Old 26th August 2014, 09:01   #12761  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by NikosD View Post
Is the app really doing something during "Patching bitdepth to 24bits..." process ?
Yes, change the fields "Source PCM Resolution" in the DTS frames header from 16 to 24 to remember the users decode to this bitdepth at least.
If yes, what's the meaning of bitdepth in a lossy (DTS) format and what is technically doing ?
Nothing.
tebasuna51 is offline
Old 26th August 2014, 09:20   #12762  |  Link
NikosD
Thanks!
HEVC decoding benchmarks
H.264 DXVA Benchmarks for all
NikosD is offline
Old 26th August 2014, 10:29   #12763  |  Link
rhaz
Hello. Anyone can explain what does this message mean "[dca @ 002f71a0] Number of channels changed in DCA decoder (6 -> 2)" I tried converting the .dts to .wavs or any other format and I always get this message before decoding starts, after its finished, I get a shrinked file. Original file is 1h 20 minutes long, a resulting file ends up in 26 minutes long only. Now it doesn't cut off or anything, it shrinks that 1h20min to 26 minutes long file and when you play it its impossible to understand anything, its all mashed up together or something.
I've been using eac3to cmd line for converting formats and I never had this problem before. Anyone knows how do I successfully convert this particular .dts? I'm sure it has to do something with that DCA decoder message, I've never seen one before. Cheers.
rhaz is offline
Old 26th August 2014, 13:26   #12764  |  Link
I don't know for certain, but it looks like you got a mix of 5.1 and 2.0 in your audio stream. I wonder if you possibly tried to convert audio streams extracted from VOBs as they are authored on DVD (file mode), not of an extracted linear PGC (IFO mode).
LigH is offline
Old 26th August 2014, 13:30   #12765  |  Link
rhaz
It's from BluRay. I've done this million times. I'm doing it right now. And it all works, except this one, I'm stuck with it. What's wrong with this DTS! Arrgh...
rhaz is offline
Old 26th August 2014, 13:53   #12766  |  Link
filler56789
SuperVirus
filler56789's Avatar
Need MORE info
filler56789 is offline
Old 26th August 2014, 14:22   #12767  |  Link
Sounds like it doesn't realize that the format changed, and writes the 2 channel content as 6 channel. It would sound horrible and end up shorter (a third).
If you can, cut off a small piece of the start, until the message goes away.
nevcairiel is offline
Old 26th August 2014, 16:49   #12768  |  Link
Music Fan
Does it really change anything for decoding ? Because I believe most of decoders work in 24 bit for a while and even for 16 bit pcm sources, DAC often make an "upscale" in 24 bit.
And I guess you mean that some DAC do not work in floating point and thus need to know (with the dts header) how to decode the dts (in 16 or 24 bit).
Music Fan is offline
Old 27th August 2014, 01:48   #12769  |  Link
tebasuna51
tebasuna51's Avatar
This was explained already.
Don't change anything in the decode and the decoders don't need know the bitdepth of source PCM.
Old 28th August 2014, 09:26   #12770  |  Link
NikosD
After using Haali installer for eac3to, I had problems with the Haali splitter which I managed to disable.
I have two questions though:
1) Is there a way to install just the Haali matroska muxer without the rest of the installer ?
Is there a separate installer/ option to do that ?
2) Is there something special in this specific matroska muxer that makes it mandatory for eac3to ?
The full installation is problematic due to Haali splitter.
Thanks!
NikosD is offline
Old 28th August 2014, 09:37   #12771  |  Link
tebasuna51
tebasuna51's Avatar
Without Haali matroska muxer you can extract video only like elementary streams: .h264, .vc1 or .m2v
Old 28th August 2014, 09:40   #12772  |  Link
NikosD
OK, but it could be done by any matroska muxer, not Haali explicitly.
NikosD is offline
Old 28th August 2014, 10:55   #12773  |  Link
filler56789
SuperVirus
Unfortunately, Haali's Matroska Muxer is "inside" the files splitter.ax and mkx.dll. And sadly JEEB either is too busy or doesn't have permission to fix the design flaws of the Haali "bundle"
Old 29th August 2014, 15:42   #12774  |  Link
Overdrive80
Anime addict
Overdrive80's Avatar
I install CCCP codecs, and after install this keys:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Haali]
[HKEY_CURRENT_USER\Software\Haali\Matroska Splitter]
"input.fonts"=dword:00000001
"input.linking"=dword:00000001
"ui.trayicon"=dword:00000001
[HKEY_CURRENT_USER\Software\Haali\Video Renderer]
"BT.709"=dword:00000002
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\HaaliMkx]
"StartMenuFolder"="Haali Media Splitter"
"rmp4"="1"
"rOGM"="1"
"rts"="1"
"rm2ts"="1"
"rEXT"="1"
"rFT"="1"
"rWMP"="1"
"Install_Dir"="C:\\Program Files (x86)\\Haali\\MatroskaSplitter"
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\HaaliMkx\Input]
"avi.1"="ffffffff00000000ffffffff,524946460000000041564920,{51A00247-40A8-4845-9F17-7DBFCC9A8783}"
"mp4.1"="00000000ffffffff,0000000066747970,{B3DE7EDC-0CD4-4d07-B1C5-92219CD475CC}"
"mp4.2"="00000000ffffffff,000000006d6f6f76,{B3DE7EDC-0CD4-4d07-B1C5-92219CD475CC}"
"mp4.3"="00000000ffffffff,000000006d646174,{B3DE7EDC-0CD4-4d07-B1C5-92219CD475CC}"
"ogm.1"="ffffffff,4f676753,{DB43B405-43AA-4f01-82D8-D84D47E6019C}"
"ts.1"="ff,47,{B841F346-4835-4de8-AA5E-2E7CD2D4C435}"
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\HaaliMkx]
"DisplayName"="Haali Media Splitter"
"UninstallString"="\"C:\\Program Files (x86)\\Haali\\MatroskaSplitter\\uninstall.exe\""
"NoModify"=dword:00000001
"NoRepair"=dword:00000001
[HKEY_LOCAL_MACHINE\SOFTWARE\HaaliMkx]
"rmp4"="1"
"rOGM"="1"
"rts"="1"
"rm2ts"="1"
"WMP"="1"
"rEXT"="1"
"rFT"="1"
[HKEY_LOCAL_MACHINE\SOFTWARE\HaaliMkx\Input]
Intel i7-6700K + Noctua NH-D15 + Z170A XPower G. Titanium + Kingston HyperX Savage DDR4 2x8GB + Radeon RX580 8GB DDR5 + ADATA SX8200 Pro 1 TB + Antec EDG750 80 Plus Gold Mod + Corsair 780T Graphite
Overdrive80 is offline
Old 7th September 2014, 19:28   #12775  |  Link
tebasuna51
tebasuna51's Avatar
Last 9 post in this thread moved to http://forum.doom9.org/showthread.php?t=171150
Reason: off topic
Old 9th September 2014, 04:35   #12776  |  Link
asarian
I have this command:
C:\eac3to>eac3to audio.ac3 output1.wav -edit=0:47:10.200,3200ms -silence
MP2, 2.0 channels, 1:34:19, 224kbps, 44.1kHz
Decoding with libav/ffmpeg...
Editing RAW/PCM...
Reducing depth from 64 to 24 bits...
Writing WAV...
Creating file "output1.wav"...
Clipping detected, a 2nd pass will be necessary.
This track is not clean.
The last MPx frame is incomplete and thus gets skipped.
Starting 2nd pass...
Editing RAW/PCM...
Writing WAV...
Applying -31.9dB gain...
I was hoping it would *overwrite* 3200ms of silence at 0:47:10.200. Instead, it just inserts 3200ms! How can I do the former?
Secondly, due to small glitch in the stream (the one I'm trying to blank out), eac30 decides to apply a -31.9dB gain on the file, making it as good as mute. How can I prevent that?
Thx.
asarian is offline
Old 9th September 2014, 09:04   #12777  |  Link
Music Fan
Try without -silence.
Old 9th September 2014, 11:07   #12778  |  Link
tebasuna51
tebasuna51's Avatar
You need two pass:
eac3to audio.ac3 output1.wav -edit=0:47:10.200,-3200ms -no2ndpass
then the -31.9dB gain is not applied and the glitch is deleted.
eac3to output1.wav output2.wav -edit=0:47:10.200,3200ms -silence
now insert the silence at same point.
Old 9th September 2014, 11:26   #12779  |  Link
asarian
You need two pass:
Thank you very much! The -no2ndpass option isn't listed in the Options somehow, but it works nonetheless!
asarian is offline
Old 12th September 2014, 19:14   #12780  |  Link
asarian
Originally Posted by heerschop View Post
I use Eac3to with nero without installing nero.
Eac3to only needs a couple files and registry settings
Nero Files:
- AdvrCntr2.dll
- NeAudio2.ax
- NeEacDec.dll
Copy these files in a folder of your choice. I have copied them to my eac3to folder.
Use the following command lines to register the dll's.
regsvr32.exe C:\tools\eac3to\Nero\NeAudio2.ax
regsvr32.exe C:\tools\eac3to\Nero\AdvrCntr2.dll
The following registry keys have to be added to the registry to register the nero plugin.
[HKEY_LOCAL_MACHINE\SOFTWARE\Ahead\Installation\Families\Nero 7\Info]
etc.
[HKEY_LOCAL_MACHINE\SOFTWARE\Ahead\Installation\Families\Plugins\Info]
etc.
That all you need to use the nero plugin with eac3to
The above info seems hopelessly outdated (naturally so, of course). For one, Wimdows 7, 64-bit installs in:
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Ahead]
Copying the pertinent registry info from my Vmware box (only box I still have a Nero 7 running), I can't get the DLL's I copied over to work, though. However many ways I try, I keep getting errors about "the DllRegister Server entry point was not found."
Surely, isn't time eac3to found a better way to deal with aac files? (Yes, I still have some old movies that need it).
asarian is offline
eac3to
