Old 24th August 2011, 15:37   #41  |  Link
nand chan
You probably forgot to specify a hardware device context. The following I assume are the relevant imported functions for what you want to do, since all lut loaders contain them.
User32.dll
GetMonitorInfoA
EnumDisplayMonitors
MonitorFromWindow
GDI32.dll
CreateDCA
GetICMProfileA
SetDeviceGammaRamp
GetDeviceGammaRamp
DeleteDC
Done.
Forget about my old .3dlut stuff, just use mpv if you want accurate color management
nand chan is offline   Reply With Quote
Old 24th August 2011, 15:47   #42  |  Link
leeperry
Kid for Today
Originally Posted by nand chan View Post
For the curious, a comparison of 16-bit LUT vs 8-bit LUT (to make madVR load it, I first converted it down to 8-bit and then converted that back up to 16-bit which is simply a bit-shift, the same way madVR converts levels). You can clearly see the advantage of greater-than-8-bit precision processing even on 8-bit devices. So if you want to use a .3dlut with avisynth be wary of this difference:
http://screenshotcomparison.com/comparison/75573
fair enough, but here's a real world banding test pattern going through LAV CUVID: Banding 720p.rec709.mkv
no post-processing in ffdshow, simply bypassing as 16-235 YV12, and mVR taking care of TV>PC conversion and dithering on top(no LUT enabled in there):
and now SmoothL() plus an 8bit YUY2 LUT in ffdshow, outputting 0-255 RGB32 to mVR, only taking care of dithering:
on my semi-10bit CRT, the latter looks much smoother.
Old 24th August 2011, 15:51   #43  |  Link
Its an artificial pattern, how is that real world?
Anyhow, while the first shows very minor 1px bands (no severe macro bands), the second shows very strong dithering noise.
Personally, on this LCD screen, i prefer the first. But of course, that may just be a matter of taste, and/or different screen technologys.
Old 24th August 2011, 15:52   #44  |  Link
Wile-E-Coyote
Hello.
I just successfully calibrated my TV with dispcalGUI and wanted to create a 3Dlut file with it but when I open my ti3 file I get an error message saying the input string format is incorrect.
Wile-E-Coyote is offline   Reply With Quote
Old 24th August 2011, 16:02   #45  |  Link
leeperry
Kid for Today
Well, real world as in "going through the whole video pipeline".
I'll give you that I was using SuperSampling and Grainfactory4()....now w/ only SmoothL+YUY2 LUT:
any better on your LCD? Hopefully not a 6bit TN?
I could also disable dithering in mVR, but I like a grainy picture tbh:
Old 24th August 2011, 16:09   #46  |  Link
nand chan
The third pattern looks identical to the first pattern on my monitor. The second pattern has awful dithering noise as mentioned.
10-bit H-IPS with 12 bit internal LUTs.
Originally Posted by Wile-E-Coyote View Post
Hello.
Upload the .ti3 you get errors with.
Old 24th August 2011, 16:32   #47  |  Link
Wile-E-Coyote
Here you go
Old 24th August 2011, 16:33   #48  |  Link
nand chan
Going to go ahead and release version 0.5 as-is because the software is still alpha either way and I don't want to delay the current release/feedback cycle too much.
Might still be some bugs, I haven't extensively tested every single tool after the code re-write. Everything should be a lot, lot cleaner though.
In version 0.6 I am going to be adding multi-threaded .3dlut processing to speed up execution time on multi-core processors.
As usual, see the first post for a changelog: http://www.mediafire.com/?wwbuu5vhau5x6jm
I'm still trying to think of a new name for the project.
Works fine for me in version 0.5, try it.
Old 24th August 2011, 16:43   #49  |  Link
I agree, third and first look pretty much identical.
The 4th shows more banding then the others.
Also H-IPS 10bit with 12bit LUT (Dell U3011)
Old 24th August 2011, 16:55   #50  |  Link
leeperry
Kid for Today
It's not dithering at all, it's grain added on purpose via the GrainFactory4() Avisynth script(I'm a movie grain whore ). But you can see that 10bit untouched mVR processing and SmoothL+8bit YUY2 LUT in ffdshow+mVR dithering look identical, which was my original point...so to me that still leaves the ffdshow LUT option very much open.
Old 24th August 2011, 17:16   #51  |  Link
Wile-E-Coyote
I did. Same error.
Old 24th August 2011, 17:37   #52  |  Link
nand chan
Dell U2410 here
I've finished writing the multi-threading code now, applycal.exe completes /calculation/ in about 0.6 seconds. Saving/loading the .3dlut still takes about 1 second overall.
CPU usage spikes nice and high at 100%.
I did. Same error.
I can't reproduce it. It works fine here, even using the GUI. Are you sure you're using the latest version?
Old 24th August 2011, 17:42   #53  |  Link
Wile-E-Coyote
Yes, .NET framework is also up to date. I'll guess I have no choice but sit through another 2 hours of calibration to try again.
Old 24th August 2011, 17:44   #54  |  Link
nand chan
Does running
genscript.exe -i profil.ti3 -o -
work?
It works here and it should output the following: http://pastebin.com/pmei93qL
You can go ahead and copy/paste that into a .txt file, run it using yCMS and it should give you a working .3dlut.
(You already have a copy of yCMS in %AppData%\TI3Parser\yCMS if you've been using this program)
Fair enough. What is it exactly that you want to do? Apply calibration information from a .cal file to a YCbCr LUT?
If so, it should be a simple process of going through the YCbCr LUT, converting each entry to RGB, running the RGB through the Calibration LUT, then converting the result back into YCbCr.
I can have a program for this running by 0.6, but I can't test it myself. You'll have to check for bugs yourself.
Old 24th August 2011, 17:49   #55  |  Link
Wile-E-Coyote
Does running
work?
No running that command line gives me the same error message. I'll try your advice later. Thanks.
EDIT : yCMS gives me an error message as well
Error! Invalid Command: '109.8925'.
Old 24th August 2011, 18:15   #56  |  Link
nand chan
Very odd, I get:
The file '..\test.3dlut' was successfully created.
Running time: 4449ms; Computation time: 1765ms (39.7%)
When you're saving the file do you have some sort of word wrap enabled maybe? Also what operating system are you on? Maybe it's detecting the line breaks incorrectly, which would explain both issues.
@leeperry: Can you run inspect3dlut on a YCbCr .3dlut and upload the output somewhere? (Or simply tell me what it reports for the two color encoding fields)
Old 24th August 2011, 19:36   #57  |  Link
Wile-E-Coyote
Very odd, I get:
Word wrap? Not that I know of. I pasted the text on notepad.
I'm running Win 7 Ultimate x64
Old 24th August 2011, 19:39   #58  |  Link
nand chan
See “Format -> Word Wrap”.
Regardless, I don't know what else could be causing the problems.
Old 24th August 2011, 19:43   #59  |  Link
Wile-E-Coyote
Word wrap is deactivated, but I decided to open the file in Notepad++ and re-save it, and it worked, at least for yCMS.
I'm trying to use that method for the 3ti files but without success so far.
Old 24th August 2011, 21:02   #60  |  Link
alph@
Replicant
alph@'s Avatar
Hello.
here too, same error message?i have the framwork 4,it's the last version of ti3 Parser
upload
http://www.mediafire.com/?rr2648w3ow9ftb4
alph@ is offline   Reply With Quote
3dlut, argyllcms, color management, icc, madvr, ti3, ycms
