Old 16th March 2018, 23:29   #501  |  Link
No, I could only agree: I would expect multi-threaded processing of frames, possibly in a slices or wavefront partition technology. (AFAIR, AV1 still uses small macroblock-like windows, just more overlapping to neighborhoods...)
Old 17th March 2018, 03:41   #502  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
I don't think anyone but the developers know what half the options mean or do, though some expected values are in the code. You might try --cpu-used=8, which is supposed to max out the processing power.
Actually don't bother, that argument does nothing, they nerfed it without removing the option. Hm. Maybe pthreads isn't detected correctly? OK, tracing the code, you have to have more than one tile-column to get more than one thread; threading is tile-based only. You'd think default would equal threads, but...?
Old 17th March 2018, 06:01   #503  |  Link
Tommy Carrot
Tommy Carrot's Avatar
--cpu-used is actually the speed/quality slider, it has nothing to do with threading, they just named it stupidly. The lower it is, the more additional tools and searches are enabled, so 0 is the highest quality, but ridiculously slow, and 8 is the "fastest", but lowest quality.
Tommy Carrot is offline   Reply With Quote
Old 17th March 2018, 12:58   #504  |  Link
colinhunt
This cmdline
ffmpeg -i moto--x264-8bit-420-1080p2400fps-468frames.mp4 -strict -1 -f yuv4mpegpipe - | aomenc -w 1920 -h 1080 -v --fps=24000/1000 --cpu-used=8 --dev-sf=255 --tile-columns=6 --limit=48 --i420 -t 24 -b 8 --input-bit-depth=8 --end-usage=cbr --target-bitrate=1024 -p 1 --webm --num-tile-groups=32 -o aomout.webm -
resulted in aomenc running 15 threads and cpu load bouncing around between 4 and 20 percent. Encoding 48 frames took approx. 10 minutes.
Old 17th March 2018, 14:54   #505  |  Link
IMHO, aomenc (and vpxenc the same way) will need a lot of simplification regarding sane defaults and relations between parameters to become user friendly... balancing the presets (and "everything default" equals to the "medium" preset) for x264 and x265 took quite an important part of their development efforts.
Old 17th March 2018, 17:05   #506  |  Link
colinhunt
Source: 1080p24 8bit 4:2:0 468 frames (19.5 seconds)
cmdline: ffmpeg -i moto--x264-8bit-420-1080p2400fps-468frames.mp4 -strict -1 -f yuv4mpegpipe - | aomenc -w 1920 -h 1080 -v --fps=24000/1000 --cpu-used=4 --tile-columns=6 --i420 -t 14 -b 8 --input-bit-depth=8 --end-usage=vbr --target-bitrate=1024 -p 1 --webm -o aomout.webm -
Encoding took 74 minutes, running on 14 threads. Output has a reported (mediainfo) bitrate of 1047 kbps. Oddly enough framerate is reported as 24.025 fps.
Old 17th March 2018, 17:37   #507  |  Link
Maybe aomenc doesn't count the duration of the very last frame, only the gaps between all of them.
Old 17th March 2018, 17:44   #508  |  Link
colinhunt
You mean that framerate? That number is from Mediainfo.
Old 17th March 2018, 17:50   #509  |  Link
Hmm, yes, it looks a bit like "duration / (framecount-1)". So, maybe the opposite way, aomenc counted the duration of the last frame, MediaInfo instead assumes it does not count.
Old 17th March 2018, 22:54   #510  |  Link
colinhunt
I encoded the same 1080p24 8bit 4:2:0 source on aomenc 0.1.0-8449-g6471e8bd7 twice, first with --cpu-used=4 and then with --cpu-used=2. Target bitrate was set for 1024 kbps. Below are the 3SSIM Metric graphs for both encodes.
--cpu-used=4 (green) took 4440 seconds to encode, while --cpu-used=2 (red) took 9060 seconds.
Old 20th March 2018, 17:32   #511  |  Link
bstrobl
IETF 101: https://www.youtube.com/watch?v=qS7hfrFWeic
Spec is somewhat "frozen", so only bugfixes left.
bstrobl is offline   Reply With Quote
Old 20th March 2018, 19:15   #512  |  Link
iwod
And for anyone that has not been following it, it has been somewhat "Frozen" for nearly 6 months.
As said in the video, there are still crap loads of things going on under the hood. That is not necessarily a bad thing, they are taking the time to properly finish it.
But I have slightly less confident given how they have handle it, I hope they release a preview or beta to the industry before going final.
iwod is offline   Reply With Quote
Old 20th March 2018, 19:20   #513  |  Link
The part of the industry that cares is involved in the development already, so whats left?
Old 20th March 2018, 19:21   #514  |  Link
bstrobl
The interesting part about the xvc presentation is that this is basically the current state of JVET/JEM, along with its current bitrate performance that ISO/ITU and co. have managed to achieve.
Obviously there is no way in hell Divideon is getting away with basically a direct rip of JVET, so if xvc gains any commercial ground whatsoever it will simply get sued into oblivion or into updating and making a poor codec. Might as well use VP9/AV1 in that case, especially if no old files become incompatible. The best they can hope for is to basically become a replacement for MPEG LA, but I don't see any lists where they have gained any companies as licensors.
Old 20th March 2018, 21:27   #515  |  Link
hajj_3
They should just try and sell their patents to google/Netflix for a few million dollars and get google/Netflix to donate the patents to IETF to be used in AV2.
P.S mediainfo 18.03 has just been released that can detect AV1 files: http://mediaarea.net/en/MediaInfo
Old 23rd March 2018, 13:13   #516  |  Link
leonccyiu
https://www.golem.de/news/videocodec...03-133457.html
According to this German article, the bitstream has been frozen with just a few bugs to work out.
I hope that hardware decoders can come a lot sooner than we expect, and that nvidia and arm have already been working on them.
leonccyiu is offline   Reply With Quote
Old 23rd March 2018, 15:35   #517  |  Link
hajj_3
The article just talks about the conference video that was posted a few days ago. I am more bothered about intel and amd apus getting AV1 hardware decoders quickly than nvidia gpus.
Old 24th March 2018, 11:52   #518  |  Link
easyfab
some tests with foreman clip @250kbit/s on my i7-2600k:
x264 - core 155 r2901 7d0ff22
preset : placebo
real bitrate 263 kb/s size 321 KiB
time : pass 1 : 1s pass 2 : 9s total time : 10 s
metrics :
SSIM All:0.948739 (12.902161)
PSNR average:36.585589
VMAF score = 93.379718
x265 - 2.7+3-9086c8a3e76d:[Windows][GCC 7.3.0][64 bit] 8bit+10bit+12bit
preset : veryslow
real bitrate 254 kb/s size 311 KiB
time : pass 1 : 39s pass 2 : 39s total time : 78 s
metrics :
SSIM All:0.952898 (13.269586)
PSNR average:37.447079
VMAF score = 95.024192
libvpx-vp9 v1.7.0-213-gf4b1eca53
preset : cpu-used 0
real bitrate 238 kb/s size 291 KiB
time : pass 1 : 2s pass 2 : 68s total time : 70 s
metrics :
SSIM All:0.952918 (13.271442)
PSNR average:37.275722
VMAF score = 94.977788
aomenc 0.1.0-8871-g7a3c26460
preset : cpu-used 2
real bitrate 252 kb/s size 307 KiB
time : pass 1 : 2s pass 2 : 1254s total time : 1256 s
metrics :
SSIM All:0.951930 (13.181228)
PSNR average:37.565993
VMAF score = 95.79106
aomenc is real slow for the moment and with cpu-used 2 . I won't try 1080p file for the moment =p
Old 24th March 2018, 12:04   #519  |  Link
ChaosKing
The most important part: Which one of the encodes pleases your eyes the most?
Old 24th March 2018, 13:03   #520  |  Link
easyfab
here you have the result files. I add a av1->x264 (crf 0) file .
https://www.sendspace.com/file/bm5el8
For me av1 is the most "clean"
