28th August 2018, 11:29 | #52181 | Link | |
29th August 2018, 10:56 | #52183 | Link | |
noise is the biggest problem for me now with MADVR, its so bad on my RX 580 i've had to move back down to NGU Low from HIGH, have been getting high with sub 20ms rendering which is pretty good for polaris. Thought about watercooling my card but to expensive and too much of a faff. I've done as much soundproofing as I can, you can only go so far before you ambient temps get too high, my PC is now idling about 45 degrees which isnt great. My previous card, RX 460 used to be very loud and could barely manage NGU LOW though so upgrading to the RX 580 was still a good buy for me as I can get NGU LOW on 40% GPU fan which is pretty much silent. |
29th August 2018, 12:13 | #52184 | Link |
you should check benchmark to see how a card is performing in term of temps and noise.
i can't remember a card i brought that was even remotely loud. if it was the r9 270, 760, rx 480 or my 1060 "all" where properly cooled and never good loud at all temp and not problems too. and i don't even use a case fan... there is no way other none reverence cooled mid range cards are that bad. try a custom fan curve and don't forget 80 degree is save for a modern GPU. or even lower the power target, under volt and/or under clock the cards. |
29th August 2018, 12:25 | #52185 | Link |
Soul Seeker
Regarding chroma upscaling is this true? I saw it in a guide:
"The sharpness of the algorithm used in chroma upscaling section should not exceed the sharpness of the algorithm used in the image upscaling section. It could be the same, but not exceed it." |
29th August 2018, 12:32 | #52186 | Link |
Its basically pointless to use a sharper chroma scaler then Luma. If you have processing power to spare, use a better Luma scaler instead.
29th August 2018, 12:42 | #52188 | Link |
while i totally agree that you should not use processing intensive scaler on chroma if you have to scale luma. but i disagree on the sharpness.
i personally use super XBR 125-150 on chroma and super XBR 100 on image scaling. |
29th August 2018, 16:45 | #52194 | Link |
Madshi says GTX 1050 = underpowered with latest Madvr setting, which means RTX 2080Ti is a must, haha
https://www.avsforum.com/forum/24-di...l#post56716594 |
29th August 2018, 16:45 | #52195 | Link |
my card nearly hits nearly 50 decibels at full load which is apparently normal for this card, i've never hard a card thats quiet at full load though, pushing that much air has to make a decent amount of noise.
Mine is silent up to about 60% fan |
29th August 2018, 17:06 | #52196 | Link | |
Win11 Pro x64 b23H2 Ryzen 5950X@4.5Ghz 32Gb@3600 Zotac 3090 24Gb 551.33 madVR/LAV/jRiver/MyMovies/CMC Denon X8500HA>HD Fury VRRoom>TCL 55C805K Last edited by Manni; 29th August 2018 at 17:13. |
29th August 2018, 17:36 | #52198 | Link | |
29th August 2018, 17:49 | #52199 | Link | |
HDR -> SDR can output to any brightness or color gamut. The problem is your SDR calibration would have to balance both formats. SDR is most accurate close to 100 nits, while HDR is most accurate close to 1,000 or 4,000 nits. So it isn't easy to balance the two with a reasonably bright display.
29th August 2018, 17:53 | #52200 | Link | |
Try installing MSI Afterburner and creating a custom fan curve. You can keep the fan at idle or at a low speed until the GPU becomes very hot. If the card never gets past this temperature with your desired settings, then you don't have to worry about excessive cooling, which the default fan profile will usually do.
