Old 22nd September 2017, 20:14   #181  |  Link
the subtitle queue isn't full and the upload too check the PCIe speed.
Old 22nd September 2017, 22:43   #182  |  Link
cyberscott
PCIe speeds are fine, Gen2, 16x.
The screen shot does't show the full story, only what was happening at the time of the photo.
All the queues go up and down during the presence of any subtitles withAssFilterMod, always in a state of flux.
I did confirm same behavior within potplayer. This one is weird. Must be something specific to my system hardware and software as lion09503 reported no issues with his Nvidia 1060 / Ryzen system and he has a less powerful video card than I do.
It not the end of the world if I can't use the filter, just a little annoying that I haven't been able to pin down the cause yet.
cyberscott is offline   Reply With Quote
Old 22nd September 2017, 23:02   #183  |  Link
lion09503
Originally Posted by cyberscott View Post
Thanks for that info. I haven't tried another player outside of MPC-CE yet. I'll probably give potplayer a try this weekend to see if anything changes.
Great. I haven't heard of mpc-ce though. Is that a port of mpc-hc? Can you link it? I'm not finding anything on google.
lion09503 is offline   Reply With Quote
Old 22nd September 2017, 23:59   #184  |  Link
cyberscott
You'll never find MPC-CE, it doesn't exist. A typo on my part, should be MPC-BE. I've edit my original post to correct. Sorry for the confusion.
Old 22nd October 2017, 01:41   #185  |  Link
cyberscott
I'd though I'd post back that after I installed the Windows 10 Fall Creators update, my issues with both AssFilterMod and xysubfilter completely cleared up and both now work as they should. I though I'd never had to thank Micro$oft for anything, lol!
Old 17th November 2017, 05:28   #186  |  Link
Blitzker
version 0.4
Hello!
Its been a while since the last release but i found time to release a new version.
AssFilterMod version 0.4 is out: https://github.com/Blitzker/assfiltermod/releases
v0.4
- add: System tray icon
- add: Selection of external subtitles in context menu of tray icon
- add: Open settings by left click on the tray icon
- add: Use of fonts in External Subs Fonts folder for SRT subtitles
- add: Libass is built with harfbuzz support
- add: Support of font ligatures
- add: Option to disable auto-load of external subtitles
- fix: Auto-load of subtitles with unicode characters
- fix: Auto-load of SRT subtitles on a different codepage than en_us
- Settings page is now split in two: General Settings and SRT Settings
- Add support for Visual Studio 2017
- Use my fork of libass
- Update libass asm building tools : Now use nasm instead of yasm
I highly recommend to delete the registry key HKEY_CURRENT_USER\Software\AssFilter or reset the settings in the configuration pages.
This release introduce a system tray icon with which you can access the configuration by a left-click. The support of external subtitles have been improved and now load all subtitles present in the media file folder (they must still match the media name) and the subfolders (all .ass and .srt are loaded) specified in the configuration dialog. You can switch between the external subtitles by using the context menu on the new tray icon (right-click).
The binaries are now built with Visual Studio 2017, so be sure to install the redistributables (urls on first post).
Latest dev builds of AssFilterMod can be found here: https://www.mediafire.com/folder/w1w...s/AssFilterMod
Blitzker is offline   Reply With Quote
Old 17th November 2017, 06:17   #187  |  Link
is it possible to make the custom resolution option to be AR aware?
and the tray icon doesn't work on my system.
i'm on an old windows 10 insaider build.
Old 18th November 2017, 00:24   #188  |  Link
Blitzker
I'll see what i can do about the AR.
For the tray icon, its a stupid error on my part. Its disabled by default and i forgot to add a checkbox in the General Settings.
In the meantime, you can manually activate it by going in the registry "HKEY_CURRENT_USER\Software\AssFilter" and set "TrayIcon" to 1.
Old 18th November 2017, 05:09   #189  |  Link
Dulus_No
Kerning option for srt
Would be possible to add an option for enabling kerning for .srt? It's possible for .ass with the script property "Kerning: yes".
http://www.framecompare.com/screensh...rison/KZPNNN8X
Dulus_No is offline   Reply With Quote
Old 18th November 2017, 23:04   #190  |  Link
Blitzker
Simple enough. I've added support for kerning in the next build.
Old 18th November 2017, 23:14   #191  |  Link
Blitzker
New build of AssFilterMod available:
- Add the missing "Enable System Tray Icon" checkbox in General Settings
- Add "Enable Kerning" checkbox in SRT settings.
http://www.mediafire.com/file/1icans...75459a_x32.zip
http://www.mediafire.com/file/kq25ai...75459a_x64.zip
Old 19th November 2017, 07:08   #192  |  Link
Dulus_No
Thank you!
Old 21st November 2017, 23:44   #193  |  Link
Siso
Soul Seeker
Siso's Avatar
I tried the latest version and it seems it doesn't allow me to make the subtitle font to bold...It stays on normal.
Siso is online now   Reply With Quote
Old 22nd November 2017, 13:15   #194  |  Link
Dulus_No
Workaround is to add in "Custom Tags" this: {\b1}
Old 22nd November 2017, 13:22   #195  |  Link
Siso
Soul Seeker
Siso's Avatar
Thank you.
Old 26th November 2017, 15:29   #196  |  Link
i'm on fall creator update now and i can't install assfilter now.
and yes i'm installing it as an admin. madVR worked fine so i'm quite lost here...
Old 26th November 2017, 15:47   #197  |  Link
lvqcl
Do you have Visual Studio 2015 redistributable or Visual Studio 2017 redistributable installed?
Old 26th November 2017, 16:12   #198  |  Link
thanks.
Old 26th November 2017, 17:17   #199  |  Link
clsid
A static build would be nice to have. It avoids this dependency problem and pretty much all other codecs do it for that reason.
Old 26th November 2017, 22:26   #200  |  Link
Blitzker
Yes, this is the way to do it for now. Its on my to-do list to be able to select options on the font selection dialog box.
Indeed, like you said this would avoid problems. Will do that for the next build.
