6th September 2015, 15:41 | #2821 | Link |
Hi Nordo,
to be able to help you, please post your AVStoDVD log file and make a screen shot of the filter graph and also post it here... Using the latest AVStoDVD version is also a good idea. Cheers manolito |
7th September 2015, 02:11 | #2822 | Link |
Hi Manolito
Filter graph and file log below:- http://s276.photobucket.com/user/Aus...tml?sort=3&o=1 http://s276.photobucket.com/user/Aus...tml?sort=3&o=0 Hope I've added them correctly. |
7th September 2015, 03:25 | #2823 | Link |
Your filter graph is correct, but the log file is a little short. The whole AVStoDVD log file is needed.
You should update AVStoDVD to the latest version. Also AviSynth should be updated to version 2.60 and LAV Filters to version 0.65. And generally you cannot discuss torrent downloads at Doom9. Cheers manolito |
7th September 2015, 08:29 | #2824 | Link |
Thanks Manolito
I was trying not to be too explicite with what I was doing. Regarding the log file, how and where do I capture the whole file? I tried searching through this thread and other places but could find any instructions. Cheers |
7th September 2015, 12:19 | #2825 | Link |
After a conversion the log file will be in your output folder. If the DVD title is "DVD" (the default) then the log file will have the name "DVD.log".
This is a regular text file. Open it with Notepad, copy and paste the whole content into your post. For better readability you can "quote" the log content. Or you can upload the log file to a file hoster like SendSpace or Zippyshare and post just the link. Cheers manolito |
8th September 2015, 03:26 | #2826 | Link |
Thanks Manolito
File log below. <6/09/2015 2:24:51 AM> START PROCESS <> <6/09/2015 2:24:51 AM> PROJECT SETTINGS DVD Video Standard: PAL DVD Titles number: 1 DVD Size: 4450/4450 MB (100%) DVD Output Setup: DVD Folder DVD Label: DVD DVD Menu: No Menu Output Folder: H:\Main Movie\Self Less Delete Temp Assets Files: Yes Delete Temp Working Files: Yes Edit Command Parameters: No Post Process Task: Close all applications and shutdown system PREFERENCES MultiThread: 1 AVS Video Source Filter: FFMpegSource AVS Audio Source Filter: FFMpegSource AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize Frame Adjust Strategy: 0 PAL SpeedUp: 0 NTSC SlowDown: 0 Video Resolution: 1 Video BitRate Min: 2500 Video BitRate Level 1: 6500 Video Profile Level 2: 4500 Video BitRate Max: 8500 Keep DVD Compliant Video: 1 AC3 Audio Encoder: 3 Force FFmpeg for Long Audio: 1 DVD Audio Format: 0 DVD Audio BitRate: 192 Keep DVD Compliant Audio: 1 Normalize Audio: 0 Auto Delay Audio: 1 DVD Audio Language (Primary): EN - English DVD Audio Language (Secondary): EN - English DVD Subs Language (Primary): EN - English DVD Subs Language (Secondary): EN - English DVD Subs Font: Tahoma 16pt (255,255,255) Chapters Interval: 5 Use Source Chapters: 1 DVD Burning Drive: G: ATAPI iHAS324 B AL1B DVD Burning Speed: 8x Auto Erase DVD RW: 1 Unload ActiveMovie library: 1 Adjust DirectShow Filters at runtime: 1 Save General Settings: 1 SYSTEM INFO Processor Name: AMD Phenom(tm) II X4 965 Processor Operating System: Windows 7 Service Pack 1 (64 bit) Current user is Admin: NO Available Output Disc Space: 0 GB AviSynth is installed: YES (release 2.5.8) LAV Filters is installed: YES (release 0.64.0) ffdshow is installed: NO <> <6/09/2015 2:24:51 AM> TITLE 1 SOURCE FILES Video: H:\My Downloads\TORRENTS\Self Less\Self.less.2015.BRRip.XviD-ETRG\Self.less.2015.BRRip.XviD-ETRG.avi Info: XviD - 751 kbps - 640x352 - DAR 1.818 - 25 fps - Progressive - 1:52:12 hours - 168301 frames Audio 1: H:\My Downloads\TORRENTS\Self Less\Self.less.2015.BRRip.XviD-ETRG\Self.less.2015.BRRip.XviD-ETRG.avi Info: MPEG-1 Audio layer 3 - 112 kbps - CBR - 2 ch - 44100 Hz - 1:52:12 hours (0 ms delay) [MediaInfoLib - v0.7.69] <> <6/09/2015 2:24:51 AM> AVISYNTH SCRIPT LoadPlugin("H:\Program Files (x86)\AVStoDVD\Lib\ffms2.dll") # Audio is frameserved by AviSynth just for Preview and Edit purposes. Audio = FFAudioSource("H:\My Downloads\TORRENTS\Self Less\Self.less.2015.BRRip.XviD-ETRG\Self.less.2015.BRRip.XviD-ETRG.avi", track=1) Video = FFVideoSource("H:\My Downloads\TORRENTS\Self Less\Self.less.2015.BRRip.XviD-ETRG\Self.less.2015.BRRip.XviD-ETRG.avi", track=-1, seekmode=0) Video = Video.ConvertToYV12() Video = Video.AddBorders(0,4,0,4) Video = Video.Lanczos4Resize(720,576) Audio = Audio.SSRC(48000) AudioDub(Video, Audio) <> <6/09/2015 2:24:51 AM> START VIDEO ENCODING OPERATIONS Encoding Profile: HCenc VBR 2-pass Target Video FileSize: 4189.9 MB Encoding Parameters: -ini "C:\Users\John\AppData\Local\Temp\DVD_Self.less.2015.BRRip.XviD-ETRG.HCenc.ini" HCenc ini file: *INFILE C:\Users\John\AppData\Local\Temp\DVD_Self.less.2015.BRRip.XviD-ETRG_1.avs *AVSRELOAD *OUTFILE H:\Main Movie\DVD_Self.less.2015.BRRip.XviD-ETRG.m2v *LOGFILE C:\Users\John\AppData\Local\Temp\DVD_Self.less.2015.BRRip.XviD-ETRG.HCenc.log *MAXBITRATE 9000 *BITRATE 5221 *PROFILE BEST *ASPECT 16:9 *PROGRESSIVE *TFF *BIAS 50 *DC_PREC 9 *MATRIX MPEG *AQ 1 *LUMGAIN 1 *SMP *PRIORITY HIGH *DBPATH C:\Users\John\AppData\Local\Temp *WAIT 2 <> <6/09/2015 2:25:28 AM> Log file created by AVStoDVD Release 2.8.1 <> |
15th September 2015, 19:23 | #2829 | Link |
DVD is NOT dead
A little bit OT, but it should be a bit of additional motivation for folks like MrC and others who still engage in writing software to create and modify DVDs:
http://i.imgur.com/2ph5wgR.jpg DVD sales are still more than twice as high as BluRay sales. The tendency on this forum to look at the DVD as an obsolete technology is not justfied... Cheers manolito Last edited by manolito; 15th September 2015 at 19:30. |
15th September 2015, 22:27 | #2831 | Link |
VoD stands for Video on Demand
Cheers //EDIT// Forgot to mention that the data are just for Germany, source is the GfK (Gesellschaft für Konsumforschung), a very reliable source. Last edited by manolito; 15th September 2015 at 22:43. |
17th September 2015, 21:42 | #2832 | Link |
AVStoDVD Dev
AVStoDVD release 2.8.3 final is available to download.
Change log: - Some bugs fixed - Added 'Open Project Log file' option in main window menu 'View'/'Operations Log' - Added 'Video FrameRated Mode' option in main window menu 'Title'/'Edit Source Title Info' - Added 'A2D Projects Path' option in 'Preferences'/'Paths' - Added 'Spline36Rezize' value to 'AVS Up/DownSize Filter' options in 'Preferences'/'AviSynth' - Added 'Display Info' option in 'Edit Title'/'AviSynth' - Added 'fpsnum' and 'fpsden' flags to FFmpegSource calls when source video is not CFR - Added '-readtoeof 1' command to Aften CL when wave input is potentially over 4 GB - Added '/FILESYSTEM "ISO9660 + UDF" /UDFREVISION "1.02"' switches to ImgBurn command line - Added a warning message in 'Quick Startup Tutorial' if H.264/AVS or AAC are decoded by MS DirectShow Filters - Added AviSynth library 'Upmix.avsi' (thanks to tebasuna51 and manolito) - Added possibility to upmix audio sources from Stereo to pseudo-Surround (5.0 and 5.1) - Improved audio channels downmix management ('Downmix.avsi' functions are always called when dowmnmix is required) - Improved handling of VFR sources - Updated A2DSource.avsi to handle FrameRateNum and FrameRateDen as input parameters to A2DVideoSource() - Updated SRT ReSync routine to handle constant shift times (i.e. when AviSynth Trim is activated) - Updated .style file generation routine to support MicroDVD format for hard-encoded subtitles font customization - Updated AviSynth warning at startup if currently installed release is below 2.6.0 - AVSMeter updated to release 2.0.6 (changed ConUseSTDOUT=1 in AVSMeter.ini) - Improved log activity Bye |
18th September 2015, 00:03 | #2833 | Link | |
Thanks a lot for the new version, works like a charm...
This new feature Quote:
http://www39.zippyshare.com/v/ojgGwzb1/file.html Main changes: The SoX based upmix routines now integrate into AVStoDVD in a fully transparent way BS1770Gain updated to the current version 0.47 Several bug fixes Cheers manolito Last edited by manolito; 18th September 2015 at 16:46. |
18th September 2015, 00:40 | #2834 | Link |
FFMpegSource and HEVC (H.265) source files
ffms2 v. 2.17 which comes with AVStoDVD cannot decode HEVC source files. To handle these sources you have to update ffms2. You can either use the official Myrsloik builds at GitHub, or the C-plugin builds by qyot27. The official builds should work right out of the box (I could not test them because they won't run on my old CPU). The C-plugin builds can also be used transparently by AVStoDVD, but it requires a little tweaking. BTW you find the latest build here: http://forum.doom9.org/showthread.ph...37#post1739037 If anyone is interested in using a qyot27 build, let me know... Cheers manolito |
18th September 2015, 09:22 | #2837 | Link |
@SuLyMaN
Please be patient... This subs autoloading feature still needs some refinements (and further testing from the side of the BatchMux middleware) before its introduction into one alpha or beta release of AVS2DVD... I am working on this - as reported in the thread freshly created on the restart of the BatchMux development. In the next hours there will be a consolidation of the BM test cases... And some other news... Even if the subject addresses mostly MrC, I will keep all users and interested people well informed and updated on the matter... Cheers SD |
