11th January 2015, 04:26 | #21 | Link |
Software Developer
Zoom Player MAX v10 beta 6 has been released (skipped v9.6).
Many new features introduced, including two new fullscreen navigation interfaces (a media scanner and audio/subtitle stream selection), support for assigning functions to the 4th and 5th mouse buttons and more... |
11th January 2015, 05:47 | #22 | Link | |
I especially like the extra mouse button support. What about mouse buttons 6 to 10? Maybe with only the "Custom" option to keep the UI from exploding any more? The audio/subtitle stream selection interface is nice too. What does the "Install Codec pack" option install? Anything that is not in the Install Center? |
11th January 2015, 05:59 | #23 | Link |
It installs LAV and DC-BASS, the installers of which are now included in the Zoom Player download. So if you already have those two installed via Install Center, you can deselect the codec pack option in the installer.
11th January 2015, 17:06 | #24 | Link |
Software Developer
Asmodian:
I've added support for the 4th and 5th button as there's a clear API for that. It seems that additional buttons may not be using the same API and may in fact just do keyboard shortcuts (which you can hook using ZP's keyboard editor) or must use custom drivers to support. |
15th January 2015, 00:39 | #25 | Link |
Software Developer
Zoom Player MAX v10 beta 7 has been released.
It introduces the new mini color control interface that simplifies changing of color values (brightness/contrast/saturation/hue/gamma) while taking minimal screen space. |
15th January 2015, 01:36 | #26 | Link | |
Zoom Player really has become an amazingly feature complete touch-enabled video player. Now I need to get a Windows 10 tablet to replace my iPad! |
22nd January 2015, 23:20 | #27 | Link |
Software Developer
Asmodian:
I bought a Win 8.1 tablet for $83+$32 shipping (still waiting for it) so I can test how well ZP works on these Sub $100 windows tablet with atom baytrail processors. I'm also working on adding kinetic scroll support to give that as an option instead of the current scrolling method, it works reasonably well on my current test system (ASUS Transformer T100). |
28th January 2015, 05:27 | #29 | Link | |
I really like the time tool tips and chapter markers on the control bar but is there a way to change the color of the chapter markers that I missed? Not that magenta is bad but I might like something less visible. Also, have you looked into enabling Large Address Aware? I found it was required when using advanced ass subtitles with xySubFilter and MadVR on a 4K display. Zoom Player is better than ever. I have been liking the minimal mode with seek bar (F8). Combined with binding exit to middle click it seems like I am not missing anything but I also have an almost border-less video player. |
29th January 2015, 18:35 | #30 | Link |
Software Developer
Asmodian:
You'll have to edit the skin to change the chapter's tick-color. I'm not really sure why you need to have ZP be large address aware, ZP doesn't use anywhere near 2GB so having 4GB addressable space shouldn't really have any effect. |
29th January 2015, 19:16 | #31 | Link | |
just take a UHD sample set madVR CPU queue to over 48 and zoomplayer will crash. some filter can take quiet some RAM like a subtitle renderer and with UHD this is going to take more than 1.5 GB of RAM from time to time. one P010 UHD frame is about 20 MB |
30th January 2015, 09:10 | #32 | Link | |
I think I saw nearly 3 GB of RAM used at the worst (busy animated ass with xySubFilter) playing P010 1080p on a 4K screen after patching zplayer.exe. I am positive it was regularly over 2 GB. Of course this memory usage it isn't really Zoom Player and switching to xyVSFilter was also a solution in my case. I only thought rendered at 4K subtitles were worth fighting for. |
31st January 2015, 00:03 | #33 | Link |
Software Developer
I enabled the large address aware flag:
http://zoomplayer.com/t/zplayer_large_address_aware.zip However, I have not tested this and I'm not sure if there is impact on performance or stability, so this won't be part of v10 final. Please test and report if there are any issues. |
31st January 2015, 06:33 | #34 | Link |
Wow thanks! I happen to be traveling and do not have access to my sample or system to test. I will have to report my results is four days. :/
No need to rush it in, patching has always worked well for me. I just need to redo it every time I update Zoom Player and enabling large address aware by default might help others with 4K displays. I am also curious what impact it would have on 32 bit systems. |
31st January 2015, 09:41 | #36 | Link | |
Thats really all it does, so unless you use crazy evil code that stores a flag in the highest bit of memory addresses, you are fine.
2nd February 2015, 03:58 | #37 | Link |
Software Developer
Version 10 release candidate 2 has been released:
http://www.inmatrix.com/files/zoomplayer_beta.shtml |
6th February 2015, 07:34 | #38 | Link | ||
8th February 2015, 13:33 | #39 | Link |
Software Developer
Admodian:
v10 will come with LAA enabled by default in v10. I just spent hours trying to figure out why Zoom Player window would auto-maximize on launch on a 7" windows tablet I just got in for testing. Looks like another "feature" built into Windows 8.1 that auto-maximizes EVERY window, with no clue on how to disable this behavior. Managed to write a work-around, but it wasn't the cleanest of code. |
11th February 2015, 04:08 | #40 | Link |
Software Developer
Version 10 release candidate 3 has been released:
http://www.inmatrix.com/files/zoomplayer_beta.shtml This RC includes quite a few fixes related to tablet/touch-input. |
dvd, htpc, media player, tablet, zoom player |
