Old 8th October 2014, 16:28   #361  |  Link
TOM_SK
Great, thank you very much!
TOM_SK is offline   Reply With Quote
Old 28th October 2014, 20:17   #362  |  Link
Dextor41
Hi, few issues with the latest version - 098:
1) Got an error:
[2014-10-28 19:30:57] Done video encoding with x264
ffms [info]: 696x480p 10:11 @ 3475/143 fps (cfr)
resize [error]: invalid sar `1.3:1.3'
mp4 [error]: failed to finish movie.
x264 commandline generated by TX264: --crf 21 --profile baseline --level 3.1 --preset veryslow --tune film --force-cfr --fps 23.976 --video-filter resize:width=640,height=480,sar=1.3:1.3,method=bicubic --output "<Temporary file>" "<Input file>"
The input video is a MKV, MPEG4 Video (H264) 696x480 (29:22) with DAR 4:3 and AC3 audio, subtitles and chapters
EDIT: the error went away after I disabled the option to set DAR in TX264. By mistake I enabled the option and set it to 4:3 not noticing the original already had that DAR.
2) I personally do not like that the stats that TX264 shows when encoding do not have any titles/description
Dextor41 is offline   Reply With Quote
Old 16th January 2015, 20:24   #363  |  Link
XanaMuui
Thanks for the new version!
The deconding of WMV files is working now.
Just out of curiosity, why did you removed the skins?
XanaMuui is offline   Reply With Quote
Old 16th November 2015, 13:26   #364  |  Link
Dogway
This thing no longer works with avisynth right (avs 2.6):
[16/11/2015 12:25:34] Done video encoding with x264
avs [error]: Avisynth: access violation at 0x0007A9C1 in C:\Windows\system32\avisynth.DLL,
attempting to read from 0x01210168
x264 [error]: could not open input file `E:\Nuevo AviSynth Script (2) - copia.avs'
faac, mkv, mp4, neroaacenc, x264
