26th August 2014, 01:18 | #7901 | Link |
I cannot get the movie to play properly, and even after updating most of the executables in the tools subfolder I still get avs4x264.exe has stopped working when trying to transcode them. Anyone got an idea on how to fix that?
26th August 2014, 07:33 | #7902 | Link | |
Your problem should be solved by ensuring the videos are BD-compliant.
Born in the USB (not USA) |
26th August 2014, 10:36 | #7903 | Link | |
26th August 2014, 16:54 | #7904 | Link |
25p is not supposed to be BD compliant but actually it generally works.
I'm not sure it is a really good idea because I changed TSmuxer by curiosity and the resulting AVCHD was not playable, while the same project worked with the old TSmuxer version installed by multiAVCHD. |
30th August 2014, 19:59 | #7907 | Link |
Anybody know how to add multiple avchd folders to a flash drive so they will properly play on ps3?
Typically I just author multiple titles together with multiavchd and copy the avchd folder to the root of the flash drive.. My question is about adding new avchd folders periodically with the previous folders still on the drive. Is there a numbering sequence that will work? Thanks. |
29th September 2014, 23:32 | #7908 | Link |
This tool works great on my Win 7 64bit Desktop but just installed it onto a new Thinkpad laptop with same OS.. After loading a 720p.ts file it takes forever to go to properties. It creates a .ffindex file before it will proceed..
I have the same k-lite codecs installed as the desktop and multitest passes.. Any ideas on how to skip the indexing step? EDIT- Ok, I unchecked 'Use FFms2 instead of Directshow' and it seems to have fixed it.. To all of you who know more about this than I do - Is that the solution? Last edited by nikknightt; 29th September 2014 at 23:42. |
4th October 2014, 10:48 | #7909 | Link |
ffms2 always indexes video before opening it. DirectShow doesn't. ffms2 should be frame accurate. DirectShow tends not to be (when navigating back and forward in a video etc). If you're encoding a video from start to finish, DirectShow should be fine. Maybe the indexing process takes longer when using a laptop as it has a slower hard drive than the desktop?
Keep in mind if you have any of ffdshow's video filters enabled (I'm assuming you have ffdshow installed... I can't remember whether it's still included in K-Lite) they can effect the video decoding. Assuming ffdshow is decoding. For example, if you enable the ffdshow picture properties filter and adjust the contrast or brightness etc, it'll be adjusted when you re-encode also. I've done that many times in the past..... encoded video before realising I hadn't disabled ffdshow's filtering first. Of course if you never enable ffdshow's filters, or LAV or another DirectShow codec is doing the decoding, it won't be an issue. |
21st November 2014, 21:38 | #7910 | Link |
Sigh, did a fresh Windows install and now eac3to inside multiavchd won't encode audio in any way. I take that back, if it does decide to encode any audio it drops any 5.1 DTS or AC3 track down to 128kbps. It won't do anything at all with DTS-HD or TrueHD, all conversions just fail and will only mux in the audio untouched. Any audio files in mkv container have never really worked to begin with if I wanted to transcode the audio. Most files I have to mux into m2ts so the audio is recognized and then add in chapter file separately. Even in an m2ts container I cannot get eac3to to do anything with my audio other than downconvert it to AC3 @ 128kbps?
Any idea what's going on? I have installed ffdshow, avisynth, and haali just like always and still no joy. Right now I just have LAV filters installed and I can still encode a video but can't doing anything with audio so I do that separately in audiomuxer, which is a pain. |
22nd November 2014, 04:54 | #7912 | Link | |
Did I just complicate it even more? |
22nd November 2014, 22:25 | #7914 | Link |
Yes, I do realize this. It's just irritating because I had it all working before and now it's not. I wish the program would get updated but it does not look like that's going to happen, and that's very unfortunate as it is a fantastic program when it works correctly.
23rd November 2014, 20:42 | #7915 | Link | |
10th December 2014, 10:46 | #7917 | Link |
IIRC, he said 2 or 3 years ago that he was involving in another project.
Here is his website ; http://deanbg.com/ |
10th February 2015, 14:49 | #7920 | Link |
Strange behaviout for multiavchd
Hello,
I use multiavchd for a long time. Suddenly I noticed something strange. Although I see on main menu preview the buttons (box with colors), when I play my final AVCHD disk (folder from PC) I see an arrow at the same color and I have no pop up menu (even though I choose it from the beggining of my project). Few days ago, I didn't have any problem. Has anyone else the same problem or might know what cause it? (I install it to another PC and I have the same result) |
