Old 23rd August 2019, 18:41   #7001  |  Link
benwaggoner
Originally Posted by quietvoid View Post
I'm aware of x265's --dhdr10-opt, but I prefer to keep it the same as the source (which seems to always be for every frame).
Not sure if it would affect compatibility as well.
That's just the way the source gets generated. No need to put it on every frame for playback.
Ben Waggoner
My Compression Book
Old 24th August 2019, 11:48   #7002  |  Link
stax76
stax76's Avatar
Somebody reported an error, encoding finishes but returns exit code 1 at the end, has that a special meaning? What could be the reason?
CPU : AMD Ryzen 9 3900X 12-Core Processor
---------- Video encoding using x265 3.1+11-de920e0 Wolfberry ----------
"C:\Program Files (x86)\VapourSynth\core\vspipe.exe" K:\Downloads\SampleVideo_1280x720_1mb_temp\SampleVideo_1280x720_1mb.vpy - --y4m | C:\Users\Renor\Desktop\StaxRip\Apps\Encoders\x265\x265.exe --crf 20 --output-depth 12 --aq-mode 1 --frames 132 --y4m --output K:\Downloads\SampleVideo_1280x720_1mb_temp\SampleVideo_1280x720_1mb_out.hevc -
The system cannot find the path specified.
y4m [info]: 1280x720 fps 25/1 i420p8 frames 0 - 131 of 132
raw [info]: output file: K:\Downloads\SampleVideo_1280x720_1mb_temp\SampleVideo_1280x720_1mb_out.hevc
x265 [info]: HEVC encoder version 3.1+11-de920e0a3183
x265 [info]: build info [Windows][GCC 9.1.1][64 bit] 12bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AVX2
x265 [info]: Main 12 profile, Level-3.1 (Main tier)
x265 [info]: Thread pool created using 24 threads
x265 [info]: Slices : 1
x265 [info]: frame threads / pool features : 4 / wpp(12 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 1 inter / 1 intra
x265 [info]: ME / range / subpel / merge : hex / 57 / 2 / 3
x265 [info]: Keyframe min / max / scenecut / bias: 25 / 250 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt : 20 / 4 / 2
x265 [info]: b-pyramid / weightp / weightb : 1 / 1 / 0
x265 [info]: References / ref-limit cu / depth : 3 / off / on
x265 [info]: AQ: mode / str / qg-size / cu-tree : 1 / 1.0 / 32 / 1
x265 [info]: Rate Control / qCompress : CRF-20.0 / 0.60
x265 [info]: tools: rd=3 psy-rd=2.00 early-skip rskip signhide tmvp b-intra
x265 [info]: tools: strong-intra-smoothing lslices=4 deblock sao
Output 132 frames in 1.92 seconds (68.61 fps)
x265 [info]: frame I: 1, Avg QP:20.28 kb/s: 21838.80
x265 [info]: frame P: 31, Avg QP:20.75 kb/s: 4661.11
x265 [info]: frame B: 100, Avg QP:27.32 kb/s: 311.44
x265 [info]: Weighted P-Frames: Y:0.0% UV:0.0%
x265 [info]: consecutive B-frames: 3.1% 9.4% 3.1% 40.6% 43.8%
encoded 132 frames in 2.28s (57.92 fps), 1496.04 kb/s, Avg QP:25.73
------- Error Video encoding using x265 3.1+11-de920e0 Wolfberry -------
Video encoding using x265 3.1+11-de920e0 Wolfberry failed with exit code: 1 (0x1)
The exit code might be a system error code: STATUS_WAIT_1
The exit code might be a system error code: Incorrect function.
Old 24th August 2019, 20:08   #7003  |  Link
stax76
stax76's Avatar
The issue was solved:
https://forum.doom9.org/showthread.p...20#post1883020
Old 31st August 2019, 00:42   #7004  |  Link
markiemarcus
Regarding RDOQ, am I the only one who really doesn't like the look of it? Though it's effective at maintaining grain motion, it seems to make it awfully boxy. I realise that this is subjective, but I find the results from disabling RDOQ entirely (--rdoq-level 0 --psy-rdoq 0) and increasing Psy-rd (to anywhere between 2.5 to 3.5) to be consistently more pleasing, assuming the same bitrate. Especially in grainy animation. The only explanation I can come up with for this comes from the documentation: that underlying flat colours reveal the shortcomings of RDOQ "biasing towards energy in general" as opposed to "energy in the source". On live action it seems okay, but I've found a number of instances in animation where anything other than tiny amounts can be quite ugly and make a right mess of fine grain or dither, regardless of the bitrate.
My apologies if that sounds overly negative; I realise that there are folks here who know a lot more than I do. Perhaps I'm missing something? Outside of a few difficulties with deep reds, this is really the only head-scratcher I've run into with x265. The only thing I long for is a way to control the strength of SAO. I like it, but sometimes I think half as much or even less would do.
markiemarcus is offline   Reply With Quote
Old 4th September 2019, 16:39   #7005  |  Link
Barough
Barough's Avatar
x265 v3.1+14-f08461fdae33 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.2.0)
Old 5th September 2019, 06:49   #7006  |  Link
filler56789
SuperVirus
filler56789's Avatar
Regarding v3.1+14-f08461fdae33...
sadly the compiler warnings are back — for example,
D:/KOMPILES/MCW/x265/source/encoder/analysis.cpp:2498:54: warning: this statement may fall through [-Wimplicit-fallthrough=]
 2498 |                                 case 3: mvpSelect[2] = mode.amvpCand[list][ref][!(mode.cu.m_mvpIdx[list][pu.puAbsPartIdx])];
D:/KOMPILES/MCW/x265/source/encoder/analysis.cpp:2499:33: note: here
 2499 |                                 case 2: mvpSelect[1] = mvp;
[ 77%] Building CXX object encoder/CMakeFiles/encoder.dir/search.cpp.obj
D:/KOMPILES/MCW/x265/source/encoder/search.cpp: In member function 'void x265_12bit::Search::predInterSearch(x265_12bit::Mode&, const x265_12bit::CUGeom&, bool, uint32_t*)':
D:/KOMPILES/MCW/x265/source/encoder/search.cpp:2276:42: warning: this statement may fall through [-Wimplicit-fallthrough=]
 2276 |                             mvpIdxSel[2] = !mvpIdx;
D:/KOMPILES/MCW/x265/source/encoder/search.cpp:2277:21: note: here
 2277 |                     case 2: mvpSel[1] = interMode.amvpCand[list][ref][mvpIdx];
D:/KOMPILES/MCW/x265/source/encoder/search.cpp:2278:42: warning: this statement may fall through [-Wimplicit-fallthrough=]
 2278 |                             mvpIdxSel[1] = mvpIdx;
D:/KOMPILES/MCW/x265/source/encoder/search.cpp:2279:21: note: here
 2279 |                     case 1: mvpSel[0] = interDataCTU->mv[list][cuIdx + puIdx].word;
And last but not least (since I-don't-know-when, really):
-- cmake version 3.15.2
CMake Deprecation Warning at CMakeLists.txt:10 (cmake_policy):
  The OLD behavior for policy CMP0025 will be removed from a future version
  of CMake.
  The cmake-policies(7) manual explains that the OLD behaviors of all
  policies are deprecated and that a policy should be set to OLD only under
  specific short-term circumstances.  Projects should be ported to the NEW
  behavior and not rely on setting a policy to OLD.
CMake Deprecation Warning at CMakeLists.txt:16 (cmake_policy):
  The OLD behavior for policy CMP0054 will be removed from a future version
  of CMake.
Old 5th September 2019, 07:06   #7007  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I'd expect there's be a lot of convergence at high bitrates. I'm most interested in how the different modes do when they don't have enough bits to do it right.
I'm also replicating the procedure from my encoding challenge, for apples-to-apples
https://forum.doom9.org/showthread.php?t=175776
Do you have any results from this aq-mode comparison? It would be interesting to know if mode 4 has any useful real-world applications. Of course, HDR encodes are a different story then.
Old 5th September 2019, 07:28   #7008  |  Link
@filler56789 - I do not remember anymore when I mentioned "deprecated CMake policies" to the developer mailing list ... could be more than a year ago already. They are still supported, and I can only hope that abandoning them won't break it for long.
Old 10th September 2019, 17:00   #7009  |  Link
benwaggoner
I encoded them and then went on vacation and forgot to look at them !
I'll try to mux and upload before I head to IBC.
Ben Waggoner
My Compression Book
Old 11th September 2019, 07:44   #7010  |  Link
Just a side note:
Recently I found archives of images stored in BPG format (Better Portable Graphics), a variant of HEIF. Trying to view them, I found that some famous Windows image viewers don't support it well, partially due to license doubts (IrfanView). For XnView I found a plugin which substitutes the partial support (bpgdec) by basic support via an encoder using x265, but it is not easily configurable (only via configuration file, globally). Web browsers can display BPG images via a JavaScript decoder for the HTML5 Canvas, written by the format author Fabrice Bellard.
The decoders I found so far are not very optimized, especially not multithreaded. Decoding a 150 MPx image takes several seconds. (You will probably guess well if you ask yourself who owns one of such 50K$ cameras...)
Old 11th September 2019, 19:01   #7011  |  Link
benwaggoner
Just a side note:
It should be straightforward to write a version that would hand off the frame to system-level decoders from Edge and Safari. That'd be HW in most cases, but a well optimized assembly decoder is going to be faster than JS by a lot too.
Chrome and Firefox have been hard-coded to explicitly not pass through HEVC streams to the system decoders, although they do so for H.264. It'd be a trivial tweak to Chromium to re-enable that.
Ben Waggoner
My Compression Book
Old 12th September 2019, 13:12   #7012  |  Link
I also mean the decoding speed in separate image viewers. Especially sad for IrfanView, which used to be among the fastest for several formats, but is afraid of license trouble when implementing a HEIF decoder. (Or is it the encoder part, to implement the support only wholesome or not at all?)
Has libavcodec a multi-threaded HEVC decoder? I believe so...
Old 13th September 2019, 05:26   #7013  |  Link
suarsg
Originally Posted by Wolfberry View Post
x265-3.1+11-de920e0-win64-static-multilib
x265 [info]: build info [Windows][GCC 9.2.1][64 bit] 8bit+10bit+12bit
x265 [info]: (libavcodec  58.55.101)
x265 [info]: (libavformat 58.31.104)
x265 [info]: (libavutil   56.33.100)
x265 [info]: (lsmash       2.16.1)
Added a new option --lavf to force the use of lavf demuxer regardless of file extension, but this option has no effect on Y4M files.
x265-3.1+11-de920e0-win64-static-multilib+svt (linked with SVT-HEVC, bigger file size)
Hello Wolfberry,
Did you change the order of the printed parameters in x265_param2string()? The "Encoding settings"-field in the produced metadata header from your binary is in a completely different order than what is the default on x265. It's really weird to see that when you're used to certain parameters being in a particular place. Can't say I'm a fan of this "customization".
suarsg is offline   Reply With Quote
Old 13th September 2019, 11:10   #7014  |  Link
Originally Posted by suarsg View Post
Hello Wolfberry,
Yes he did. Use builds from user barough
Old 13th September 2019, 11:31   #7015  |  Link
Barough
Barough's Avatar
x265 v3.1+19-c4b098f973e6 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.2.0)
Old 14th September 2019, 11:40   #7016  |  Link
redbtn
redbtn's Avatar
What about new option --selective-sao? Anybody knows should i disable it, like --no-sao earlier?
https://bitbucket.org/multicoreware/...f47?at=default
redbtn is offline   Reply With Quote
Old 14th September 2019, 20:31   #7017  |  Link
quietvoid
Yes, --selective-sao 4 (default) enables --sao even if you have --no-sao.
You can disable it all with --selective-sao 0 --no-sao
Old 15th September 2019, 09:29   #7018  |  Link
Selur
Selur's Avatar
The confusing part is that
a. just using '--no-sao' doesn't disable SAO, you get
[warning]: SAO turned ON when selective-sao is ON
so to turn sao off you need to use '--selective-sao 0 --no-sao' ,'--no-sao' or '--selective-sao' on it's own isn't enough.
b. With 'selective-sao' is described as 'Disable SAO for all slices', what is SAO used on if you use '--selective-sao 0 --sao' ?
looking at the code:
if (!!m_param->selectiveSAO)
    Slice* slice = frameEnc->m_encData->m_slice;
    slice->m_bUseSao = curEncoder->m_frameFilter.m_useSao = 1;
    switch (m_param->selectiveSAO)
    case 3: if (!IS_REFERENCED(frameEnc))
                slice->m_bUseSao = curEncoder->m_frameFilter.m_useSao = 0;
            break;
    case 2: if (!!m_param->bframes && slice->m_sliceType == B_SLICE)
            break;
    case 1: if (slice->m_sliceType != I_SLICE)
            break;
else
here are a few conclusions:
  • '--selective-sao 0 --sao' and '--selective-sao 4 --sao' and '--selective-sao 4 --no-sao' all do the same thing, they do the same as the old '--sao' (should be no surprise this causes confusion)
  • only '--selective-sao 0 --no-sao' disabled SAO
  • '--selective-sao X' with X > 0
  • man, that is a fugly coding style
Cu Selur
Old 15th September 2019, 14:18   #7019  |  Link
Boulder
Pig on the wing
Boulder's Avatar
--no-sao should definitely mean switching SAO off completely. It's ridiculous to add some other parameter affecting the choice.
Old 15th September 2019, 21:57   #7020  |  Link
redbtn
redbtn's Avatar
Another issue with selective-sao is no space between rd and selective-sao
MediaInfo shows rd=4selective-sao=0
I don't know how propertly create issue on bitbucket.
Hex Editor:
