Old 9th March 2018, 20:12   #15641  |  Link
He is also using older version of AviSynth+ r2455. I have r2580.
Old 9th March 2018, 21:44   #15642  |  Link
MaistroX
HereŽs a link to a video of exaktly what I do and settings and so on -> https://streamable.com/83rcf
Something went wrong because It should be
\\RWDA-2018\RipBot264temp\job4\video.mkv
You will have to show me step by step what you do exactly (video would be very helpful!)
MaistroX is offline   Reply With Quote
Old 9th March 2018, 21:48   #15643  |  Link
tkwou
loss of audio
Hi Atak_Snajpera. I switched to 1.22.0 and I'm not getting any audio tracks. The MKVinfo.txt does not contain any info. It has an error message "Error: no destination file name was given." So job1_a1.avs andjob1_a2.avs are also empty.
tkwou is offline   Reply With Quote
Old 10th March 2018, 14:52   #15644  |  Link
@tkwou
Download mkvtoolnix v19 or update to v1.22.2
Old 10th March 2018, 18:03   #15645  |  Link
tkwou
Old 10th March 2018, 18:14   #15646  |  Link
MaistroX
@Atak_Snajpera
Tryed to write you a private message but it says "The following errors occurred with your submission:
1.Atak_Snajpera has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
So I paste the message here insted!
"If my sample that are linked here https://forum.doom9.org/showthread.p...27611&page=522 is to low resolution, I can provide with Another link somewere in Hinger res. in private if youŽd like?
Relly would like to get this DE to work on my new system with Win 10.
Regards MaistroX"
Old 10th March 2018, 18:32   #15647  |  Link
Yes. Send me something with higher resolution. I can't see text.
Old 10th March 2018, 19:53   #15648  |  Link
MaistroX
@Atak_Snajpera
Her you go! -> https://www.dropbox.com/sh/91z3jjbez...mzUfvUYva?dl=0
Old 10th March 2018, 21:38   #15649  |  Link
byteshare
ByteShare
byteshare's Avatar
Check CPU and memory stability. You must be 100% sure that it is not an OC issue.
He ran Prime95 for about 3 hours no issues for CPU. Ran HeavyLoad test for RAM, no issues. I'll have him update AVISynth.
Old 11th March 2018, 12:56   #15650  |  Link
He ran Prime95 for about 3 hours no issues with CPU. Ran HeavyLoad test for RAM, no issues. I'll have him update AVISynth.
Also try with simpler x265 command line...
Old 11th March 2018, 15:48   #15651  |  Link
Spasm
This might help. I too was having random encoding server crashes after updating until I adjusted this setting:
Set at 0 (auto) = crashes. Anything else and it's back to normal.
Spasm is offline   Reply With Quote
Old 11th March 2018, 17:40   #15652  |  Link
varekai
varekai's Avatar
Running RipBot will disable (revert?) avisynth 2.60 used in BD-RB.
So to be able to use BD-RB a new install of avisynth is needed.
Disabling RipBot autoupdate doesn't help.
Any solution to this?
Old 11th March 2018, 18:21   #15653  |  Link
Rename Install.cmd in Tools\AviSynth
Old 11th March 2018, 22:14   #15654  |  Link
varekai
varekai's Avatar
Thanks for the info, worked like a charm!
Old 12th March 2018, 06:09   #15655  |  Link
burt123
burt123's Avatar
Problems with batch DE...TV series
Hi Atak,
Um, trying to do some "Married With Children" episodes in batch lots.
Seems to be OK when doing them singularly, but not in batch using DE.
I get errors every time, at the end of the process before muxing, I guess.
This is the Job log (if that helps) :-
E:\>"C:\Users\Administrator\Documents\RipBot264v1.22.0\EncodingClient.exe" "E:\Temp\RipBot264temp\job1\job1_EncodingClient.meta"
E:\>"C:\Users\Administrator\Documents\RipBot264v1.22.0\tools\mp4box\mp4box.exe" -tmp "E:\Temp\RipBot264temp" -add "E:\Temp\RipBot264temp\video.264":name="Married with children s01e01 dvdrip xvid-fov-1" -fps 29.97 -add "E:\Temp\RipBot264temp\job1\Encoded_Audio_1.aac":lang=und -mpeg4 -new "D:\Married With Children\Married With Children S01\New folder\Married with children s01e01 dvdrip xvid-fov-1.mp4"
AVC-H264 import - frame size 1280 x 720 at 29.970 FPS
AVC Import results: 41087 samples - Slices: 231 I 12339 P 28517 B - 41325 SEI - 227 IDR
Stream uses forward prediction - stream CTS offset: 2 frames
Opening file E:\Temp\RipBot264temp\job1\Encoded_Audio_1.aac failed
Error importing E:\Temp\RipBot264temp\job1\Encoded_Audio_1.aac:lang=und: Requested URL is not valid or cannot be found
Elapsed Time: 00h:21m:58s
Anything stick out as to what the problem might be ??
BTW, using very latest build & updates.
Cheers
burt123 is offline   Reply With Quote
Old 12th March 2018, 12:23   #15656  |  Link
Does E:\Temp\RipBot264temp\job1\Encoded_Audio_1.aac exist?
What happens if manually execute EncodeAudio.cmd?
Old 12th March 2018, 12:34   #15657  |  Link
burt123
burt123's Avatar
Just checked both...
No it doesn't exist, so where did this entry come from, and due to that, the .cmd doesn't do anything
Old 12th March 2018, 12:47   #15658  |  Link
It will be easier and faster if you send me whole job folder. (without those large files ofcourse)
Old 12th March 2018, 13:20   #15659  |  Link
burt123
burt123's Avatar
OK, should be here :-
http://www.mediafire.com/file/3eu3ezdhk94ded7/job1.rar
Old 12th March 2018, 14:25   #15660  |  Link
Originally Posted by burt123 View Post
Fix available via auto-update.
