Old 11th January 2011, 17:23   #10901  |  Link
Originally Posted by omegaman7 View Post
Your previous post suggested 23040 was the default output size for BD-25 Unless I read it wrong, in which I Humbly apologize.
I think I'll probably just stick with the Default. and hope for 22.5Gb like you average. I've now seen 2 movies though that completed at 21.7 and 21.8Gb. I suppose 2 movies out of 20 - 30 movies isn't a bad frequency
I did "Dinner for Schmucks" with the custom setting of 23450, and what appears to be the same settings as you, and it came out at 22.4GB. That's right in line with what it should be.
Old 11th January 2011, 18:45   #10902  |  Link
omegaman7
omegaman7's Avatar
And the calculations should have been identical for bd rebuilder then. That boggles my mind LOL! aw well. I personally watched the backup. Funny movie
Old 11th January 2011, 20:59   #10903  |  Link
sreemv
@sreemv
Hi!
The tile of this thread is quite clear - It is for reporting bugs ONLY...
Apologies - didnt realize there are multiple threads for this tool - usually most other tools appear to have singlle thread.
sreemv is offline   Reply With Quote
Old 12th January 2011, 00:38   #10904  |  Link
Voyeurism
Audio Sync Issue
I have been using the various BD Rebuilder beta's to back up my collection to DVD5, to date without any problems that I've noticed. However, when I try to rebuild the movie "The Curious Case of Benjamin Button" I get an audio sync problem.
The first time this happened I was using the previous (0.36.something) beta, but I have now tried the disk again with the latest (0.37.01) beta and the same problem occurs.
I am using the "Movie Only" backup, and keeping the 3 English language audio tracks.
Any suggestions would be welcomed.
Voyeurism is offline   Reply With Quote
Old 12th January 2011, 00:48   #10905  |  Link
Originally Posted by Voyeurism View Post
Are all three language off? How much off (seconds or milliseconds)?
Old 12th January 2011, 08:11   #10906  |  Link
Voyeurism
The second audio track (English descriptions for the hard of hearing) seems to be very slightly off, although not enough to be really noticeable - it's possible that it's fine, and I'm just getting paranoid. The third audio track (director's commentary) seems to be absolutely fine.
The main audio track is noticeably off - maybe 1-2 seconds. From looking at the stream information in VLC this is a TrueHD track on the original disk, but has been reencoded to AC3 on the BD5. The other two were AC3 on the disk and on the BD5 I don't know how to check whether they have been touched by BD Rebuilder or not.
Also, strangely, the frame rate for the video stream is shown in VLC as 23.976023 for the stream on the disk, and 47.952047 for the BD5 - although that can't possibly be correct, as it's definitely not running at double speed.
Old 12th January 2011, 15:30   #10907  |  Link
Sounds like it may be the same issue Capsbackup reported. I'd appreciate it if both of you would try replacing the BD Rebuilder executable with the one in this zip and see if it fixes it. Unfortunately you'll have to run the job again.
Old 12th January 2011, 16:44   #10908  |  Link
Capsbackup
I will run a test now. Will use same settings as before, IVTC Sources with 3:2 Pulldown and Use DECOMB filter on interlaced sources selected.
Will report back later this afternoon.
Old 12th January 2011, 17:16   #10909  |  Link
Thanks. I think this is it -- but can't be sure until its tested.
Old 12th January 2011, 22:32   #10910  |  Link
TheBreen
I'm not sure if this is a problem at all but it relates to the undersizing discussion. I backed up The Shining with a source size of 30.08GB, using BD-25 as my target output, and the result was 16.8GB. I thought this a bit strange since I chose Full Backup and I thought only non-english audio would have been stripped, and I didn't think non-english audio would have amounted to half of the source size.
So I re-tried the backup with same settings except Custom Target Size of 45000 and the result was 21.5GB. Should 21.5GB have been an acceptable output size with the BD-25 option as well, meaning video was compressed unnecessarily?
TheBreen is offline   Reply With Quote
Old 12th January 2011, 22:46   #10911  |  Link
Make sure you are using the apps and versions that are linked in the first post of this thread. Sometimes using other versions or other CODECs can result in undersizing -- that's not a good thing. In some cases other CODECs can actually change the resolution or clarity, and as a result what appears to be a high Q at a lower bitrate is actually a blurred image.
Old 13th January 2011, 00:57   #10912  |  Link
Capsbackup
The test BD-RB file did not correct the audio out of sync problem on the movie Case 39.
[Options]
MIN_M2TS_SIZE=100
KEEP_MBTREE=1
MODE=0
ENCODE_QUALITY=1
ONEPASS_ENCODING=2
AUTO_QUALITY=0
QUICK_EXTRAS=0
TARGET_SIZE=4500
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=all
SD_CONVERT=0
COLOR_BOOST=0
RESIZE_1080=0
DEINTERLACE=1
DTS_REENCODE=1
AC3_REENCODE=1
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=0
REMOVE_WORKFILES=0
FULL_AVCHD=0
AUDIO_TRACK_LIMIT=1
SUBTITLE_TRACK_LIMIT=1
CUSTOM_TARGET_SIZE=8400
REMOVE_OUTPUT=0
OPEN_GOP=1
USE_FILTERS=0
MOVIE_ONLY_LOOP=1
BDMV_CERT_ONLY=1
USE_LAVF=0
IVTC_PULLDOWN=1
VERSION=0.37.0.2
ASSUME_DVD_PAL=0
SD_TO_1080=0
CONVERT_WIDE=0
[Paths]
SOURCE_PATH=G:\BD RIPS\CASE_39_AC\
WORKING_PATH=G:\CASE_39 BDRB TEST\
[07:54:07] BD Rebuilder v0.37.02 (beta)
  - Source:  CASE_39_AC
  - Input BD size: 35.49 GB
  - Approximate total content: [02:44:02.565]
  - Target BD size: 8.20 GB
  - Windows Version: 6.1 [7600]
  - SHUTDOWN at completion enabled
  - Quality: Better (Faster), ABR
[07:54:07] PHASE ONE, Encoding
 - [07:54:07] Extracting A/V streams [VID_00000]
 - [07:54:10] Reencoding: VID_00000 (1 of 29)
 - [07:54:10] Collecting video information
   - Rate/Length: 23.976fps, 357 frames
   - Bitrate: 5,375 Kbs
 - [07:54:10] Reencoding: VID_00000, Pass 1 of 1
 - [07:54:25] Video Encode complete
 - [07:54:25] Reencoding audio tracks (if req'd)
 - [07:54:26] Multiplexing M2TS
 - [07:54:26] Extracting A/V streams [VID_00001]
 - [07:54:31] Reencoding: VID_00001 (2 of 29)
 - [07:54:31] Collecting video information
   - Rate/Length: 23.976fps, 1,080 frames
   - Bitrate: 4,040 Kbs
 - [07:54:31] Reencoding: VID_00001, Pass 1 of 1
 - [07:55:05] Video Encode complete
 - [07:55:05] Reencoding audio tracks (if req'd)
 - [07:55:05] Multiplexing M2TS
 - [07:55:07] Extracting A/V streams [VID_00002]
 - [07:55:09] Reencoding: VID_00002 (3 of 29)
 - [07:55:09] Collecting video information
 - [07:55:09] Reencoding: VID_00002, Pass 1 of 1
 - [07:55:24] Video Encode complete
 - [07:55:24] Reencoding audio tracks (if req'd)
 - [07:55:25] Multiplexing M2TS
 - [07:55:25] Extracting A/V streams [VID_00003]
 - [07:55:29] Reencoding: VID_00003 (4 of 29)
 - [07:55:29] Collecting video information
 - [07:55:29] Reencoding: VID_00003, Pass 1 of 1
 - [07:55:43] Video Encode complete
 - [07:55:43] Reencoding audio tracks (if req'd)
 - [07:55:44] Multiplexing M2TS
 - [07:55:45] Extracting A/V streams [VID_00005]
 - [07:55:49] Reencoding: VID_00005 (5 of 29)
 - [07:55:49] Collecting video information
   - Rate/Length: 23.976fps, 959 frames
 - [07:55:49] Reencoding: VID_00005, Pass 1 of 1
 - [07:56:13] Video Encode complete
 - [07:56:13] Reencoding audio tracks (if req'd)
 - [07:56:13] Multiplexing M2TS
 - [07:56:15] Extracting A/V streams [VID_00006]
 - [07:56:24] Reencoding: VID_00006 (6 of 29)
 - [07:56:24] Collecting video information
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29.970fps, 7,983 frames
   - Bitrate: 902 Kbs
 - [07:56:24] Reencoding: VID_00006, Pass 1 of 1
 - [07:57:20] Video Encode complete
 - [07:57:20] Reencoding audio tracks (if req'd)
 - [07:57:21] Multiplexing M2TS
 - [07:57:22] Extracting A/V streams [VID_00015]
 - [08:17:18] Reencoding: VID_00015 (7 of 29)
 - [08:17:18] Collecting video information
   - Rate/Length: 23.976fps, 157,417 frames
   - Bitrate: 8,455 Kbs
 - [08:17:18] Reencoding: VID_00015, Pass 1 of 1
 - [10:18:51] Video Encode complete
 - [10:18:51] Reencoding audio tracks (if req'd)
 - [10:22:04] Multiplexing M2TS
 - [10:26:08] Extracting A/V streams [VID_00016]
 - [10:26:10] Reencoding: VID_00016 (8 of 29)
 - [10:26:10] Collecting video information
   - Rate/Length: 29.970fps, 1,494 frames
   - Inverse Telecining in effect (IVTC)
   - Bitrate: 889 Kbs
 - [10:26:10] Reencoding: VID_00016, Pass 1 of 1
 - [10:26:18] Video Encode complete
 - [10:26:18] Reencoding audio tracks (if req'd)
 - [10:26:18] Multiplexing M2TS
 - [10:26:19] Extracting A/V streams [VID_00017]
 - [10:26:21] Reencoding: VID_00017 (9 of 29)
 - [10:26:21] Collecting video information
   - Rate/Length: 29.970fps, 1,684 frames
   - Bitrate: 867 Kbs
 - [10:26:21] Reencoding: VID_00017, Pass 1 of 1
 - [10:26:30] Video Encode complete
 - [10:26:30] Reencoding audio tracks (if req'd)
 - [10:26:30] Multiplexing M2TS
 - [10:26:31] Extracting A/V streams [VID_00018]
 - [10:26:33] Reencoding: VID_00018 (10 of 29)
 - [10:26:33] Collecting video information
   - Rate/Length: 29.970fps, 1,844 frames
   - Bitrate: 860 Kbs
 - [10:26:33] Reencoding: VID_00018, Pass 1 of 1
 - [10:26:42] Video Encode complete
 - [10:26:42] Reencoding audio tracks (if req'd)
 - [10:26:43] Multiplexing M2TS
 - [10:26:44] Extracting A/V streams [VID_00019]
 - [10:26:45] Reencoding: VID_00019 (11 of 29)
 - [10:26:45] Collecting video information
   - Rate/Length: 29.970fps, 958 frames
   - Bitrate: 904 Kbs
 - [10:26:45] Reencoding: VID_00019, Pass 1 of 1
 - [10:26:50] Video Encode complete
 - [10:26:50] Reencoding audio tracks (if req'd)
 - [10:26:50] Multiplexing M2TS
 - [10:26:51] Extracting A/V streams [VID_00020]
 - [10:26:53] Reencoding: VID_00020 (12 of 29)
 - [10:26:53] Collecting video information
   - Bitrate: 892 Kbs
 - [10:26:53] Reencoding: VID_00020, Pass 1 of 1
 - [10:27:03] Video Encode complete
 - [10:27:03] Reencoding audio tracks (if req'd)
 - [10:27:03] Multiplexing M2TS
 - [10:27:04] Extracting A/V streams [VID_00021]
 - [10:27:10] Reencoding: VID_00021 (13 of 29)
 - [10:27:10] Collecting video information
   - Rate/Length: 29.970fps, 5,309 frames
   - Bitrate: 860 Kbs
 - [10:27:10] Reencoding: VID_00021, Pass 1 of 1
 - [10:27:35] Video Encode complete
 - [10:27:35] Reencoding audio tracks (if req'd)
 - [10:27:36] Multiplexing M2TS
 - [10:27:37] Extracting A/V streams [VID_00022]
 - [10:27:39] Reencoding: VID_00022 (14 of 29)
 - [10:27:39] Collecting video information
   - Rate/Length: 29.970fps, 1,500 frames
   - Bitrate: 894 Kbs
 - [10:27:39] Reencoding: VID_00022, Pass 1 of 1
 - [10:27:46] Video Encode complete
 - [10:27:46] Reencoding audio tracks (if req'd)
 - [10:27:47] Multiplexing M2TS
 - [10:27:47] Extracting A/V streams [VID_00023]
 - [10:27:50] Reencoding: VID_00023 (15 of 29)
 - [10:27:50] Collecting video information
   - Rate/Length: 29.970fps, 2,047 frames
   - Bitrate: 910 Kbs
 - [10:27:50] Reencoding: VID_00023, Pass 1 of 1
 - [10:28:00] Video Encode complete
 - [10:28:00] Reencoding audio tracks (if req'd)
 - [10:28:01] Multiplexing M2TS
 - [10:28:02] Extracting A/V streams [VID_00024]
 - [10:28:06] Reencoding: VID_00024 (16 of 29)
 - [10:28:06] Collecting video information
   - Rate/Length: 29.970fps, 3,585 frames
   - Bitrate: 892 Kbs
 - [10:28:06] Reencoding: VID_00024, Pass 1 of 1
 - [10:28:24] Video Encode complete
 - [10:28:24] Reencoding audio tracks (if req'd)
 - [10:28:25] Multiplexing M2TS
 - [10:28:26] Extracting A/V streams [VID_00025]
 - [10:28:30] Reencoding: VID_00025 (17 of 29)
 - [10:28:30] Collecting video information
   - Rate/Length: 29.970fps, 4,195 frames
   - Bitrate: 856 Kbs
 - [10:28:30] Reencoding: VID_00025, Pass 1 of 1
 - [10:28:51] Video Encode complete
 - [10:28:51] Reencoding audio tracks (if req'd)
 - [10:28:52] Multiplexing M2TS
 - [10:28:53] Extracting A/V streams [VID_00026]
 - [10:28:56] Reencoding: VID_00026 (18 of 29)
 - [10:28:56] Collecting video information
   - Rate/Length: 29.970fps, 1,955 frames
   - Bitrate: 896 Kbs
 - [10:28:56] Reencoding: VID_00026, Pass 1 of 1
 - [10:29:06] Video Encode complete
 - [10:29:06] Reencoding audio tracks (if req'd)
 - [10:29:06] Multiplexing M2TS
 - [10:29:07] Extracting A/V streams [VID_00027]
 - [10:29:13] Reencoding: VID_00027 (19 of 29)
 - [10:29:13] Collecting video information
   - Rate/Length: 29.970fps, 5,239 frames
   - Bitrate: 906 Kbs
 - [10:29:13] Reencoding: VID_00027, Pass 1 of 1
 - [10:29:38] Video Encode complete
 - [10:29:38] Reencoding audio tracks (if req'd)
 - [10:29:39] Multiplexing M2TS
 - [10:29:40] Extracting A/V streams [VID_00028]
 - [10:29:44] Reencoding: VID_00028 (20 of 29)
 - [10:29:44] Collecting video information
   - Rate/Length: 29.970fps, 2,856 frames
   - Bitrate: 942 Kbs
 - [10:29:44] Reencoding: VID_00028, Pass 1 of 1
 - [10:29:58] Video Encode complete
 - [10:29:58] Reencoding audio tracks (if req'd)
 - [10:29:59] Multiplexing M2TS
 - [10:29:59] Extracting A/V streams [VID_00029]
 - [10:30:02] Reencoding: VID_00029 (21 of 29)
 - [10:30:02] Collecting video information
   - Rate/Length: 29.970fps, 2,267 frames
   - Bitrate: 875 Kbs
 - [10:30:02] Reencoding: VID_00029, Pass 1 of 1
 - [10:30:13] Video Encode complete
 - [10:30:13] Reencoding audio tracks (if req'd)
 - [10:30:14] Multiplexing M2TS
 - [10:30:14] Extracting A/V streams [VID_00030]
 - [10:30:18] Reencoding: VID_00030 (22 of 29)
 - [10:30:18] Collecting video information
   - Rate/Length: 29.970fps, 2,591 frames
   - Bitrate: 947 Kbs
 - [10:30:18] Reencoding: VID_00030, Pass 1 of 1
 - [10:30:30] Video Encode complete
 - [10:30:30] Reencoding audio tracks (if req'd)
 - [10:30:31] Multiplexing M2TS
 - [10:30:32] Extracting A/V streams [VID_00031]
 - [10:30:38] Reencoding: VID_00031 (23 of 29)
 - [10:30:38] Collecting video information
   - Rate/Length: 29.970fps, 6,136 frames
   - Bitrate: 904 Kbs
 - [10:30:39] Reencoding: VID_00031, Pass 1 of 1
 - [10:31:09] Video Encode complete
 - [10:31:09] Reencoding audio tracks (if req'd)
 - [10:31:10] Multiplexing M2TS
 - [10:31:11] Extracting A/V streams [VID_00032]
 - [10:31:13] Reencoding: VID_00032 (24 of 29)
 - [10:31:13] Collecting video information
   - Rate/Length: 29.970fps, 1,426 frames
   - Bitrate: 921 Kbs
 - [10:31:13] Reencoding: VID_00032, Pass 1 of 1
 - [10:31:21] Video Encode complete
 - [10:31:21] Reencoding audio tracks (if req'd)
 - [10:31:21] Multiplexing M2TS
 - [10:31:22] Extracting A/V streams [VID_00033]
 - [10:31:30] Reencoding: VID_00033 (25 of 29)
 - [10:31:30] Collecting video information
   - Rate/Length: 29.970fps, 7,214 frames
   - Bitrate: 920 Kbs
 - [10:31:30] Reencoding: VID_00033, Pass 1 of 1
 - [10:32:05] Video Encode complete
 - [10:32:05] Reencoding audio tracks (if req'd)
 - [10:32:07] Multiplexing M2TS
 - [10:32:08] Extracting A/V streams [VID_00034]
 - [10:32:24] Reencoding: VID_00034 (26 of 29)
 - [10:32:24] Collecting video information
   - Rate/Length: 29.970fps, 14,600 frames
   - Bitrate: 874 Kbs
 - [10:32:25] Reencoding: VID_00034, Pass 1 of 1
 - [10:34:01] Video Encode complete
 - [10:34:01] Reencoding audio tracks (if req'd)
 - [10:34:03] Multiplexing M2TS
 - [10:34:05] Extracting A/V streams [VID_00035]
 - [10:34:13] Reencoding: VID_00035 (27 of 29)
 - [10:34:13] Collecting video information
   - Rate/Length: 29.970fps, 7,929 frames
   - Bitrate: 857 Kbs
 - [10:34:14] Reencoding: VID_00035, Pass 1 of 1
 - [10:35:07] Video Encode complete
 - [10:35:07] Reencoding audio tracks (if req'd)
 - [10:35:08] Multiplexing M2TS
 - [10:35:10] Extracting A/V streams [VID_00036]
 - [10:35:16] Reencoding: VID_00036 (28 of 29)
 - [10:35:16] Collecting video information
   - Rate/Length: 29.970fps, 5,456 frames
   - Bitrate: 855 Kbs
 - [10:35:16] Reencoding: VID_00036, Pass 1 of 1
 - [10:35:52] Video Encode complete
 - [10:35:52] Reencoding audio tracks (if req'd)
 - [10:35:53] Multiplexing M2TS
 - [10:35:54] Extracting A/V streams [VID_01001]
 - [10:35:59] Reencoding: VID_01001 (29 of 29)
 - [10:35:59] Collecting video information
 - [10:35:59] Reencoding: VID_01001, Pass 1 of 1
 - [10:36:33] Video Encode complete
 - [10:36:33] Reencoding audio tracks (if req'd)
 - [10:36:33] Multiplexing M2TS
[10:36:35]PHASE ONE complete
[10:36:35]PHASE TWO - Rebuild Started
 - [10:36:35] Rebuilding BD file Structure
[10:36:40] - Encode and Rebuild complete
 - Computer SHUTDOWN initiated.
The audio is ahead of the video. The original 00270mpls for these 18 scenes, VID_00016 to VID_00033, reports a total time of 00:30:06, and the BD-RB backup reports 00:37:37, the same as before.
I am not sure if this helps, but if I run DGAVCIndex on the BD-RB backup 00016.m2ts file, it reports 29.970fps.
If I run DGAVCIndex on the VID_00016.AVS.264, it reports 37.462537fps.
Let me know what else I can provide that may be of help.
Old 13th January 2011, 01:51   #10913  |  Link
TheBreen
Hi and thanks. I did install those linked apps when I installed BDRB and I don't believe anything has changed since. Inspect.exe seems to show no problem:
- Windows Version: 5.1 [2600]
- AVISYNTH Version: 2.5.7.0, Ok
- HAALI Splitter: Ok
- FFDSHOW: 3326, Ok
- FFDSHOW VC-1 set "disabled", WMP11, Ok
- BD Rebuilder v0.37.0.1, Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
I re-tried the backup with target BD25 and again got 16.8GB with compressed video, even though as I mentioned above the custom target output produced 21.5 with no video compression. Below is the log for the undersized BD25:
[17:19:54] BD Rebuilder v0.37.01 (beta)
  - Source:  SHINING
  - Input BD size: 30.08 GB
  - Approximate total content: [04:12:24.662]
  - Target BD size: 22.95 GB
  - Auto Quality: Good (Very Fast), Two Pass
[17:19:54] PHASE ONE, Encoding
 - [17:19:54] Extracting A/V streams [VID_00006]
 - [17:19:58] Reencoding: VID_00006 (1 of 8)
 - [17:19:58] Collecting video information
   - Rate/Length: 29.970fps, 2,778 frames
 - [17:19:58] Reencoding: VID_00006, Pass 1 of 1
 - [17:20:18] Video Encode complete
 - [17:20:18] Reencoding audio tracks (if req'd)
 - [17:20:19] Multiplexing M2TS
 - [17:20:21] Extracting A/V streams [VID_00036]
 - [17:20:26] Reencoding: VID_00036 (2 of 8)
 - [17:20:26] Collecting video information
   - Rate/Length: 23.976fps, 7,920 frames
 - [17:20:26] Reencoding: VID_00036, Pass 1 of 1
 - [17:23:09] Video Encode complete
 - [17:23:09] Reencoding audio tracks (if req'd)
 - [17:23:11] Multiplexing M2TS
 - [17:23:13] Extracting A/V streams [VID_00005]
 - [17:23:34] Reencoding: VID_00005 (3 of 8)
 - [17:23:34] Collecting video information
   - Rate/Length: 29.970fps, 13,530 frames
 - [17:23:34] Reencoding: VID_00005, Pass 1 of 1
 - [17:24:45] Video Encode complete
 - [17:24:45] Reencoding audio tracks (if req'd)
 - [17:24:50] Multiplexing M2TS
 - [17:24:54] Extracting A/V streams [VID_00003]
 - [17:25:40] Reencoding: VID_00003 (4 of 8)
 - [17:25:40] Collecting video information
   - Rate/Length: 29.970fps, 31,080 frames
 - [17:25:40] Reencoding: VID_00003, Pass 1 of 1
 - [17:28:06] Video Encode complete
 - [17:28:06] Reencoding audio tracks (if req'd)
 - [17:28:12] Multiplexing M2TS
 - [17:28:17] Extracting A/V streams [VID_00040]
 - [17:29:34] Reencoding: VID_00040 (5 of 8)
 - [17:29:34] Collecting video information
   - Rate/Length: 29.970fps, 54,615 frames
 - [17:29:34] Reencoding: VID_00040, Pass 1 of 1
 - [17:34:08] Video Encode complete
 - [17:34:08] Reencoding audio tracks (if req'd)
 - [17:34:18] Multiplexing M2TS
 - [17:34:27] Extracting A/V streams [VID_00039]
 - [17:35:59] Reencoding: VID_00039 (6 of 8)
 - [17:35:59] Collecting video information
   - Rate/Length: 29.970fps, 62,914 frames
 - [17:35:59] Reencoding: VID_00039, Pass 1 of 1
 - [17:41:05] Video Encode complete
 - [17:41:05] Reencoding audio tracks (if req'd)
 - [17:41:17] Multiplexing M2TS
 - [17:41:26] Extracting A/V streams [VID_00004]
 - [17:42:55] Reencoding: VID_00004 (7 of 8)
 - [17:42:55] Collecting video information
 - [17:42:55] Reencoding: VID_00004, Pass 1 of 1
 - [17:48:16] Video Encode complete
 - [17:48:16] Reencoding audio tracks (if req'd)
 - [17:48:28] Multiplexing M2TS
 - [17:48:36] Extracting A/V streams [VID_00000]
 - [17:57:56] Reencoding: VID_00000 (8 of 8)
 - [17:57:56] Collecting video information
 - [17:57:56] Keeping original video (no reencode)
 - [17:57:56] Reencoding audio tracks (if req'd)
 - [17:59:34] Multiplexing M2TS
[18:06:21]PHASE ONE complete
[18:06:21]PHASE TWO - Rebuild Started
 - [18:06:21] Rebuilding BD file Structure
[18:06:26] - Encode and Rebuild complete
 - WORKFILES folder removed.
[18:06:28]JOB: SHINING finished.
Old 13th January 2011, 02:11   #10914  |  Link
Capsbackup
@TheBreen;
Perhaps you could try setting BD-RB to two pass encoding, and remove the selection/checks next to One Pass (CRF) Encoding and One Pass (ABR) Encoding.
Sizing is much more accurate this way.
Old 13th January 2011, 02:46   #10915  |  Link
TheBreen
@TheBreen;
Maybe I should try that, thanks. I have been using Automatic Quality Settings with AUTO_BIAS=2 in the config.
Still, in this case of The Shining, it seems to that any quality settings should produce the same result with target output BD25, because the video does not need to be re-encoded at all to get it under 25GB (or at least that's what I understand from my experiment with a higher custom target output). But I might be missing something...
Old 13th January 2011, 03:09   #10916  |  Link
Voyeurism
My backup with the test build is running overnight - I will hopefully post results in the morning.
Old 13th January 2011, 14:35   #10917  |  Link
Any quality setting should produce the same (or very close) size.
Old 13th January 2011, 14:37   #10918  |  Link
That's disappointing, I thought that was it for sure. I'll pick up "Case 39" today and give it a run. Thanks for helping.
Old 13th January 2011, 15:47   #10919  |  Link
Capsbackup
My pleasure.
I have not used IVTC sources with 3:2 pulldown before, nor do I see many original Blu-rays with this type mpeg2 files, so this is really not a big concern for me. Probably more a concern for you and other users though. Since my backups are played back on my standalone S360, I'm not sure there would be much benefit upon display of this already not real good quality clip.
But I am happy to help test and promote development and features for BD-RB, so count me in as needed!
Old 13th January 2011, 19:34   #10920  |  Link
Voyeurism
The test BD-RB file did not correct the audio out of sync problem on the movie "The Curious Case of Benjamin Button" either.
