23rd April 2008, 19:41 | #4401 | Link | |
23rd April 2008, 19:48 | #4403 | Link |
If anyone can provide a little sample which produces that "[libav] Stream parameters not seen; skipping frame" complaint, that would be helpful. I'd then forward it to the libav TrueHD decoder programmer. (If it proves to be a bad rip, this is not necessary, though.)
23rd April 2008, 20:42 | #4405 | Link |
too much lurking
It failed on rerip too. Works fine with nero though. How does one make a sample? Could someone point me to a simple guide?
Also is there a way I can demux only that track? The -demux switch demuxes everything and I don't need to do that again. Last edited by saint-francis; 23rd April 2008 at 20:46. |
23rd April 2008, 20:45 | #4406 | Link | |
23rd April 2008, 20:49 | #4407 | Link | ||
http://www.mh-nexus.de/ Just remove everything except the first 50MB. |
23rd April 2008, 21:57 | #4410 | Link | |
Madshi, if you don't have any Blu-ray Disc with TrueHD, i 'll send you a sample. Saint-francis, you just select the first 50 MB and copy-paste them to a new file. It's not necessary to upload the sample, i believe. I can do it, since i found one. Last edited by nautilus7; 23rd April 2008 at 22:27. |
23rd April 2008, 22:14 | #4411 | Link | ||
too much lurking
23rd April 2008, 22:15 | #4412 | Link | |
And as I stated it came from a vob file that was a DTS Audio DVD. - where the audio tracks are on the VIDEO_TS folder and I used VOBORATOR to extract them. http://alphabase.com/downloads/testDTS.wav is the smallest test file I had. Thanks for you help on this.
BSW |
23rd April 2008, 22:53 | #4413 | Link |
Are you sure the file is ok? eac3to detects it as wav, not dts wav and i can't play it correctly.
Furthermore, eac3to can deal with vob files directly, so vobrator isn't needed. Try eac3to with the vob files. |
23rd April 2008, 23:40 | #4414 | Link | |
I did try the VOB and it looks like its going to work - but I don't have the sonic decoder. I do have nero 7 on this PC, but I still get an error: Decoding with DirectShow (Nero Audio Decoder 2)... The DirectShow audio decoder didn't accept the input stream. Aborted at file position 147456. Can you provide me with a link to a usable decoder? I am using ac3dts in zplayer - can eac3to use this?
BSW |
23rd April 2008, 23:49 | #4415 | Link |
Do you have nero HD DVD / blu-ray plug-in bought and registered? If not, you can use the libav decoder that ships with eac3to (-libav option).
The command should be like: Code:
eac3to input.vob Code:
eac3to input.vob id_number: output.wavs -libav -resampleto44100 Last edited by nautilus7; 23rd April 2008 at 23:52. |
24th April 2008, 00:01 | #4416 | Link | |
Still getting the TrueHD error though after decrypting and demuxing RE 3 again. Do you happen to still have 2.40 somewhere so I can see if there error exists with that version? |
24th April 2008, 00:51 | #4417 | Link | |
However your decoder definitely has a bug in that it is not figuring out .wav files that are dts encoded. I have tired a few other files - ones that are already 44k and they have exactly the same problem - they are calling it a 2 ch file - which by the way it is written as a 2ch file to fake out cd players into streaming the 2 channels to a decoder which then decodes the 6 channels. So my guess is that you need more code to figure out that there is really 6 channels there. Hopefully this can get fixed as I have a lot more files already .wav files that I won't be able to split up. Thanks for you help!
BSW |
24th April 2008, 00:55 | #4418 | Link |
Well, whatever problem I had, it's fixed now. I demuxed the m2ts file through eac3to and then opened the TrueHD track without the AC3 track embedded and it's encoding to FLAC now.
Edit: I forgot that I updated to the latest ffdshow nightly build from XXL today. That may or may not have fixed the libav error. |
24th April 2008, 01:00 | #4419 | Link | |
eac3to it's not my program! It's madshi's! He should get all the credit (and the blame ). Though, what you mention about dts-wav support not being complete might be true. Perhaps madshi can have a look at the sample you uploaded in your previous post... Last edited by nautilus7; 24th April 2008 at 01:05. |
24th April 2008, 01:04 | #4420 | Link | |
This truehd decoding bug, i think, isn't libav related, since it works for hd dvd tracks, but an eac3to bug. Furthermore, it was introduced in the recent versions of eac3to, where no libav update was done. |
eac3to |
