Old 28th March 2020, 17:12   #681  |  Link
umezawa_takeshi
Unregistered User
As mentioned by others, Windows 7 and older and 32bit Windows are not supported now.
I cannot update the first post because it is posted by another person.
umezawa_takeshi is offline   Reply With Quote
Old 30th March 2020, 16:43   #682  |  Link
umezawa_takeshi
Unregistered User
Version 21.2.1 is released
Version 21.2.1 is released.
Others
  • Excluded utv_logc.exe from installer.
License (GPLv2) / readme / Windows exe installer zip package utv_logc.exe / source code / GitHub
In addition, experimental zip package is available. I don't explain the usage of zip package more than written in readme-zip.txt .
FIX: In uninstall procedure, the batch file to execute is uninstall.bat. Not install.bat (written in readme-zip.txt), of course.
Old 18th April 2020, 15:14   #683  |  Link
umezawa_takeshi
Unregistered User
Version 21.3.0 is released
Version 21.3.0 is released.
Performance Improvements
  • ULxx, UQxx: Speed up encoding a little.
License (GPLv2) / readme / Windows exe installer, zip package, utv_logc.exe / source code / GitHub
Note: Huffman decode routine is updated. If you find any problem in ULxx/UQxx decoding, please report it.
Old 31st July 2020, 15:19   #684  |  Link
umezawa_takeshi
Unregistered User
Version 21.3.1 is released
Version 21.3.1 is released.
Others
  • Added tooltips to configuration dialogs.
Old 1st August 2020, 19:49   #685  |  Link
vigan1
Thank you it's the best codec for realtime encoding !
UTvideo T2 is the fastest.
It is supported on ffmpeg ? Or only T1 in FFmpeg ?
vigan1 is offline   Reply With Quote
Old 2nd August 2020, 09:37   #686  |  Link
umezawa_takeshi
Unregistered User
As far as I know, T2 encoding is not supported on FFmpeg. T2 decoding is supported.
Old 3rd August 2020, 15:20   #687  |  Link
vigan1
Thank you, they should add it, your codec is the best.
I know it's hard and lonely sometime to work on a project, for free, so please remember that your work is very highly appreciated.
And I hope you will have the best life, be happy.
Thank you.
When it's hard don't give up, have a nice day!
Old 5th August 2020, 15:37   #688  |  Link
umezawa_takeshi
Unregistered User
Thank you for your encouragement. You too.
Old 5th August 2020, 20:43   #689  |  Link
Richard1485
The fact that this codec is still being actively developed is fantastic. Thanks for the update!
Old 26th August 2020, 14:20   #690  |  Link
umezawa_takeshi
Unregistered User
Version 22.0.0 is released
Version 22.0.0 is released.
New features
  • UQxx: Add "Predict Gradient" intra-frame prediction method.
License (GPLv2) / readme / Windows exe installer, zip package, logger tool / source code / GitHub
Old 22nd September 2020, 08:53   #691  |  Link
umezawa_takeshi
Unregistered User
Version 22.1.0 is released
Version 22.1.0 is released.
New features
  • ULY0, ULH0: Add NV12 input/output.
  • Speed up decoding to RGB32/RGBA and YUY2/UYVY from native internal format.
Old 2nd October 2020, 13:25   #692  |  Link
umezawa_takeshi
Unregistered User
Version 22.2.0 is released
Version 22.2.0 is released.
  • UQxx: Speed up encoding / decoding in case of Predict Gradient.
Old 23rd October 2020, 16:12   #693  |  Link
jeffk
Hi, Thanks for your codec, it is amazingly fast.
I feel that the "Not recommended" about interlaced video is a bit brutal, because if really encoding Interlaced Video we dont know if we need to use it.
Is it not recommended for progressive, not recommended at all ?
At the moment i'm working on Interlaced video I dont know if I must/need/should check it.
jeffk is offline   Reply With Quote
Old 23rd October 2020, 17:25   #694  |  Link
jpsdr
Not recommended is for allways checking this whatever your video is. Otherwise it will assume video is interlaced, and encode accordingly, wich will result in less efficient for progressive video.
If it's always checked, encoding of progressive video will be less efficient.
If it's always unchecked, encoding of interlaced video will be less efficient.
If you think there is more progressive than interlaced videos, you'll not recommend the interlaced mode.
The best is to check it when you have interlaced video, and uncheck when you have progressive.
If you're dealing more often with interlaced than progressive video, and don't want to have to configure each time, it will be more efficient to check it.
My github.
Old 24th October 2020, 11:31   #695  |  Link
umezawa_takeshi
Unregistered User
The reason I wrote that the option is not recommended is simply because it is slow and I won't optimize it anymore. There is nothing wrong with using this option if there is any reason.
  • If you are working with interlaced video, you can achieve higher compression ratio with the option.
  • If you use ULY0/ULH0 and its input/output format is not YUV 4:2:0, you should use the option correctly because vertical down/up sampling algorithm depend on whether the video is interlaced or not.
Of course, you should not use the option if you are working with progressive video.
Old 25th October 2020, 18:10   #696  |  Link
Richard1485
Maybe it would be better to label the interlaced option as "slow". It is obvious that the option should be used only for interlaced content, but as things stand the user might assume that it is not recommended even for interlaced content, or that there is some issue with interlaced video in UT VIdeo, which is not the case.
Old 26th October 2020, 08:24   #697  |  Link
Maybe "Don't enable by default" or similar...
Old 26th October 2020, 11:37   #698  |  Link
umezawa_takeshi
Unregistered User
All right. I will fix wording in the next release.
Old 24th April 2021, 13:16   #699  |  Link
umezawa_takeshi
Unregistered User
Version 22.3.0 is released
Version 22.3.0 is released.
  • UMxx: Speed up input/output on AVX512-VBMI2 capable processors.
Others
  • Updated supported environment and recommended environment.
Old 30th May 2021, 10:14   #700  |  Link
mzso
Does ffmpeg include the official codec, or do they have their own UT-Video implementation?
Edit:
I seeem to have a major issue when trying to record with MSI afterburner. No video is recorded.
