Old 20th August 2018, 09:50   #881  |  Link
pistacho
Version 2.8.2 (08/20/2018)
  • Updated: x264 encoder to version 157.2932.
  • Updated: x265 encoder to version 2.8.59.
  • Updated: Mkvmerge to version 25.0.0.
DOWNLOAD => BDtoAVCHD_v2.8.2.msi
pistacho is offline   Reply With Quote
Old 12th October 2018, 10:33   #882  |  Link
pistacho
Version 2.8.3 (10/10/2018)
  • Updated: x264 encoder to version 157.2935.
  • Updated: x265 encoder to version 2.9.1.
  • Updated: Mkvmerge to version 27.0.0.
DOWNLOAD => BDtoAVCHD_v2.8.3.msi
Old 12th December 2018, 10:14   #883  |  Link
pistacho
Version 2.8.4 (12/12/2018)
  • Updated: x265 encoder to version 2.9.8.
  • Updated: Mkvmerge to version 29.0.0.
DOWNLOAD => BDtoAVCHD_v2.8.4.msi
Old 28th January 2019, 10:00   #884  |  Link
pistacho
Version 2.8.5 (01/28/2019)
  • New: In advanced encoding options added tune animation setting for x265 (new --tune animation in x265 v3.0).
  • Changed: x265 encodes now uses --aq-mode 3 (improves quality on dark scenes).
  • Updated: x265 encoder to version 3.0.1.
  • Updated: Mkvmerge to version 31.1.0.
DOWNLOAD => BDtoAVCHD_v2.8.5.msi
Old 19th March 2019, 16:16   #885  |  Link
pistacho
Version 2.8.6 (03/19/2019)
  • Updated: x264 encoder to version 157.2969.
  • Updated: 3D tools to Intel Media SDK 2018 R2.1 (API 1.27).
  • Updated: Mkvmerge to version 32.0.
DOWNLOAD => BDtoAVCHD_v2.8.6.msi
Old 22nd June 2019, 09:34   #886  |  Link
pistacho
Version 2.8.7 (06/22/2019)
  • Updated: x265 encoder to version 3.1.1.
  • Updated: Mkvmerge to version 34.0.
DOWNLOAD => BDtoAVCHD_v2.8.7.msi
Old 9th August 2019, 19:21   #887  |  Link
pistacho
Version 2.8.8 (08/09/2019)
  • Updated: x264 encoder to version 158.2984.
  • Updated: x265 encoder to version 3.1.2.
  • Updated: Mkvmerge to version 35.0.
DOWNLOAD => BDtoAVCHD_v2.8.8.msi
Old 2nd October 2019, 15:01   #888  |  Link
pistacho
Version 2.8.9 (10/02/2019)
  • Updated: x265 encoder to version 3.2.4.
  • Updated: Mkvmerge to version 37.0.
DOWNLOAD => BDtoAVCHD_v2.8.9.msi
Old 7th November 2019, 23:47   #889  |  Link
darkio
Bug: Don't remux subtitles in .srt form from mkv with h264 video to mkv with h265 video.
In temp folder subtitle is ok, but on final file is missing.
Original file is mkv with h264 video 1080p and ac3 audio.
For full conversion I've used mkv with h265, untouched audio, flagged force subtitle and cfr 20 with 720p resize.
Please, fix
darkio is offline   Reply With Quote
Old 10th November 2019, 12:38   #890  |  Link
pistacho
I found that bug: only occurs if video is resized to 720p and source subtitle is SRT (UTF-8). Not occurs never if source is a Blu-Ray or is MKV and not is resized.
For now, this is a fixed version:
BDtoAVCHD_test.rar
Extract RAR and copy to C:\Program Files (x86)\BDtoAVCHD\
Old 10th November 2019, 13:16   #891  |  Link
darkio
Ok thanks a lot for this fix !.
It works ok now
I really appreciate that the error has been solved.
I find it very easy for quick jobs. I have only a small request.
I Suggest to you some improvements:
aac encoding for mkv output
x265 color depth (8,10 and 12 Bit)
UHD bluray o mkv hevc 10 bit, hdr etc as input
hdr to sdr conversion
use nvenc (rigaya) encoder for uhd conversion
more resolution after crop:
1080p
1.66:1 (5:3) / 1920x1152
1.77:1 (16:9) / 1920x1080
1.85:1 / 1920x1038
2:1 / 1920x960
2.35:1 / 1920x817
2.37:1 (RED Wide) / 1920x810
2.39:1 (referred to as 2.40) / 1920x803
2.40:1 (Blu-Ray) / 1920x800
2.44 / 1920x787
1.33:1 (4:3) / 1920x1440
Old 14th November 2019, 19:44   #892  |  Link
pistacho
Version 2.9.0 (11/14/2019)
  • Fixed: when video is resized to 720p and source subtitles are in SRT, no subtitles are muxed at output.
  • Updated: x265 encoder to version 3.2.6.
  • Updated: Mkvmerge to version 40.0.
DOWNLOAD => BDtoAVCHD_v2.9.0.msi
Old 21st November 2019, 13:27   #893  |  Link
darkio
another bug with last update (I think)
do not endode until the end of file.
import mkv or bluray, then resize to 720p with mkv output and h265 codec then queue with or without subtitles.
start to encode but fail.
the queue colour is green but final mux is incomplete.
please, fix and add ac3 192 for stereo output. some disk, like anime, use uncompressed audui
Old 22nd November 2019, 20:49   #894  |  Link
pistacho
I cannot reproduce this bug. Probably is because you have in temp folder files with same name of previous incomplete tests/jobs. Delete manually all contents of temp folder and try again.
Also for 192 Kbps bitrate, stereo tracks can be encoded at 384 or 448 Kbps AC3 (even stereo Mp3 good quality has 320 Kbps).
Regarding the support for UHD BD and other new major functions, I don't have it planned for now.
Old 20th December 2019, 21:30   #895  |  Link
pistacho
Version 2.9.1 (12/20/2019)
  • Updated: x264 encoder to version 159.2990.
  • Updated: x265 encoder to version 3.2.1+2.
  • Updated: Mkvmerge to version 41.0.
DOWNLOAD => BDtoAVCHD_v2.9.1.msi
Old 24th January 2020, 10:36   #896  |  Link
pistacho
Version 2.9.2 (01/24/2020)
  • Updated: 2D/3D tools to Intel Media SDK 2019 R1 (API 1.28).
  • Updated: x265 encoder to version 3.2.1+5.
  • Updated: Mkvmerge to version 42.0.
DOWNLOAD => BDtoAVCHD_v2.9.2.msi
Old 3rd March 2020, 10:19   #897  |  Link
pistacho
Version 2.9.3 (03/03/2020)
  • Updated: x265 encoder to version 3.3+1.
  • Updated: Mkvmerge to version 43.0.
DOWNLOAD => BDtoAVCHD_v2.9.3.msi
Old 11th April 2020, 18:00   #898  |  Link
pistacho
Version 2.9.4 (04/11/2020)
  • Updated: x264 encoder to version 160.3000 (r3000).
  • Updated: x265 encoder to version 3.3+2.
  • Updated: Mkvmerge to version 45.0.
DOWNLOAD => BDtoAVCHD_v2.9.4.msi
Old 12th June 2020, 09:32   #899  |  Link
pistacho
Version 2.9.5 (06/11/2020)
  • Updated: x264 encoder to version 160.3007 (r3007).
  • Updated: x265 encoder to version 3.4+1.
  • Updated: Mkvmerge to version 47.0.
DOWNLOAD => BDtoAVCHD_v2.9.5.msi
Old 11th July 2020, 16:36   #900  |  Link
masterkivat
変身!
masterkivat's Avatar
Does BDtoAVCHD have plans to support multi-audio sources? Like, let's say I have an .mkv file that have multi-audio tracks and in order to give more bitrate to the video (reencoding it obviously), I may want to reencode these audio tracks to AC3 640kbps or less and keep all these audio tracks in the final project...
masterkivat is offline   Reply With Quote
avchd, bdtoavchd, blu-ray ripper, m2ts, ps3
