Old 21st June 2007, 20:01   #21  |  Link
akupenguin
x264 developer
akupenguin's Avatar
Originally Posted by d'Oursse View Post
ask the gstreamer developpers about the different versions of ffmpeg. For a developper it's a pain. Example : 3 or 4 days ago : they changed the options of configure. It's not 3 years at all.
That's the build system, not the api. It affects compiling ffmpeg, not compiling programs which use libav*, unless you imported a copy of ffmpeg into your source tree.
Incompatible api changes require incrementing the major version, which has happened twice in the last 3 years.
akupenguin is offline   Reply With Quote
Old 22nd June 2007, 17:50   #22  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
My attempt at a sample accurate audio source. Not very tested yet. Only supports mpeg1 layer 2/3 audio in mkv so far. Should seek accurately in the same formats as the video source.
Usage: FFAudioSource(string source, int track = -1)
Experimental audio source
Old 23rd June 2007, 11:06   #23  |  Link
ficofico
I've tried to make a script including this line
(mvfpsflowscd(30,oversample=16,blurradius=4)
but when I open the file with FFMpegSource avisynth give me an error
Where I've to write "linear=false" ?
ficofico is offline   Reply With Quote
Old 23rd June 2007, 13:37   #24  |  Link
IanB
Avisynth Developer
ChangeFPS(...., linear=False)
And it will be on line 10 of one of your *.AVSI files.
Also oversample=8 might probably avoid the issue as well.
IanB is offline   Reply With Quote
Old 28th June 2007, 21:37   #25  |  Link
Mr_Odwin
FAVC Man
Mr_Odwin's Avatar
What there is of this so far is great. I used it today on an flv file and the video part seemed to work fine, even though flv isn't mentioned in the readme.
Mr_Odwin is offline   Reply With Quote
Old 2nd July 2007, 22:47   #26  |  Link
Myrsloik
Myrsloik's Avatar
A new version has been released with several improvements to seeking.
FLV files have now been confirmed to work perfectly
VOB files now appear to have frame accurate seeking (at least with the single test vob used) but no rff flags applied (won't ever happen)
Normal MPG files should seek without showing artifacts
Feel free to report the results with any other containers you use.
Old 2nd July 2007, 22:57   #27  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
Wouldn't applying rff flags be a must for proper IVTCing of badly flagged video? (Looking at that URL in your sig I'm rather surprised to read the above... )
np: Lusine - Flat (Cepia Remix) (Podgelism)
now playing: [artist] - [track] ([album])
Leak is offline   Reply With Quote
Old 2nd July 2007, 23:04   #28  |  Link
Myrsloik
Myrsloik's Avatar
Doing that using only libraries coming from ffmpeg you have to first decode the video to find out the flags. So in the end all you'd get is a very slow dgindex/dgdecode clone if you're lucky. I don't see a great demand for that.
If you find me a nice mpeg/vob/ts parsing library it would be a completely different thing though...
Old 4th July 2007, 22:25   #29  |  Link
infernix
the funk phenomena
infernix's Avatar
works on wine! tried only on demuxed .vc1 source so far:
FFmpegSource(source="FEATURE_1_FEATURE_2.VC-1.stream.0.vc1",track=-1,seekmode=0,timecodes="test.timecodes",cache=true,cachefile="test.ffcache")
AssumeFPS(23.976)
takes a minute or two to index for 18GB. And I can't seek, or it takes incredibly long (probably the latter).
Thanks so much i hate the VFW interface, I couldn't get it to read vc1
infernix is offline   Reply With Quote
Old 13th July 2007, 06:18   #30  |  Link
Myrsloik
Myrsloik's Avatar
Version 1.3 has been released (see first post) and some other items have been added to the possible improvements list.
Old 13th July 2007, 16:21   #31  |  Link
ficofico
Myrsloik can you post the version 1.1? This version doesn't work in my batch script.
With the tool avs2avi, the avs file is like: ffmpegsource("temp.mp4) when temp.mp4 it's a x264 8000 bitrate .The conversion in xvid with avs2avi with the 1.1 release it's good, with this version doen't work, it give me error.
The dll in plugins directory it's still 1.1 (after I've seen that 1.3 doesn't work) but the dll in system32 are from 1.3 version.
thanks
Old 13th July 2007, 18:02   #32  |  Link
Myrsloik
Myrsloik's Avatar
No, if you can't be bothered to actually tell me what the error is it can't be that important.
Old 13th July 2007, 18:51   #33  |  Link
ficofico
the error it's
the script it's very simple
Before upgrade ffmpeg works well.
Old 13th July 2007, 19:47   #34  |  Link
Harukalover
Harukalover's Avatar
ficofico: Hint: Read the manual when upgrading to newer versions.
There is no function named ffmpegsource anymore.
/me points to ffvideosource
Harukalover is offline   Reply With Quote
Old 13th July 2007, 20:07   #35  |  Link
ficofico
ops..................sorry, but I've assume that the name was a constant.
Old 13th July 2007, 20:07   #36  |  Link
Myrsloik
Myrsloik's Avatar
My guess is that you're using the ffmpeg dlls from a previous version/other program.
Old 13th July 2007, 20:47   #37  |  Link
ficofico
no no, now I've upgrade the dll and change the script, now work. Thank you and sorry for the mistake.
Old 16th July 2007, 14:29   #38  |  Link
Myrsloik
Myrsloik's Avatar
It's time to get some input from the silent masses...
What should I do about audio handling in general?
Is there any reason at all to keep FFAudioSource when FFAudioRefSource actually works (if you've got the space)?
Should FFAudioRefSource be merged with FFVideoSource (faster file opening the first time if you want both audio and video)?
Should I waste many more hours to try to get FFAudioSource to work (it's highly unlikely it'll ever be good for more than previews)?
...the next version will also have postprocessing.
Old 16th July 2007, 16:20   #39  |  Link
Mr_Odwin
FAVC Man
Mr_Odwin's Avatar
I personally would like FFVideo and FFAudio/FFAudioRef merged; perhaps like QTInput/Directshowsource where there is an audio=true/false option?
Old 17th July 2007, 00:17   #40  |  Link
IanB
Avisynth Developer
From a user perspective it is much more straight forward to them if you do the AudioDub of the audio and video internally for them.
From a programming perspective I know it sucks having function arguments left, right and centre to control need behaviour.
