2nd April 2020, 19:22 | #5341 | Link |
@FranceBB
Are you testing this on vanilla XP or the one with modified kernel?
Groucho's Avisynth Stuff |
2nd April 2020, 21:49 | #5342 | Link | |
Broadcast Encoder
Anyway, I'll reboot with the normal kernel and I'll let you know. EDIT: Nope, same behavior with the normal kernel... I also tried with: Code:
SetMaxCPU("C") ColorBars(width=848, height=480) Even specifying C only doesn't make the other programs work... Only VirtualDub works and I have no idea why... Last edited by FranceBB; 2nd April 2020 at 22:15. |
2nd April 2020, 22:15 | #5343 | Link |
You have copied the 32bit dll's into the system 64bit directory (system32)?
I am reading System32 directory and see AvsMeter x86 Edit: My Error, your on WinXP 32bit correct?
Live and let live Last edited by gispos; 2nd April 2020 at 22:19. |
2nd April 2020, 22:18 | #5344 | Link | |
Broadcast Encoder
There's "System" which is the old 16bit and System32 which is the 32bit System. Windows XP x86 with 32 GB of RAM DDR4. https://tarma.com/support/im9/using/...picalpaths.htm |
2nd April 2020, 22:19 | #5345 | Link | |
結城有紀
2nd April 2020, 22:22 | #5346 | Link |
The only difference I can think of is that VDub uses the VfW interface whereas the others you tried use the native API, either C or C++.
2nd April 2020, 22:34 | #5347 | Link | |
2nd April 2020, 23:33 | #5348 | Link |
FranceBB, You are using VirtualDub Filtermod, thats an old one. [Been VirtualDub2 for quite some time]
3rd April 2020, 00:23 | #5349 | Link |
AviSynth+ version 3.5.1 has been released.
Mostly just bugfixes and tidying up POSIX stuff. Seeing the recent discussion, might want to check against 3.5.1 to see if the issue with C api programs exists.
3rd April 2020, 00:40 | #5350 | Link | |
Broadcast Encoder
Oh, I didn't know that. I just updated it and it works like a charm. I noticed that it now also has some added features like the device capture, the VP8 and VP9 encoding through ffmpeg and so on. Anyway, even with the new version of VirtualDub, the new Avisynth works, however nothing else does... |
3rd April 2020, 00:44 | #5351 | Link |
Well, I'm out of ideas for now.
3rd April 2020, 01:35 | #5352 | Link | |
See My Avisynth Stuff |
3rd April 2020, 01:52 | #5353 | Link | |
ColorBars(width=640, height=480, pixel_type="yv12") admfilter() Prefetch(4) Zs_RF_Shared and AdvancedDenoising
3rd April 2020, 01:56 | #5354 | Link | |
Broadcast Encoder
My guess (and it's just a guess) is that the test build wasn't actually compiled with something for XP and the only reason why Dependency Walker was saying that everything was fine was that probably what was "missing" already had an implementation made by the wrapper of my custom kernel but perhaps it wasn't complete and it broke something, I don't know. Anyway, it works now, so... I guess all's well that ends well Last edited by FranceBB; 3rd April 2020 at 01:58. |
3rd April 2020, 03:08 | #5355 | Link | ||
An access violation that only occurs in programs that directly talk to AviSynth, but not in programs that use VfW as a middleman points to it being that something in the Neo patchset changed the API and we need to identify and mitigate that. I haven't taken a look at any of it yet, though, so it may not have anything to do with that. |
3rd April 2020, 04:13 | #5356 | Link | |
but if I use the 3.5.1 as a main and load this from MPP block it work! Code:
mp_pipeline(""" ### dll: C:\3.5.test_20200402b\x64\AviSynth.dll ColorBars(width=640, height=480, pixel_type="yv12") admfilter() Prefetch(4) ### ### """)
3rd April 2020, 07:13 | #5357 | Link | |
3rd April 2020, 08:32 | #5358 | Link |
here https://github.com/realfinder/MP_Pipeline/releases
or last official one mirror https://forum.doom9.org/showthread.p...28#post1841228
3rd April 2020, 13:46 | #5359 | Link | ||
Broadcast Encoder
3rd April 2020, 16:58 | #5360 | Link | |
Have you tried? Something has changed from the previous version. Could this cause problems for some people? More information Code:
example 1 (this was still possible without 'return') ------------ LWLibavVideoSource(SourceFile) return dummy() function dummy(clip clp){ clp } example 2 (This was possible, not now) ------------ LWLibavVideoSource(SourceFile) #dummy() function dummy(clip clp){ clp } example 3 (MP_Pipeline needs now also return) ------------ MP_Pipeline(""" ### inherit start ### SourceFile = String(ScriptDir()) + "Goblin.mkv" ### inherit end ### LWLibavVideoSource(SourceFile, cache=False) ### ### ### platform: Win32 HDRAGC() ### platform: Win64 ### ### audio=LWLibavAudioSource(SourceFile, cache=False) audioDub(last, audio) return last """) sharpen(0.40)
Live and let live |
