13th June 2010, 12:41 | #8001 | Link | |
1. Which profile are you using? 2. Which program shows 20-30% usage? 3. Check your ripbot.ini: Usex264x64=1 |
13th June 2010, 15:17 | #8003 | Link |
Hi Atak, thanks for this great gui.
but after 1.16.0, the new Win7 progress bar function makes it unable to minimize to tray icon in Win7. Is there any way, or an option, to re-enable this? I think tray icon is a good way to prevent closing an app accidentally also keep the taskbar clean. (especially it takes a lot time to encode HD x264 video) |
13th June 2010, 15:23 | #8004 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 13th June 2010 at 15:25. |
13th June 2010, 15:53 | #8005 | Link | |
Cheers Trayman |
13th June 2010, 18:44 | #8006 | Link |
Hi Atak,
i know you can't hear that anymore but i've got the "Gathering Information ..." - Bug since 1.16.0 (even in 1.16.1). I've tried every step discribed in this thread. Took me a lot of time to find related replies. So i've deinstalled EVERYTHING what has to do with video-decoding, -encoding or playback. I've enabled and disabled DXVA-Support, tried some Haali - Versions .... Nothing worked for me! So is there a small workaround to avoid that hanging on "Gathering Information..." ? The Video-Stream is a VC-1 - Stream. Maybe i find a BD with another format to test. My System: - ffdshow_3466_clsid 32-bit - Haali from 20/05/2010 - Avisynth 2.5.8 - Java 6 Update 20 Edit: - Haali pops up and then disappears on "Gathering Information..." - RipBot264 1.15.1 still works with every Haali-Version - want to use 1.16.x cause of DivXPlus - support (owned it) Last edited by klopsknoedel; 13th June 2010 at 18:48. |
14th June 2010, 03:24 | #8009 | Link | |
To benjyv;
Your private message can't get sended to you about an setting that you've check for not receiving private message. I send you my reply here. Quote:
Regards,.. 8!
PC; 7.5 on 7.9 (Windows Experience Rating) on the lower rating. |
14th June 2010, 04:42 | #8010 | Link | |
Usex264x64=1 is in ini also, but i`m using Win 7 32bit. Program is working very nice, i transcoded some of my movies from 7 GB to 4.7 very nice but it`s so slow I check CPU usage in task Manager. All 4 core are on ~25-35% in first pass and 65% in second Here is a image, first peak is when pass 1 started and second is when pass 2 start. Last edited by Washka; 14th June 2010 at 05:00. |
14th June 2010, 06:17 | #8011 | Link |
I dont care so should you
My Installer's || |
14th June 2010, 09:50 | #8014 | Link |
The output filename problem.
There is a small issue with swedish characters åäö and ÅÄÖ they become something else when the file is muxed. I believe it has something to do with utf-8. Since the filename is correct in MuxFiles.cmd Then the output removes "." lets say i have an episode of 24 and i'd like to call it 24 - S01E01 - 12.00AM - 1.00AM it becomes 24 - S01E01 - 12 00AM - 1 00AM. Code:
"F:\Progs\RipBot264v1.15.1\tools\mkvtoolnix\mkvmerge.exe" -o "C:\Users\Trayman\Desktop\24S01E01 - 12 00AM - 1 00AM.mkv" --title "24S01E01 - 12 00AM - 1 00AM" --default-duration 0:25fps -d 0 -A -S "F:\temp\RipBot264temp\video.264" --language 0:und --sync 0:0 -a 0 -D -S "F:\temp\RipBot264temp\job18\job18 T80 2_0ch 192Kbps DELAY 0ms.ac3" --chapters "F:\temp\RipBot264temp\job18\chapters.txt" Cheers Trayman |
14th June 2010, 15:54 | #8015 | Link |
I usually use Ripbot to resize a blu-ray to fit on two-layer dvd and it always works well, but tried to resize for one-layer dvd yesterday and the final folder turned out to be oversized by 9Mbs and would not fit. Is it common or not?
14th June 2010, 16:09 | #8016 | Link | |
Custom Installer Maker
Since then I started to lock the size subtracting 10mb from the desired size just to be safe. You should do that and post again if it still outputs oversized encodes.
Applications: VistaTweaker, Launch, ServiceTweaker. Custom installers: iTunes without QuickTime, Skype and more. |
14th June 2010, 16:17 | #8017 | Link | |
14th June 2010, 16:53 | #8018 | Link | |
Hi Atak, I'm having a repeat of the problem described previously here http://forum.doom9.org/showthread.ph...87#post1361387
I don't know why it happens randomly but now I'm just adding one project to the queue and ripbot says NO AUDIO in the settings. I have this issue only when I try to compress videos from my canon ixus photo camera, which records avi MJPEG video and mono pcm audio. From any other video format ripbot loads the audio track correctly. Mediainfo reports this from the audio track Quote:
In the past I have run other software to play and compress this kind of videos, like virtualdub or autogk with no problems, so I guess it may be a little bug in your software or maybe in ffdshow or any other part parameters. Thank you very much |
14th June 2010, 18:21 | #8019 | Link |
hi,
could anybody help me with the "Gathering Information..." - Problem? I've tried 1.16.1, 1.16.0, 1.15.1 and 1.15.0. The problem occures on every version. I've deinstalled every sofware from my PC which contains codecs like, "Media Player Classic", "Media Coder", "XMedia Recode" and so on. Then i've performened a registry-clean to get rit of the codec-entries. Then i only installed ffdshow 32-bit, AviSynth 2.5.8, Haali Media Splitter 20052010 and Java 6 Update 20 32-bit! BUT THE PROBLEM STILL REMAINS. I don't know why. All worked for years, but now it hangs on "Gathering Informations...". I've Windows 7 Profressional x64 |
14th June 2010, 20:57 | #8020 | Link |
Hey Atak
quick question: Will it be possible in a future release to add a job while encoding? It takes a long time for me to add 24 episodes to the queue list, in this time one episode can be finished encoding. |
