Old 8th December 2018, 13:00   #6601  |  Link
Octo-puss
Could you add an option that would prevent MeGUI from storing *.backup files? I've just noticed the entire folder grew to hundreds of MBs over time.
Octo-puss is offline   Reply With Quote
Old 8th December 2018, 13:52   #6602  |  Link
LouieChuckyMerry
LouieChuckyMerry's Avatar
You could try going to "Options/Settings/Extra Configuration" and unticking "Always backup files when needed".
LouieChuckyMerry is offline   Reply With Quote
Old 8th December 2018, 14:39   #6603  |  Link
kuchikirukia
Try replacing "Dither_out()" by "ConvertFromStacked()".
If it still doesn't work show complete MeGUI log and Avisynth script.
Script error: There is no function named 'ConvertFromStacked'.
That's using the Avisynth portable that comes with it, according to settings and the log.
kuchikirukia is offline   Reply With Quote
Old 8th December 2018, 14:44   #6604  |  Link
Zathor
You have to load first the ConvertStacked.dll from the avs\plugins directory.
I also second the request to see your logs to be able to help better.
Old 8th December 2018, 15:11   #6605  |  Link
kuchikirukia
Ah. It seems to be miscategorized under Internal Filters in the wiki.
That works.
Old 9th December 2018, 12:17   #6606  |  Link
Octo-puss
Thanks, I'll see if it helps.
Old 9th December 2018, 15:20   #6607  |  Link
Betsy25
The new worker config options are top notch!
Betsy25 is offline   Reply With Quote
Old 9th December 2018, 15:24   #6608  |  Link
LouieChuckyMerry
Also, if you want to keep just a single backup of each item, then delete anything in "MeGUI Path/Update_Cache" with "obsolete" in the title. I usually do this each time I update so the folder doesn't grow too large.
Old 10th December 2018, 14:14   #6609  |  Link
imsrk48
imsrk48's Avatar
How to fix ImageSource error in megui?
http://imgur.com/a/vkkgPrW
Last edited by imsrk48; 10th December 2018 at 14:24. Reason: I Have Forgotten to give Image Link.
imsrk48 is offline   Reply With Quote
Old 10th December 2018, 14:42   #6610  |  Link
That depends which AviSynth version you may have installed in your Windows system, and if MeGUI uses its own portable AviSynth+ DLL. You will probably need to load the plugin ImageSeq.dll in your script explicitly from MeGUI\tools\avs\plugins.
Old 10th December 2018, 14:44   #6611  |  Link
Groucho2004
You asked this already and it was answered:
https://forum.doom9.org/showthread.p...08#post1854208
Groucho's Avisynth Stuff
Old 10th December 2018, 14:46   #6612  |  Link
imsrk48
imsrk48's Avatar
Yes sir thanks
Sent from my LG-M700 using Tapatalk
Old 11th December 2018, 16:17   #6613  |  Link
Zetti
MediaInfo v18.12 is released.
Old 12th December 2018, 15:13   #6614  |  Link
Statick
Having some very annoying crashes/problems in MeGUI x64
Everything was working a few weeks ago and I do not know what has changed or why it no longer works. I haven't knowingly installed anything new or changed any settings. I've tried updating to latest versions as well as restoring older versions from backups. I've tried 32-bit MeGUI and that works fine, but this will be slow and I only have 64-bit AviSynth and plugins installed (so it will take time to rebuild all that in 32-bit, and I will lose efficiency)
I'm encoding from a DVD rip (VOB files produced from DvdFab), and currently my AVS script is completely empty (just the MeGUI one-click generated default)
If I encode using x264 then it crashes upon starting the video encode with a 0xC0000005 STATUS_ACCESS_VIOLATION (it successfuly indexes, does the audio, etc, then crashes when it starts the video)
If I encode using x265 then it doesn't crash, but the video output is an entirely green screen
If I load the AVS file generated by one-click into the "input" tab, then the MeGUI preview window displays it perfectly, I can scroll through and play the video without problems. I do notice, however, that the preview has been de-interlaced, which shouldn't be happening (I don't have deinterlace selected anywhere as I plan to handle this in AVIsynth, which I'm currently not doing until I figure out what's causing the crashes, the source material is interlaced TV)
Any ideas?
Edit: I know installing MeGUI into Program Files isn't recommended, I've had it this way for years without problems though (I just deal with having a UAC prompt when I open it). I have tried copying the MeGUI folder out to my desktop and running it from there, and I still get the same results. I'm trying to encode to 10-bit x264 but I get the same results if I switch to 8-bit
global MeGUI_darx = 160
global MeGUI_dary = 117
LoadPlugin("C:\Program Files\MeGUI\tools\dgindex\DGDecode.dll")
DGDecode_mpeg2source("D:\video work\rips\TEST\VIDEO_TS\nucrwwa3.xay\TEST_VTS_01_1.d2v", info=3)
LoadPlugin("C:\Program Files\MeGUI\tools\avisynth_plugin\ColorMatrix.dll")
ColorMatrix(hints=true, threads=0)
#deinterlace
#crop
#resize
#denoise
Statick is offline   Reply With Quote
Old 12th December 2018, 15:38   #6615  |  Link
Statick
full log
[Error] Log
-[Information] Versions
--[Information] MeGUI: 2896 x64
--[Information] MeGUI Debug Data: available
--[Information] Update Check: development update server
--[Information] System Information
---[Information] Operating System: Windows 10 Pro 1803 x64 (10.0.17134.471)
---[Information] .NET Framework: 4.0 (4.0.0.0)
---[Information] .NET Framework: 4.7 (4.7.03056)
---[Information] Redistributables
----[Information] Microsoft Visual C++ 2008 x86:  9.0.21022
----[Information] Microsoft Visual C++ 2010 x64:  10.0.40219
----[Information] Microsoft Visual C++ 2010 x86:  10.0.40219
----[Information] Microsoft Visual C++ 2012 x64:  11.0.61030
----[Information] Microsoft Visual C++ 2012 x86:  11.0.61030
----[Information] Microsoft Visual C++ 2013 x64:  12.0.40660
----[Information] Microsoft Visual C++ 2013 x86:  12.0.40660
----[Information] Microsoft Visual C++ 2017 x64:  14.10.25008
----[Information] Microsoft Visual C++ 2017 x86:  14.10.25008
---[Information] DPI: 100% (96/96)
---[Information] Monitor 1
----[Information] Resolution: 1920x1080
----[Information] Primary Screen: True
--[Information] Component Information
---[Information] Haali Media Splitter: not installed
---[Information] Haali DSS2: not installed
---[Information] ICSharpCode.SharpZipLib: 0.85.5.452 (07-08-2008)
---[Information] MediaInfo: 18.05.0.0 (08-05-2018)
---[Information] SevenZipSharp: 0.64.3890.29348 (02-01-2011)
---[Information] 7z: 9.20 (18-11-2010)
--[Information] AviSynth Information
---[Information] AviSynth Wrapper
----[Information] Version: 1.0.2847.0
----[Information] Date: 06-05-2018
----[Information] Interface: 3
----[Information] File Version: 0.1
----[Information] File Date: 02-07-2018
----[Information] File Name: AviSynth+ 0.1 (r2728, MT, x86_64)
----[Information] File Path: c:\windows\system32\avisynth.dll
----[Information] AviSynth Version: AviSynth+ 0.1 (r2728, MT, x86_64)
----[Information] AviSynth+: true
----[Information] AviSynth MT: true
-[Information] Update detection
--[Information] [12/12/2018 14:35:23] Using cached update config and server: http://megui.org/auto/
--[Information] [12/12/2018 14:35:23] No package requires an update
-[Information] OneClick
--[Information] [12/12/2018 14:35:34] MediaInfo
---[Information] File: D:\video work\rips\TEST\VIDEO_TS\VTS_01_1.VOB
---[Information] DVD source detected. Using IFO file: D:\video work\rips\TEST\VIDEO_TS\VTS_01_0.IFO
---[Information] General
----[Information] Format: DVD Video
----[Information] FileSize: 63488
----[Information] PlayTime: 00:22:44.800
----[Information] PGCCount: 1
----[Information] PGCNumber: 1
---[Information] Video
----[Information] ID: 224
----[Information] Format: MPEG Video
----[Information] FormatVersion: Version 2
----[Information] Width: 720
----[Information] Height: 576
----[Information] FrameCount: 34120
----[Information] FrameRate: 25.000
----[Information] Duration: 00:22:44.800
----[Information] AspectRatio: 1.333
----[Information] AspectRatioString: 4:3
----[Information] PixelAspectRatio: 1.067
---[Information] Audio
----[Information] ID: 128 (0x80)
----[Information] Format: AC-3
----[Information] FormatInfo: Audio Coding 3
----[Information] SamplingRate: 48000
----[Information] SamplingRateString: 48.0 kHz
----[Information] Channels: 2
----[Information] ChannelsString: 2 channels
----[Information] Language: en
----[Information] LanguageString: English
----[Information] ID: 129 (0x81)
----[Information] Language: es
----[Information] LanguageString: Spanish
----[Information] ID: 130 (0x82)
----[Information] Language: fr
----[Information] LanguageString: French
----[Information] ID: 131 (0x83)
---[Information] Text
----[Information] StreamOrder: 0
----[Information] CodecID: Vobsub
----[Information] LanguageString: Danish
----[Information] StreamOrder: 1
----[Information] StreamOrder: 2
----[Information] LanguageString: Norwegian
----[Information] StreamOrder: 3
----[Information] LanguageString: Swedish
----[Information] StreamOrder: 4
----[Information] StreamOrder: 5
----[Information] StreamOrder: 6
----[Information] StreamOrder: 7
---[Information] Chapters
----[Information] 00:00:00.000: Chapter 1
----[Information] 00:02:42.720: Chapter 2
----[Information] 00:09:57.160: Chapter 3
----[Information] 00:17:41.760: Chapter 4
----[Information] 00:22:14.760: Chapter 5
--[Information] [12/12/2018 14:35:39] Video: D:\video work\rips\TEST\VIDEO_TS\VTS_01_1.VOB
--[Information] [12/12/2018 14:35:39] Audio: D:\video work\rips\TEST\VIDEO_TS\VTS_01_1.VOB ([80] - AC-3 - 2 channels / 48.0 kHz / English)
-[Information] Log for job1 (idx, VTS_01_1.VOB -> TEST_VTS_01_1.d2v)
--[Information] [12/12/2018 14:35:39] Started handling job
--[Information] [12/12/2018 14:35:39] Preprocessing
--[Information] [12/12/2018 14:35:39] Job command line: "C:\Program Files\MeGUI\tools\dgindex\dgindex.exe" -SD=< -AIF=<D:\video work\rips\TEST\VIDEO_TS\VTS_01_1.VOB< -OF=<D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\TEST_VTS_01_1< -FO=0 -exit -hide -OM=2
--[Information] [12/12/2018 14:35:40] Process started
--[Information] [12/12/2018 14:35:40] Standard output stream
--[Information] [12/12/2018 14:35:40] Standard error stream
--[Information] [12/12/2018 14:36:02] Running auto force film
---[Information] [12/12/2018 14:36:02] Film percentage: -1
--[Information] [12/12/2018 14:36:02] Postprocessing
---[Information] [12/12/2018 14:36:02] Deleting intermediate files
----[Information] [12/12/2018 14:36:02] Successfully deleted D:\video work\rips\TEST\VIDEO_TS\VTS_01_1.log
--[Information] [12/12/2018 14:36:02] Job completed
-[Information] Log for job2 (oneclick, VTS_01_1.VOB -> )
--[Information] [12/12/2018 14:36:02] Started handling job
--[Information] [12/12/2018 14:36:02] Preprocessing
--[Information] [12/12/2018 14:36:02] Processing thread started
--[Information] [12/12/2018 14:36:02] Desired size:
--[Information] [12/12/2018 14:36:02] Split size:
--[Information] [12/12/2018 14:36:03] Aspect ratio: 160:117 (1.368)
--[Information] [12/12/2018 14:36:03] Target device: Default
--[Information] [12/12/2018 14:36:04] Input resolution: 720x576
--[Information] [12/12/2018 14:36:04] Desired maximum width: 720
--[Information] [12/12/2018 14:36:04] Output resolution: 720x576
--[Information] [12/12/2018 14:36:04] Automatic deinterlacing: False
--[Information] [12/12/2018 14:36:04] Generated AviSynth script
---[NoImage] global MeGUI_darx = 160
---[NoImage] global MeGUI_dary = 117
---[NoImage] LoadPlugin("C:\Program Files\MeGUI\tools\dgindex\DGDecode.dll")
---[NoImage] DGDecode_mpeg2source("D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\TEST_VTS_01_1.d2v", info=3)
---[NoImage] LoadPlugin("C:\Program Files\MeGUI\tools\avisynth_plugin\ColorMatrix.dll")
---[NoImage] ColorMatrix(hints=true, threads=0)
---[NoImage] #deinterlace
---[NoImage] #crop
---[NoImage] #resize
---[NoImage] #denoise
--[Information] [12/12/2018 14:36:05] resolution: 720x576
--[Information] [12/12/2018 14:36:05] frame rate: 25/1
--[Information] [12/12/2018 14:36:05] frames: 34120
--[Information] [12/12/2018 14:36:05] length: 00:22:44.800
--[Information] [12/12/2018 14:36:05] aspect ratio: 160:117 (1.368)
--[Information] [12/12/2018 14:36:05] color space: YV12
--[Information] [12/12/2018 14:36:05] qpf file created: D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\TEST_VTS_01_1.qpf
--[Information] [12/12/2018 14:36:06] Eliminating duplicate filenames
---[Information] [12/12/2018 14:36:06] Video output file: D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\VTS_01_1_Video.264
---[Information] [12/12/2018 14:36:06] Muxed output file: D:\video work\output\TEST_VTS_01_1.mkv
---[Information] [12/12/2018 14:36:06] Encodable audio stream 0: D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\TEST_VTS_01_1 T80 2_0ch 192Kbps DELAY 0ms_audio.mp4
--[Information] [12/12/2018 14:36:06] Postprocessing
---[Information] [12/12/2018 14:36:06] Deleting intermediate files
--[Information] [12/12/2018 14:36:06] Job completed
-[Information] Log for job1 (audio, TEST_VTS_01_1 T80 2_0ch 192Kbps DELAY 0ms.ac3 -> TEST_VTS_01_1 T80 2_0ch 192Kbps DELAY 0ms_audio.mp4)
--[Information] [12/12/2018 14:36:06] Started handling job
--[Information] [12/12/2018 14:36:06] Preprocessing
--[Information] [12/12/2018 14:36:06] MediaInfo
---[Information] File: D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\TEST_VTS_01_1 T80 2_0ch 192Kbps DELAY 0ms.ac3
----[Information] FileSize: 32752896
----[Information] PlayTime: 00:22:44.704
----[Information] ChannelPositionsString2: 2/0/0
----[Information] BitRateMode: CBR
----[Information] [12/12/2018 14:36:06] The language information is not available for this track. The default MeGUI language has been selected.
--[Information] [12/12/2018 14:36:06] Trying to open the file with LWLibavAudioSource()
--[Information] [12/12/2018 14:36:07] Successfully opened the file with LWLibavAudioSource()
--[Information] [12/12/2018 14:36:08] AviSynth script
---[NoImage] LoadPlugin("C:\Program Files\MeGUI\tools\lsmash\LSMASHSource.dll")
---[NoImage] LWLibavAudioSource("D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\TEST_VTS_01_1 T80 2_0ch 192Kbps DELAY 0ms.ac3")
---[NoImage] # detected channels: 2
---[NoImage] # detected channel positions: 2/0/0
---[NoImage] return last
--[Information] [12/12/2018 14:36:08] Command line used: --ignorelength --threading -V 91 --no-delay - -o "{0}"
--[Information] [12/12/2018 14:36:08] AviSynth script environment opened
--[Information] [12/12/2018 14:36:09] Script loaded
--[Information] [12/12/2018 14:36:09] Output Decoder
---[Information] [12/12/2018 14:36:09] Channels: 2
---[Information] [12/12/2018 14:36:09] Bits per sample: 32
---[Information] [12/12/2018 14:36:09] Sample rate: 48000
--[Information] [12/12/2018 14:36:09] Job command line: C:\Program Files\MeGUI\tools\qaac\qaac.exe --ignorelength --threading -V 91 --no-delay - -o "D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\TEST_VTS_01_1 T80 2_0ch 192Kbps DELAY 0ms_audio.mp4"
--[Information] [12/12/2018 14:36:10] Process started
--[Information] [12/12/2018 14:36:10] Standard output stream
--[Information] [12/12/2018 14:36:10] Standard error stream
---[Information] [12/12/2018 14:36:10] qaac 2.67, CoreAudioToolbox 7.10.9.0
---[Information] [12/12/2018 14:36:10] TEST_VTS_01_1 T80 2_0ch 192Kbps DELAY 0ms_audio.mp4
---[Information] [12/12/2018 14:36:10] AAC-LC Encoder, TVBR q91, Quality 96
---[Information] [12/12/2018 14:36:30] 65505792/-1 samples processed in 0:20.030
---[Information] [12/12/2018 14:36:30] Overall bitrate: 129.614kbps
---[Information] [12/12/2018 14:36:30] Optimizing...done
--[Information] [12/12/2018 14:36:30] MediaInfo
---[Information] File: D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\TEST_VTS_01_1 T80 2_0ch 192Kbps DELAY 0ms_audio.mp4
----[Information] Format: MPEG-4
----[Information] FileSize: 22379667
----[Information] PlayTime: 00:22:44.715
----[Information] CodecID: mp4a-40-2
----[Information] Format: AAC
----[Information] FormatInfo: Advanced Audio Codec
----[Information] FormatProfile: LC
----[Information] BitRateMode: VBR
----[Information] [12/12/2018 14:36:30] The language information is not available for this track. The default MeGUI language has been selected.
--[Information] [12/12/2018 14:36:30] Postprocessing
---[Information] [12/12/2018 14:36:30] Deleting intermediate files
----[Information] [12/12/2018 14:36:30] Successfully deleted D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\TEST_VTS_01_1 T80 2_0ch 192Kbps DELAY 0ms.ac3.lwi
--[Information] [12/12/2018 14:36:30] Job completed
-[Error] Log for job6 (video, TEST_VTS_01_1.avs -> VTS_01_1_Video.264)
--[Information] [12/12/2018 14:36:30] Started handling job
--[Information] [12/12/2018 14:36:30] Preprocessing
--[Information] [12/12/2018 14:36:30] AviSynth input script
---[NoImage] #crop
--[Information] [12/12/2018 14:36:31] resolution: 720x576
--[Information] [12/12/2018 14:36:31] frame rate: 25/1
--[Information] [12/12/2018 14:36:31] frames: 34120
--[Information] [12/12/2018 14:36:31] length: 00:22:44.800
--[Information] [12/12/2018 14:36:31] aspect ratio (avs): 160:117 (1.368)
--[Information] [12/12/2018 14:36:31] color space: YV12
--[Information] [12/12/2018 14:36:31] Job command line: "C:\Program Files\MeGUI\tools\x264\x264.exe" --output-depth 10 --preset veryslow --tune grain --crf 18.0 --qpfile "D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\TEST_VTS_01_1.qpf" --sar 128:117 --frames 34120 --output "D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\VTS_01_1_Video.264" "D:\video work\rips\TEST\VIDEO_TS\0bloywow.vrw\TEST_VTS_01_1.avs"
--[Information] [12/12/2018 14:36:31] Process started
--[Information] [12/12/2018 14:36:31] Standard output stream
--[Information] [12/12/2018 14:36:31] Standard error stream
--[Error] [12/12/2018 14:36:37] Process exits with error: 0xC0000005 STATUS_ACCESS_VIOLATION (-1073741819)
--[Information] [12/12/2018 14:36:37] Job completed
Old 12th December 2018, 15:45   #6616  |  Link
If you could wrap the log in a (scrollable) CODE block, instead of QUOTE (or use an external "pastebin" service), that would be great.
Old 12th December 2018, 16:05   #6617  |  Link
sneaker_ger
/edit: ignore, "DGDecode_mpeg2source()" is the free variant
Is the DGDecode license ok?
https://forum.doom9.org/showthread.p...52#post1859452
Old 12th December 2018, 16:10   #6618  |  Link
Statick
I didn't know DGDecode needed a license (it just gets installed with MeGUI as needed) and I don't really know how to fix that? That thread suggests copying a "license.txt" file to the 64-bit plugins folder, but I cannot locate a license.txt file except for within the MeGUI/tools/ffmpeg folder (needless to say, copying that file to the plugins folder doesn't help)
Old 12th December 2018, 16:16   #6619  |  Link
zdzdz
Hello. I have a problem with setting the priority level of a worker. Before it was always Above Normal. I don't remember if it was possible to set it somewhere. But now it is always Low when worker starts.
It there a way to change the default value?
zdzdz is offline   Reply With Quote
Old 12th December 2018, 16:17   #6620  |  Link
sneaker_ger
It costs $15. http://rationalqm.us/dgdecnv/dgdecnv.html
Either you pay that or use a free alternative like DGMPGDec/mpeg2source/dgindex (same author as DGDecNV, just not maintained anymore and software instead of Nvidia CUVID). Is also included in MeGUI.
Though the missing license doesn't explain the x264 crash.
