Old 1st April 2019, 12:53   #55601  |  Link
Grimsdyke
Originally Posted by DMU View Post
... , but will solve the problem with the duplication of frames.
It's been a while but IIRC what I did to avoid the repeated frames issue when watching old US-DVDs was to choose 'DXVA2 native' in LAV Videodecoder.
Old 1st April 2019, 14:11   #55602  |  Link
Limberjork
Try to use ivtc (force film mode). It will not completely solve problems with combing artifacts in certain spots, but will solve the problem with the duplication of frames.
Yeah looks like this is the answer. I didn't realize that IVTC can't be performed in the automatic mode; I thought the deinterlacer would pick up on the need for it automatically.
Limberjork is offline   Reply With Quote
Old 1st April 2019, 18:51   #55603  |  Link
seiyafan
Originally Posted by clsid View Post
Hi everyone,
I have made an optimized NVIDIA profile for MPC-HC/BE. Might be helpful for those who struggle with the configuration. Try it out.
This is NVIDIA Profle Inspector tool with a profile file and a .bat to import that profile.
Download
Most important settings it uses:
Power management mode = Adaptive
VSync = on
GSync = off
SLI = off
Prefer NVIDIA on Optimus systems
Thanks, your profile and 419.35 GRD fixed the issue on my 1660.
seiyafan is offline   Reply With Quote
Old 2nd April 2019, 09:36   #55604  |  Link
So it would seem like the VSync setting isn't being respected after upgrading or with certain Nvidia driver versions..
Old 2nd April 2019, 19:23   #55605  |  Link
jkauff
A clean install will also wipe out any Control Panel settings.
Old 3rd April 2019, 09:54   #55606  |  Link
Sunset1982
I will do a clean installation of my htpc the next days. Any suggestion which windows version i should use as a stable patform?
I have used Windows 10 build 1809 but had random freezes with madvr/kodidsplayer/lavfilters.
I have an amd rx vega 56 gfx card...
Intel i5 6600, 16 GB DDR4, AMD Vega RX56 8 GB, Windows 10 x64, Kodi DS Player 17.6, MadVR (x64), LAV Filters (x64), XySubfilter .746 (x64)
LG 4K OLED (65C8D), Denon X-4200 AVR, Dali Zensor 5.1 Set
Sunset1982 is offline   Reply With Quote
Old 3rd April 2019, 10:14   #55607  |  Link
Asmodian
Windows 8.1 is still ideal for a madVR box.
madVR options explained
Old 3rd April 2019, 10:20   #55608  |  Link
Sunset1982
Some time ago I read a post from madshi where he wrote some disadvantages of windows 8.1, but I can't find it anymore.
Wasn't there a problem with 10bit hdr and windows 8.1?
Old 3rd April 2019, 13:48   #55609  |  Link
madjock
Not so sure about that, I think it is better as in the overlays side and other bits and bobs are supposed to be not as aggressive if thats the right word, maybe Exclusive is more Exclusive than 10 and the likes, sure HDR was much the same, but simple things like drivers, the Windows 10 ones are not compatible, so you have to try and find Windows 8.1 ones, and you are not sure if they are the same as 10 for issues.
A word of caution though, I thought the same as all I heard was it was better that 10 for this, but I have to say I only had 8.1 on for a matter of hours, a lot was to do with me having a fake monitor due to audio going to my AVR via Display Port, but my god it would not behave and it drove me mad with it jumping about to a fake disply etc.
I also noticed other things, that I cannot even remember now, simple things you take for granted in Windows 10 now, ultimately I put Windows 10 back on and all the problems vanished.
Windows 10-1909 | i5-3570k | GTX 1070 Windforce OC Rev2 8GB : 430.64 | Pioneer VSX-534 | Philips 65PUS6703 - 65"
Old 3rd April 2019, 15:08   #55610  |  Link
win8 can't do WFS 10 bit that's it FSE works totally fine.
madVR uses the API from nvida and AMD so the OS doesn't matter much for HDR what matter if there API are supported on other windows version then 0 which is still the case.
Old 3rd April 2019, 19:07   #55611  |  Link
Grimsdyke
Hi Madshi, there were a few crashes since driver update to Intel-6618 related to the dll below.
callstack crc : $cc12cd00, $3d0d8150, $1a3e20d2
exception number : 1
exception class : Exception
exception message : Access violation at address $7ffe2a28b33d in module 'igd10iumd64.dll'. Write of address $4b886ce0.
Old 3rd April 2019, 21:35   #55612  |  Link
That's all on Intel. Report it to them.
Old 3rd April 2019, 21:35   #55613  |  Link
madjock
Is this not more of a Driver problem than a madVR one, multiple AMD/nVidia drivers have issues and everyone else rolls back or waits for a better driver ?
edit : ah beaten to the punch
Old 5th April 2019, 04:29   #55614  |  Link
TheProfosist
TheProfosist's Avatar
Alright so troubleshooting this has finally completed on my saga of trying to get reasonable video playback again after switching from a GTX1060 to a RTX2060
Originally Posted by TheProfosist View Post
Trying to troubleshoot something. On my HTPC (Win10x64-1809v2, i7-4820K, 32GB ram, RTX2060, 4K HDR Sony TV) I cant seem to get pans to be smooth even though im withing the render times on a per frame basis. I can disable more things to lower it further and it doesn't seem to improve it. Yes smooth motion is on in the when needed but should be needed her 23fps content and display changed to 24fps. It doesnt show dropped or duplicated frames for how stuttery it is. Previously had the 1060 in there no real improvement going to the 2060.
Ideas on troubleshooting this would be helpful. I have tried:
using different decoders in lav filters. Anything other than CUVID just seems worse
MPC-HC versions 1.7.13 and 1.8.4
madVR versions 0.92.14 and now 0.92.17
upgraded the GPU
lower settings from NGU to superxbr to jinc
increasing buffer from 8 to 16 (though im not sure if 6GB vram is enough for this)
I have not completely wiped my madVR settings to see if it does it from scratch since I thought I would post here first to see if someone has ideas.
alright so I have made some progress I started by uninstalling, reinstalling, and reseting MPC-HC and madVR.
The stuttering has mostly been fixed I just get a little blip every now and then say every couple minutes at most. some time during fast actions or pans. I'm not using smooth motion just matching frame rate could this be buffer related? This seems more frequent than the 1 stutter every 4min or so that the madVR UI is suggesting.
I did fix exclusive mode as well.
both the stuttering and exclusive mode seem to have been related to having HDR enabled in Win10 at an OS level.
I have not yet tweaked scaling algorithms or anything like that yet. Just on default settings.
When playing back 4K HDR BD content I'm still getting stuttering on pans that should be smooth. This is with HDR turned off at the OS level and HDR set to pass through. Colors look very muted So I don't think it is actually doing HDR with this setup.
So its looking like most of my issues have been related to HDR.
looking like more HDR related issues then...
That setting was supposed to be flipped to on
I tried forced V-Sync with HDR content with HDR enabled at the OS level and still stuttered. I forced Vsync to On for MPC-HC as well as my madVR folder.
With these forced on and OS HDR disabled the playback is much less stutters but it is still stuttery and the colors are all muted so The display either sint getting HDR or doesn't know it is.
This testing was done playing back 4K HDR BD Content
Thanks to the below chart I no longer have stutter on my HTPC playing back even 4K HDR BD content. 418.91 did indeed fix my issues and large pans in GITS live action and Bladerunner 2049 are not buttery smooth. No random hiccups from 1080p playback on my 4K screen either so Ill now be able to start tweaking my actual settings which I thought were the issue all along. Thanks to the community for the help as always. Suck when I try to chill after work just to have the thing that's supposed to provide relation pissing me off.
Last thing to note is that with Windows 10 OS HDR enabled I still cant go fullscreen exclusive.
Originally Posted by Klaus1189 View Post
I just updated that info here:
https://forum.doom9.org/showthread.php?t=176013
419.67 GRD 2019-03-25 stuttering issues
419.67 CRD 2019-03-20 stuttering issues
419.35 GRD 2019-03-05 stuttering issues
419.17 GRD 2019-02-22
418.91 GRD 2019-02-14 NO stuttering issues
Did anyone test 419.17 about the stutter issues?
TheProfosist is offline   Reply With Quote
Old 5th April 2019, 07:39   #55615  |  Link
katodevin
Glad to hear going back to 418.91 fixes it. I can totally relate. I'm stuck with a 1660gtx that stutters no matter what. Much less with vsync on (every 2-3 min now), but unfortunately I can't go back to 418.x since they don't support the 1660 . I'm really hoping Nvidia figures out what the issue is, but I'm afraid I may have to dump my 1660 if it doesn't get resolved soon.
katodevin is offline   Reply With Quote
Old 5th April 2019, 10:51   #55616  |  Link
stax76
stax76's Avatar
I have a problem which is likely a driver or OS problem, I just want to ask if it's known here and where I should report it, NVIDIA has a support forum, right? I reported it first to mpv, and they told me to test madVR. After I told them it's not working in madVR too they said it's a driver or OS problem. It happens when I do the following:
using Windows 10
using NVIDIA GT 1030 card
dual monitor with duplicate mode
use d3d11 which mpv and madVR use by default
use fullscreen windowed mode
The second screen is broken then, horizontally stretched showing only the left side of the image and everything is green.
Old 5th April 2019, 11:31   #55617  |  Link
working flawless here.
cloning two 1080p screens
windows 17134
1060 419.67
d3d11 windowed and FSE which isn't the default madVR option.
Old 5th April 2019, 12:09   #55618  |  Link
stax76
stax76's Avatar
Thanks for testing. I've forgotten to mention that it happens only in full screen mode. I'm using the latest Win 10 and a driver installed about 3 weeks ago, screens are both UHD.
Old 5th April 2019, 12:46   #55619  |  Link
i tested FSE and WFS.
anything else that comes to mind?
screen scaling?
Old 5th April 2019, 13:19   #55620  |  Link
stax76
stax76's Avatar
Maybe it happens only with UHD but it could be anything, much likely it relates to d3d11, when I use gpu-context=angle in mpv then it's fine. When I extend the screens instead of duplicating it then it's fine as long as I start the player directly on the TV, yesterday I started the player first on the desktop (because the TV wasn't on yet) and moved it to the TV screen afterwards which caused the problem to appear.
