27th December 2018, 18:14 | #54001 | Link | |
good card for UHD HDR HEVC files @60fps
so I'm going to change my graphic card.... What is the lowest in price nvidia graphic card that has no problem with 4K HDR HEVC files coded @60fps? thank you |
27th December 2018, 22:21 | #54005 | Link | |
Are there any benchmark tools that have certain tests and point systems that map well to madVR NGU performance? For example: You want a card that can achieve 2000 points in 3DMark - Ice Storm to have a good NGU experience. |
27th December 2018, 22:26 | #54006 | Link | |
I imagine that a 1070ti is better of the 1050ti you suggested me.... Right? Some other specification needed to do perfectly hevc uhd 60fps files ? |
27th December 2018, 22:44 | #54007 | Link |
it can't do VP9 10 bit and you asked me for the cheapest card not a good card. but "all" cards released after the 960 and including the 960 have a HEVC decoder that can do at least 120 hz at UHD if i remember correctly.
if you need copyback decoding make sure you have 16 lanes of PCIe 3.0 available. i would personally get a 2000 series card if you are willing to spend this much the upcoming 2060 should be in the same performance and price range with an added VP9 10 bit decoder and tensor cores which may or may not be important. |
27th December 2018, 22:58 | #54008 | Link | |
an hades canyon would be an option too but they are very expensive the CPU is an total over kill but vega isn't known to perform bad with NGU. there is sadly little know about vega not a popular product to say it friendly. let's just hope something good from AMD get's announced at CES. |
28th December 2018, 15:28 | #54010 | Link |
I just swapped my 1060 for a 1080ti and the NVidia drivers didn't automatically install so I guess I have to do it manually.
So I thought I'd ask, what is the recommended driver to use if your PC is just an HTPC (i.e. no gaming)? I was using 385.28 but wondering if there's a better choice at this point. Thanks! |
28th December 2018, 15:42 | #54011 | Link | |
are you talkin'about 1070 ti?
And more to use it with Madvr .... What are the differences between GTX and RTX series? thank you so much |
28th December 2018, 17:20 | #54012 | Link | ||
yes only cards release after the 1060 based on there chip design can do it the 1070 ti is relative new on the market but is just a 1080 with disabled cuda cores.
so all RTX cards should be able to do it 1050 ti and slower and 1080 ti have the decoder too. Quote:
the RTX cards are made for ray tracing that didn't really take off for now by using these tensor cores and some ray tracing cores. |
28th December 2018, 19:00 | #54014 | Link |
no because the file is limited range as it should be this is just an information what the file is and nearly all files are encoded in limited range and has nothing todo with GPU/madVR or even lavfilter settings.
changing the setting in lavfilter to full range does nothing on it's own if you would read what it is saying you would notices but for some reasons guides or people tell other to set it to full range misleading them or like the creator of the program doesn't select a proper default setting for something like this... |
28th December 2018, 19:46 | #54015 | Link | |
28th December 2018, 21:54 | #54016 | Link |
Somehow NV HDR now works properly 10 bit HDR with 417.35 .. i dunno
Using Potplayer x64 set to LavFilters 71.3 . D3D11 Automatic (native) ALL 8 bit is unchecked on Video . RGB selected 0-255 , Random Dithering . using Windowed Full Screen and not FSE . When launching it starts on windowed mode 8 bit and when I click enter to go Windowed Full screen it goes to 10 bit. I kept Set up digital Audio HDMI : LG TV and not Off. Nvidia control panel Use Default Color Settings , Scaling Aspect Ratio and Override the scaling mode set by games and programs Checked . MadVR Bit set to Auto If anyone wants to try those settings and see if it also works for him. I am not sure what makes it work, but it works. Last edited by x7007; 28th December 2018 at 22:02. |
28th December 2018, 22:51 | #54017 | Link |
NV HDR with 417.35 works only if madVR is set to 10-bit or auto and it switches to 10-bit. Nvidia CP settings don't matter. NV HDR doesn't trigger with madVR set to 8-bit. I mentioned this before and find this really weird.
29th December 2018, 00:21 | #54018 | Link | |
Thanks for the reply though. I wonder if there's a reason for madVR to continually render frames when no other renderer/player I tried does that while paused/stopped. It's odd. |
29th December 2018, 03:15 | #54019 | Link |
Is it normal that when i use madvr with xy-VSFilter and select a subtitle in video the color of the movie changed?
Default no sub https://imgur.com/oprrT9R With english sub selected https://imgur.com/SSo0l5f |
29th December 2018, 10:40 | #54020 | Link |
Three questions:
Can changing the Internet settings in the router, while madVR is playing, change the madVR- or picture settings in any way? Can changing the name of the folder (K-Lite Codec Pack) where the madVR folder is placed, change the madVR- or picture settings in any way? Can "NTFS Sparse Files Support" affect the file that is the program and in any way change the data to affect picture quality? Last edited by SirSwede; 29th December 2018 at 11:43. |
