Old 3rd May 2016, 15:03   #41  |  Link
dapperdan
There was a video about VP10, I think it was linked from a thread here, which probably mostly applies.
https://www.youtube.com/watch?v=gkz1ZvejmEc
I've not watched it for a while, but I'm not sure there was anything particularly novel in the Daala sense of trying new things that won't have been patented, just the usual incremental improvements.
dapperdan is offline   Reply With Quote
Old 5th July 2016, 20:36   #42  |  Link
Jamaika
First tests codec, which will be released in March 2017.
http://www.cnx-software.com/2016/07/...te-with-h-265/
I am surprised the wording.
The command will encode all y4m files in the directory at 200 kbps up to 500 kbps at a 50 kbps increment. Encoding only uses one core, my machine is powered by AMD FX8350 processor, and you can see encoding is currently very slow well under 0.5 fps for a CIF video (352 x 288 resolution), but that should be expected because VP9 encoding is already slow (its successor is expected to require even more processing power), and first software implementations are usually not optimized for speed, they are just meant to show the encoding works.
Old 6th July 2016, 00:44   #43  |  Link
benwaggoner
Reference encoders are always super-slow*. The official reference implementations for H.264 and HEVC are about 100th the speed of x264 and x265 and lack lots of critical features. All the SIMD and multithreading work goes into production implementations.
* The one exception being VC-1, since that was actually done from the WMV9 decoder porting kit, and thus accidentally was full of real-world features and optimizations .
Ben Waggoner
My Compression Book
Old 6th July 2016, 03:15   #44  |  Link
Jamaika
I didn't know that codec is reference. Supposedly it is based on the codec VP10, even Ligh once compiled, but may test off some function. In a word, there is nothing to build a codec AV1.
Old 6th July 2016, 07:23   #45  |  Link
easyfab
It's very slow because he use run_tests that use best settings ( like placebo for x264/x265 ) and 1 thread.
He should test with more realistic setting --cpu-used=1 or 2 and add threads -t 4, with that it should be really faster.
Old 6th July 2016, 18:57   #46  |  Link
easyfab
I made a quick test :
source : Kimono1_1920x1080_24
x264 --preset veryslow --crf 23 : file output 6.38 Mo ( bitrate 5351 kbps ) ssim 0.955018 psnr 41.056804
x265 --preset slow 2 pass : 6.28 Mo ssim 0.960803 psnr 42.029059
x265 --preset slow 2 pass : 6.42 Mo ssim 0.961065 psnr 42.070003
vp9 -cpu-used 1 2 pass : 6.29 mo ssim 0.960090 psnr 41.922800
and for av1 -cpu-used 1 2 pass : 6.43 ssim 0.961722 psnr 42.229238
so only a little better than vp9 and x265 for the moment.
Old 6th July 2016, 21:20   #47  |  Link
benwaggoner
And how did they look? With such close values, PSNR and SSIM aren't going to be that informative.
Ben Waggoner
My Compression Book
Old 7th July 2016, 04:51   #48  |  Link
Jamaika
Maybe an interesting comparison, but ...
I don't know if there are any differences between the VP10 and AV1.
Nor do I know what the results seeks by the manufacturer. I don't know ranges of SSIM and PSNR. Could use a graph.
I would have also posting links encoders, because I understand that you tested the latest versions. (Next2)
https://aomedia-review.googlesource..../status:merged
https://chromium-review.googlesource.com/#/q/vp10
PS What puzzles me? New patches codec vp10 aren't included in the codec AV1.
Old 7th July 2016, 09:40   #49  |  Link
bstrobl
As far as I know, only the best patches that have been properly tested get merged into AV1.
AreWeCompressedYet shows minor improvements of AV1 when compared to HEVC/VP9 in areas of PSNR/PSNR-HVS/SSIM (FastSSIM seems to be more problematic). Not sure how they are going to achieve a doubling of efficiency when compared to HEVC by 2017 however.
bstrobl is offline   Reply With Quote
Old 7th July 2016, 13:42   #50  |  Link
mzso
VP10 is not AV1. AV1 is built only in part on VP10, at least it's supposed to be. How much of it is from Daala or Thor or whatever I can't say.
Old 7th July 2016, 14:08   #51  |  Link
dapperdan
I think it's fair to say that AV1 is VP10 at the moment. As tech or patents or coding contributions come from other parties now then it may grow to be something different, but as a starting point it was and mostly still is the libvpx VP10 codebase. At what percentage of code or ideas it stops being VP10 is of course debatable, and they certainly want to be a collaborative project going forward, but yeah, I don't think it's a misleading shorthand to say AV1 is VP10.
Old 7th July 2016, 14:59   #52  |  Link
Jamaika
There was such a suggestion. Codec AOM replaces VP10, Daala, Thor, HEVC. Anyway what for they did to the alliance. VP10 disappears. I see that these are two paths of development, ie said Clare.
Originally Posted by BadFrame View Post
The AOM (Alliance of Open Media) codec is based upon VP10 (which is still in heavy development as a separate branch), but they will use any useful technology which their members have access to, for example if you look at the AOM branch, there are Daala features being added:
https://chromium-review.googlesource...oject:webm/aom
I don't know if VP10 will actually materialise as a separate stable codec release or if it will be decprecated as it is the base of the AOM codec (depends on how long it will take to develop I guess).
It can and is based on the codec vp10, just don't know it or not version a few months ago.
Old 8th July 2016, 08:53   #53  |  Link
Quikee
Some things from daala and thor is in AV1 AFAICS - mainly the deringing filter (daala) and CLP filters (thor) are and multi-symbol entropy coder from daala (which might be replaced by rANS as it is faster and has similar efficiency) PVQ is still a WIP to integrate into AV1 - which might be quite interesting..
Quikee is offline   Reply With Quote
Old 8th July 2016, 09:07   #54  |  Link
Quikee
It may possibly be that they won't double the efficiency but just be marginally worse or better. It is much more important that they release a codec "soon" so they establish a base and offer a viable alternative to HEVC.
Old 8th July 2016, 12:16   #55  |  Link
mzso
So, no chance for lapped transformation from daala?
Old 8th July 2016, 12:33   #56  |  Link
mandarinka
mandarinka's Avatar
I'm not sure Daala stuff is integrated in the sense that it is definitely going to land in the final format. They adapted it or are adapting it into the same codebase so that it can be evaluated at all. The tools will have to prove their worth and/or fight their way into it in the committees/politics/visions clashes Lots of stuff currently in the codebase will be dropped from the final format, likely.
If On2/Google has main say in development, they might hamper adoption of stuff from Mozilla/Xiph because NIH mentality. (Well, let's hope such pety things will be kept in check there, but people often tend to behave like that sadly.)
Old 8th July 2016, 14:10   #57  |  Link
mzso
But, how will they finalize the format by 2017 like this?
Old 10th July 2016, 03:48   #58  |  Link
Quikee
I never said any of it will be final in AV1 format - just that it currently is or isn't part of the AV1 codebase yet. Of course things that won't show gains (or show gains but increase complex too much) will probably be dropped.
If they want inclusive development this won't happen. If there are two tools that have similar gain they will together decide which one to keep and which to drop (that's why they have regular meetings). IPR and what hardware vendors say would be a big factor in such a decision.
Old 10th July 2016, 03:56   #59  |  Link
Quikee
No, lapped transform is too invasive - they would need to change almost everything, which would not make sense to select VP10 as the base.
Old 12th July 2016, 16:17   #60  |  Link
wiak
if anyone is interested i have a compiled win64 version here
https://awesome.nwgat.ninja/aomedia/...f841b-win64.7z
