Old 27th April 2015, 11:56   #2001  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Doh. Made a mistake in ffmsindex and avisynth ffindex that would make it unflag video tracks for indexing in many cases. Here's a fixed build:
test2
Old 27th April 2015, 12:31   #2002  |  Link
stax76
stax76's Avatar
I tested 3-4 different source types, measured memory consumption, CPU usage and performance with AVSMeter against L-Smash, awesome work, perfect candidate to replace 2.20.
Old 2nd May 2015, 21:34   #2003  |  Link
Myrsloik
Myrsloik's Avatar
Here's test3.
The main noticable change is the framerate "correction". It should now more reliably pick common framerates if the input is close to one.
Previously it would "correct" framerates to 30001/1001, 25020/1001 or worse.
Test it and report your findings.
Old 2nd May 2015, 21:50   #2004  |  Link
Myrsloik
Myrsloik's Avatar
I want to remove the SWScale() function from avisynth since swscale is so horrible in general and doesn't really add anything compared to already existing resizers.
Objections?
Old 4th May 2015, 11:17   #2005  |  Link
stax76
stax76's Avatar
Thanks for the new build. Two PAL samples were ffms2 don't use 25 or 50:
https://www.dropbox.com/s/v6urrdq6ih...%20fps.ts?dl=0
https://www.dropbox.com/s/j5bwk0u205...rphic.mpg?dl=0
Old 4th May 2015, 12:08   #2006  |  Link
Myrsloik
Myrsloik's Avatar
The 50fps one is exactly 50fps and not changed at all. So that one works for me. No idea what you're getting for that one.
The other one is too far off from 25fps. ~24.9495 fps to be exact. Actually 25000/1001 (24.9750) is quite far off too, seen as a percentage. The current code will only adjust the framerate if it's within 0.05%. This small interval is needed since the difference between 25 and 25000/1001fps is only 0.1% and would otherwise cause more trouble than it solves.
The reason it's done at all is mostly to recover a normal fps from matroska files.
AssumeFPS() is your friend.
Old 4th May 2015, 12:39   #2007  |  Link
stax76
stax76's Avatar
My understanding of frame rates and field processing, especially NTSC is basic at best. 30000/1001 and 24000/1001 are obviously NTSC but were does 25000/1001 come from?
The 50 fps sample is reported as 25 fps by MediaInfo! I tried to deinterlace it and use AssumeFPS but couldn't find a way to properly process it, only thing that helped was using fpsnum, fpsden arguments for FFVideoSource.
What StaxRip and I believe MeGUI too do is read the frame rate with MediaInfo and then use AssumeFPS. With the Ski sample this didn't work so I switched to use fpsnum and fpsden arguments in the latest StaxRip release.
Old 4th May 2015, 12:51   #2008  |  Link
sneaker_ger
That can't be quite right. fpsnum/fpsden duplicates and/or deletes frames, it shouldn't help with deinterlacing.
The problem with the "SD - anamorphic.mpg" sample is probably initial delay. Delay makes an otherwise nice 25 fps cfr file into vfr with a peculiar average frame rate. Maybe delays should be handled differently? Does not really make sense to use them for the average fps calculation when we cannot map delays into AviSynth anyways (on account of being limited to cfr).
Old 4th May 2015, 13:06   #2009  |  Link
stax76
stax76's Avatar
The ski sample is 50i right? MediaInfo reporting it as 25 fps should be a bug then.
Old 4th May 2015, 13:15   #2010  |  Link
sneaker_ger
It looks ok: frame rate 25, (implied) field rate 50
Old 4th May 2015, 14:11   #2011  |  Link
stax76
stax76's Avatar
When I query the frame rate from AviSynth I get 50 fps from ffms2, something is wrong here, I've never seen a sample like this. How would a full script handling this properly look like?
Old 4th May 2015, 14:26   #2012  |  Link
sneaker_ger
Oh, you're right. ffms2 duplicates all frames for some reason. So fpsnum=25 (or similar like selecteven()/selectodd() or changefps()) might be valid after all
Old 4th May 2015, 14:51   #2013  |  Link
Myrsloik
Myrsloik's Avatar
It's interlaced h.264. It's a known and annoying issue and even in FFmpeg it's handled differently (inexplicably doubled framerate and stuff).
Old 4th May 2015, 15:02   #2014  |  Link
stax76
stax76's Avatar
Ahh, now I understand what's wrong, maybe Myrsloik can fix it. I didn't know that fpsnum, fpsden mostly is about dropping frames so I'll go back to using AssumeFPS.
Old 4th May 2015, 15:05   #2015  |  Link
Myrsloik
Myrsloik's Avatar
Go annoy the FFmpeg developers until they begin to see common sense.
Not going to add a workaround unless money is involved. There may be some other TS issues lurking in that file too.
Old 4th May 2015, 15:08   #2016  |  Link
stax76
stax76's Avatar
l-smash-works fixes it, maybe workaround ffmpeg problem? Maybe ffmpeg could be fixed by reporting it?
Old 4th May 2015, 18:42   #2017  |  Link
Myrsloik
Myrsloik's Avatar
We (the union of disgruntled source filter writers of doom9) had a quick discussion about this. We all think FFmpeg sucks and that the behavior/API should be fixed in it.
Btw, interlaced fields is frame murder.
Old 4th May 2015, 19:04   #2018  |  Link
stax76
stax76's Avatar
Thanks for investigating. I've done a small workaround, StaxRip includes 40 tools and plugins and since no software is perfect GUI authors constantly end up doing workarounds, I'm used to this. Most tools are pretty good, only mp4box sucks big time, I've every week a new problem with it, last week I discovered it's the only tool requiring VC++ 2010 runtime being present, not a big deal on it's own but after 20 more issues it starts to bother.
Old 4th May 2015, 23:25   #2019  |  Link
last week I discovered {mp4box is} the only tool requiring VC++ 2010 runtime being present
I believe jb_alvarado's media-autobuild_suite can compile MP4Box with GCC too. When it succeeds...
Well, that's not related to FFMS2.
No native AviSynth source plugin is perfect yet. Fortunately, we have a choice in many cases.
Old 5th May 2015, 14:33   #2020  |  Link
RRD
RRD's Avatar
Hello,
When I use ffmsindex.exe -k on a 59.94 (60000/1001) fps .mkv file (MediaInfo 0.7.73 report), “fps 0” appears in the output (keyframe numbers are then listed properly). Why? Is this normal?
Other occurrences found with Google:
http://forum.doom9.org/showthread.php?p=1559483#1503
http://forum.selur.de/post7638.html#p7638
http://www.amara.org/en/videos/O0RyzUaR43Oe/ru/596359/
http://www.vidqt.com/id/leeIUjHh8aE?lang=ru
http://lj.blargh.info/mckf04.txt
RRD is offline   Reply With Quote
