Old 16th September 2018, 12:04   #5681  |  Link
Klaus1189
@v0lt
Thank you
Old 16th September 2018, 18:22   #5682  |  Link
Mercury_22
MPC-BE can't see all the "long" playlist when opening a blu-ray including main movie's correct one
While MPC-HC can see it
Sample https://www.sendspace.com/file/2npu9s
Intel UHD Graphics 750; Win 10 22H2
Mercury_22 is offline   Reply With Quote
Old 17th September 2018, 12:09   #5683  |  Link
Klaus1189
A little cosmetic issue is in Options -> Internal Filters -> Tab Source Filters -> Button MPEG splitter configuration
There you can select TrueHD or AC-3 -> the round boxes are cut off at the bottom, maybe we can enlarge that.
Since my desktop resolution is 3840x2160, I use 200% scaling, I tried another pc with 1080p@100% scaling, there it looks fine to me.
Screenshots: 100% 200%
Old 17th September 2018, 18:55   #5684  |  Link
v0lt
@Mercury_22
Aleksoid1978 changed something in r3963 about this.
@Klaus1189
I corrected the size of radio buttons in r3966. But I checked only in Windows 7.
Old 17th September 2018, 21:30   #5685  |  Link
Klaus1189
Thank you v0lt
Old 18th September 2018, 17:44   #5686  |  Link
steakhutzeee
steakhutzeee's Avatar
Hi, as i can see if i change 'styles' on the fly for subs, this works correctly.
If i tweak the 'predefined style' and then select it so i use it for all the videos, i see that the subs is not loaded correctly, i mean, the tags are ignored, like italic etc.
Why this? can i solve?
Intel i5-4590 - MSI R9 270X 2GB - 8GB RAM
steakhutzeee is offline   Reply With Quote
Old 18th September 2018, 18:41   #5687  |  Link
mandarynek82
http://blog.familie-buchberger.at/20...asio-renderer/
ASIO didn't work anymore.
mandarynek82 is offline   Reply With Quote
Old 19th September 2018, 07:20   #5688  |  Link
Surely this is last beta, it's almost been a year and only for .1 release, why so adverse to releasing stable? Why not have 1.5.2 beta and release 1.5.1.1 with fixes?
Old 19th September 2018, 08:37   #5689  |  Link
Aleksoid1978
Aleksoid1978's Avatar
The release is scheduled for next month, after the purchase of a new certificate.
Old 19th September 2018, 16:17   #5690  |  Link
beter
Bug related to Save image (with subtitle) function.
When using madvr, and the windows size doesn't fit the video size, there would be two subtitles in the screenshot, one in high quality and correct ratio, and one in low quality and incorrect ratio on top.
(Edit: it seems that when using madvr the subtitle would be included even if I disabled the "include subtitle function)
The screenshot of a sup subtitle:
The look in the player.
in case of ass text subtitle, only the spacing is affected, the words would not be stretched.
beter is offline   Reply With Quote
Old 19th September 2018, 23:15   #5691  |  Link
Aleksoid1978
MadVR include subtitles, player can't handle it. See it's options, i think it have settings for subtitles in screenshot.
Old 20th September 2018, 16:17   #5692  |  Link
v0lt
MPC-BE 1.5.2 (build 3973) beta with a digital signature.
Old 22nd September 2018, 04:01   #5693  |  Link
beter
OK, I have found that option in madVR. Thanks.
Old 23rd September 2018, 19:39   #5694  |  Link
Warner306
I have a feature request. I probably should have asked earlier, but it didn't seem too important:
The feature I'm referring to is the Audio Delay column in MPC-HC that can be applied to specific display modes (refresh rates).
I have one display that has high input lag at 24p, so I have to apply a 150 ms delay to the audio, but only at 24 Hz. The delay is required at 24 Hz, so the existing audio delay in MPC-BE must be adjusted manually per video rather than per refresh rate.
I don't know how common this issue is with modern displays, but there are others out there with the same issues.
Some players besides MPC-HC provide this type of functionality.
Plex Media Player allows for an audio delay at 24 Hz:
audio_delay.24hz
Kodi also allows for an audio delay at any refresh rate:
<refresh>
<min>23</min>
<max>24</max>
<delay>125</delay>
</refresh>
There are some posts out there referencing this issue:
24p and audio sync issues
audio sync at 24fps
I'm not sure if this is relevant to anyone else, but thought I'd ask.
Old 23rd September 2018, 22:04   #5695  |  Link
iSeries
^^^ Great idea, I too have the same issue at 24p.
Old 24th September 2018, 18:38   #5696  |  Link
v0lt
Warner306
I have a "display manager" planned. But this is a big and difficult job that I do not know when we start doing.
Old 24th September 2018, 21:48   #5697  |  Link
Schrade
Schrade's Avatar
I am using MPC-BE as my video player for Twitch Streams via Streamlink-Twitch-GUI
When I try to take a screenshot using F5, it says a screenshot has been saved but it doesn't get saved. I think it might have something to do with the .m3u8 filename in the URL being 770 characters long.
Any chance we could have a setting to configure the screenshot filenames? Or perhaps there's another way around this?
MPC-BE x64 v1.5.2 (build 3973)
Schrade is offline   Reply With Quote
Old 25th September 2018, 16:10   #5698  |  Link
Warner306
Originally Posted by v0lt View Post
Warner306
That sounds fine. I can wait. Thanks for the reply.
Old 27th September 2018, 07:17   #5699  |  Link
rock
Menu Subtitles->Advanced->Styles.. doesn't work. I use build 3984. Regards.
rock is offline   Reply With Quote
Old 27th September 2018, 07:21   #5700  |  Link
Aleksoid1978
Confirm - thank you.
P.S. Fixed.
