22nd September 2007, 00:33 | #121 | Link | |
NOTE: itunes can import and play all sorts of videos (avi, mkv with softsubs, and probably wmv and ogm too) in this way, but they won't necessarily play on your ipod. |
25th September 2007, 11:20 | #123 | Link |
Do not close RipBot. Try to find following files:
job1_EncodeAudio.cmd job1_EncodeVideoPass1.cmd job1_EncodeVideoPass2.cmd job1_MuxFiles.cmd Then execute those files manually. (in the same order!)
25th September 2007, 19:29 | #124 | Link |
Rebel without Applause
where are those files at?
i cant find them anywhere, are they inside the x264 cmd? or are they actually their own programs inside your folders Last edited by Crucio; 25th September 2007 at 19:34. |
26th September 2007, 08:25 | #126 | Link |
wait no i take it back, it looks like clicking the different files are working well
why is it necessary though? Anyone else with this problem? and what kinds of fps are people getting? right now ive got 33fps second pass with a dual xeon 2.8 system built in 2003 (old) Edit: im an idiot, its messing up because my drive is named J: instead of C. I need to change something in the script or soemthing so it doesnt assume the programs are on c Last edited by Crucio; 26th September 2007 at 08:46. |
26th September 2007, 12:41 | #127 | Link |
Crucio download new version
27th September 2007, 21:34 | #128 | Link |
Nice app that I'd like to get to work! First, when I attempt to auto-crop, the app complains it can't find the autocrop.log. I look in the temp folder, and it does not exist.
Secondly, when I start the project, it looks as if the audio encodes properly, but the video doesn't encode at all, and no video is saved anywhere. I've tried to run both as a user and an admin. I'm trying to convert a short 3min. MKV file to an ipod-compatible MP4 file. I've also tried both constant quality and bitrate. Same thing. Only audio actively encodes, but nothing for the video. |
27th September 2007, 22:26 | #129 | Link |
I've found ugly bug in my latest version. I need about an hour to fix this.
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 27th September 2007 at 22:29. |
27th September 2007, 22:33 | #130 | Link |
@Atak , i just tried to encode an dvd to ps3 profile, the encoded file plays on my ps3 but the aspect ratio seems to be wrong, the orginal dvd is anamorphic 1,78:1 is there somewhere i can change so this comes out right ?
The video comes out all squezzed like the video is 4:3 aspect. Thx for a great tool. The1n |
28th September 2007, 00:56 | #132 | Link |
fixed version is now available
28th September 2007, 03:05 | #133 | Link |
I really don't understand why this program doesn't work at all for me. First, auto-crop doesn't generate the log, so the app complains it can't find the log. Secondly, no video is encoded at all - only the audio encodes. And, no final product shows up.
Is there a log of some sort I can send to troubleshoot? In the "job1" folder there are 4 *.cmd files, 3 *.avs files, 1 *.ini file, and info.txt file. In the Ripbot264temp folder, there are no files. According to the .cmd files, there should be a video file and an audio file to be muxed, correct? Last edited by kikker; 28th September 2007 at 04:33. |
28th September 2007, 12:20 | #134 | Link |
Let's see why video is not encoded.
Open job1_EncodeVideoPass1.cmd in notepad and add one line below command pause example "C:\Users\Dawidos\Documents\Delphi_Projects\RipBot264\tools\x264\[RipBot264]x264.exe" ... pause save this file and then execute job1_EncodeVideoPass1.cmd manually. If you get any error make a screenshot.
28th September 2007, 15:29 | #135 | Link |
OK, here is the result from pass 1. As you can see, there are 2 errors - not sure what the first means, but the second claims it cannot open the job1.avs when it's in the same folder.
Here is the File Info when the job1.avs is loaded into VirtualDubMod. But, in order to do that, I had to remove the "framecount= " from the directshowsource line in the avs file, otherwise the avs file wouldn't load in VDM. I thought that perhaps the original video was not in YV12, but apparently it is. Any other suggestions? EDIT: OK, I determined what the main problem is: Everything works fine if I edit the job1.avs file by removing the framecount in the directshowsource line just before I start the encode. Why would my version not like to see the framecount in there? I've tried several other video samples, and the autocrop fails to generate a log, and Ripbot continues to complain it can't find one. Does this only work with mpeg2 files input, or should autocrop work with any file? I also wonder if it has to do with the framecount issue above as well. Last edited by kikker; 28th September 2007 at 16:42. |
28th September 2007, 16:44 | #136 | Link | |
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 28th September 2007 at 17:08. |
28th September 2007, 17:02 | #137 | Link |
Well, the info for the trailer I've uploaded is in the jpg of my previous post. It's 24 fps.
I have both MKV and MP4 samples, and in each case, the framecount appears in the directshowsource line of the avs file. Ripbot simply doesn't work with that in there, and I must remove it before each encode. Here's a sample Matrix mkv trailer. http://www.mediafire.com/?3x35eow33nn I wonder if there is a version conflict in the chain of apps? I have avisynth 2.5.7. Last edited by kikker; 28th September 2007 at 17:06. |
28th September 2007, 17:17 | #138 | Link |
Your sample has been encoded in Xvid so I suggest to remove Xvid codec and use ffdshow instead!
I use FFDshow and everything is working...
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 28th September 2007 at 17:25. |
28th September 2007, 17:37 | #139 | Link |
OK, thanks for the reply.
The vid I uploaded wasn't encoded by me. Can you tell me why it would matter which encoder was used anyway? If there is a DS filter to decode the input, and the avs can be read and played by any player, then why would it matter? The only problem here is the framecount thing in the avs file. The problem is NOT that the number is inaccurate, because the number reported is exactly what is reported by VDM. The problem is simply that it's there, and when I remove the "framecount= ", it works fine. I guess the whole autocrop is related to that too? All the other vids I've tried result in the same problem (autocrop and framecount). I have used MeGUI, Staxrip, AutoMKV with no problems, so I'm hoping your svelte app can work for me too. |
28th September 2007, 17:42 | #140 | Link | |
I assume your problem is gone once you removed xvid?
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 28th September 2007 at 17:45. |
