MPC-HC's status window to show the video framerate when using madVR? It worked under XP, but ever since I upgraded to Windows 8.1 and then 10 it syncs to my monitor refresh rate. Using System Default renderer shows the correct frame rate.
I do a lot of encoding and having the frame rate is a big help when working with interlaced sources.
kuchikirukia is offline   Reply With Quote
Old 23rd August 2015, 02:19   #32648  |  Link
Dogway
Thanks for the help! Yes, nvidia at it again... : /
By chance do you know since what version they removed the feature, I'm going to do some searches in any case.
edit: These are the oldest drivers for Win10: 352.63 Beta and 352.84.
edit2: at least last version 355.60 includes what madshi claimed to be the proper way, "cl_khr_dx9_media_sharing", although I guess he has to work on it for nnedi come back.
Old 23rd August 2015, 02:40   #32649  |  Link
zvans18
zvans18's Avatar
i seem to have a problem where when nnedi3 quadrupling and SR is enabled, the chroma changes to jinc, but when SR is disabled it's back to nnedi3 like it's supposed to be
madvr 88.21 + mpc-hc 1.7.9 x64
win 8.1 with 355.60
Windows 10 // i7-8700k + GTX 1080 SLI // MPC-BE x64 + LAV + XySubFilter
zvans18 is offline   Reply With Quote
Old 23rd August 2015, 04:07   #32650  |  Link
Dogway
Update, couldn't get the above versions (352.63 Beta and 352.84 -notebook versions here-) to recognize my card (820M) on Windows10, but 353.30 did and there nnedi works, but as noted before only if I choose DXVA on LAV Video, well I can't see why not. Yet the 820M is very underpowered, it struggles to keep up with nnedi16 (only luma), but that's another story.
BTW, is it possible to include duration to profile rules?
Old 23rd August 2015, 06:37   #32651  |  Link
Asmodian
Originally Posted by Akeno View Post
This has been spanning on for the past couple of pages but can anyone give a short run down on what problems madVR has with windows 10?
So far, it sounds like nnedi3 still doesn't work on nvidia cards due to missing opencl implementation and something about d3d9 interop although I don't know what effects that has on madVR.
Nvidia removed the opencl to dxd9 interop function in the newer drivers for Windows 10 so madVR's implementation of NNEDI3 no longer works.
The two issues are actually the same issue, only NNEDI3 is affected.
madVR options explained
Old 23rd August 2015, 09:17   #32652  |  Link
Sunset1982
is there a suggestion for a good noise reduction in mpc-hc?
Since i upscale my files to my 4k screen the noise increased a lot and madvr doesnt have noise reduction options. So what to use for nr?
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 23rd August 2015, 09:55   #32653  |  Link
Sunset1982
Switched back to Win 7 and catalyst 14.12. But noticed some problems with madvr 0.88.21.
watched a movie yesterday and while playing it in fullscreen exclusive mode (D3D11, 10 Bit) the screen suddenly went black. Sound and movie seemed to play on, but no picture. Had to exit fse to windowed and switched back to fse, that fixed it. Was the second time i had this strange bug.
Today I tried to switche back to D3D9, 8 Bit mode, but can't get a picture in fse. Don't know why. When I got some time i will try to switch back to 0.88.16 or 0.87.21 and see if it still exists.
btw: should windowed overlay mode work on AMD cards? when I select it, it shows: "windowed overlay is not supported"
Old 23rd August 2015, 11:17   #32654  |  Link
Qaq
AV heretic
Some pixel shader. Look here: https://forum.doom9.org/showthread.php?t=157634
Qaq is offline   Reply With Quote
Old 23rd August 2015, 14:40   #32655  |  Link
Manni
Sorry to report that I still get unreported dropped frames with 0.88.16.
So I had to revert to 0.87.21. Dropped frames seem to be gone for good, I'll report if it was not the case.
Madshi, are you able to reproduce these issues with 0.88.x that some of us AMD users are experiencing?
Do you know what could cause these unreported dropped frames?
Please let us know if you need any more information to fix these. MadVR has always given me perfect perfect playback until 0.88.x
This is using 14.12 catalyst and D3D9 without FSE.
I mostly play blurays, so the only enhancements are chroma upscaling (NNEDI3 32) and debanding (high/high). I'm well under 25ms per frame, so far from any limit to cause frame drops at 23.976hz.
Win11 Pro x64 b23H2
madVR/LAV/jRiver/MyMovies/CMC
Old 23rd August 2015, 15:45   #32656  |  Link
alx000
Probably this was already answered here multiple times, but I always wanted to know about it.
How madVR algorithms compare to the "filters" and sharpening options built-in the new TVs?
Do you use just madVR sharpening and disable all the TV features? Or do you use both (madVR + TV sharpening) ?
alx000 is offline   Reply With Quote
Old 23rd August 2015, 16:00   #32657  |  Link
Xaurus
Oh my god I am so happy right now, after trying different drivers and trying everything except reinstall Windows 10 I finally got rid of the mysterious dropped frames.
All I had to do was to disable fullscreen exclusive mode. If someone saw my previous post, I tried EVR instead of madvr but this didn't get rid of the mysterious dropped frames so I will just assume it uses something similar to fullscreen exclusive mode.
In any case, I can finally watch some movies and TV shows again.
SETUP: Win 10/MPC-HC/LAV/MadVR
HARDWARE: Fractal Design Node 804 | Xeon E3-1260L v5 | Supermicro X11SSZ-TLN4F | Samsung 2x8GB DDR4 ECC | Samsung 850 EVO 1TB | MSI GTX 1650 Super | EVGA G2 750
Xaurus is offline   Reply With Quote
Old 23rd August 2015, 17:59   #32658  |  Link
Asmodian
No, windowed overlay is only supported by Nvidia and Intel.
Old 23rd August 2015, 18:35   #32659  |  Link
Thunderbolt8
Originally Posted by Qaq View Post
Some pixel shader
a general questions, do mpc-hcs pixel shader work in combination with madvr?
Old 23rd August 2015, 20:32   #32660  |  Link
vivan
/人 ◕ ‿‿ ◕ 人\
yeap (and I believe that it's the only way to run custom shaders in madVR).
