Old 10th January 2017, 17:12   #2821  |  Link
jpsdr
Originally Posted by shekh View Post
If you promise to port some useful filters for rgb planar mode, I can implement it.
Otherwise just having planar source "supported" but immediately converted to packed - is not useful.
No, so indeed, don't bother.
Since original VirtualDub was never hosted publicly, I have no idea about last code base.
If you have it, please share.
Can get it here. That's the last version that has been made avaible a loong time ago already (you can get it only in the forum, now unfortunately closed).
Thanks for your work on this upgraded version.
I've tested only the modes avaibles on the Decode format menu, that's why i've tested 16 bits 4:2:0.
Thanks for the links with all VDubMod version.
jpsdr is offline
Old 10th January 2017, 17:19   #2822  |  Link
pinterf
New test build
Avisynth plus r2372-dev
20170110 r2372dev (vdubmod14 VfW test)
  • New: SSE2/SSE4 for 10-16 bit <-> 10-16 bit Planar RGB (and Alpha plane) full scale conversions
    (needed for automatic planar RGB -> packed RGB VfW conversions)
  • VfW:
  • Fixed: Y3[10][10],Y3[10][16] fourcc's byte order
  • New: Planar RGB(A) (MagicYUV)
    10,12,14,16 bits: G3[0][10], G4[0][10], G3[0][12], G4[0][12], G3[0][14], G4[0][14], G3[0][16], G4[0][16]
  • New: YUV444P16 to fourcc Y416
  • New: Automatic conversion of 12, 14 and float YUV formats to 16 bit for 4:2:0 and 4:2:2
    Note: OPT_Enable_Y3_10_16 is still valid as if format was originally 16 bits
  • New: Automatic conversion of 10, 12, 14 and float YUV formats to 16 bit for 4:4:4
  • New: Conversion of 10, 12, 14 and float planar RGB formats to RGB64
    when global Avisynth variable Enable_PlanarToPackedRGB is true
  • New: Conversion of 8 bit planar RGB formats to RGB24
  • New: Conversion of 8 bit planar RGBA formats to RGB32
    Note: OPT_VDubPlanarHack=true may still be needed for Virtualdub for YUV planar outputs other than YV12 or else U and V planes are exchanged
    Edit: this must affect only 8 bit videos. Fixed in a following release
  • Supported formats:
    BRA[64],b64a,BGR[48],P010,P016,P210,P216,Y3[10][10],Y3[10][16],v210,Y416
  • Default format FourCCs:
    RGB64: BRA[64]
    RGB48: BGR[48]
    YUV420P10: P010
    YUV420P16: P016
    YUV422P10: P210
    YUV422P16: P216
    YUV444P16: Y416
    Planar RGB 10-16 bit: G3[0][10], G3[0][12], G3[0][14], G3[0][16]
    Planar RGBA 10-16 bit: G4[0][10], G4[0][12], G4[0][14], G4[0][16]
  • Global variables to override default formats:
    OPT_Enable_V210 = true --> v210 for YUV422P10
    OPT_Enable_Y3_10_10 = true --> Y3[10][10] for YUV422P10
    OPT_Enable_Y3_10_16 = true --> Y3[10][16] for YUV422P16
    OPT_Enable_b64a = true --> b64a for RGB64
    Enable_PlanarToPackedRGB = true --> RGBP8->RGB24, RGBAP8->RGB32, all other bit depths to RGB64
pinterf is offline
Old 10th January 2017, 17:43   #2823  |  Link
shekh
video data is too short (w*h*6 bytes, should be w*h*8 bytes)
I dont know, who is guilty? The Y3[10][10] output works with magic, but requires hack with avs+
VirtualDub2
shekh is offline
Old 10th January 2017, 17:45   #2824  |  Link
pinterf
It's history.
Comment in avisynth.h:
// Hack YV16 and YV24 chroma plane order for old VDub's
pinterf is offline
Old 10th January 2017, 17:50   #2825  |  Link
shekh
It's history.
Does it mean there is old (bad) VD, and there is new one (which?), where the hack is not needed anymore?
But I have to apply it now, is this expected?
VirtualDub2
shekh is offline
Old 10th January 2017, 20:50   #2826  |  Link
pinterf
1.) OK, Y416 is now really done but cannot test, vdub says: XYUV64 output is not implemented. Using vdubmod 38494.
2.) (plane hack)
It looks something like this in the avs source
// Old VDub wants YUV for YV24 and YV16 and YVU for YV12.
  if (parent->VDubPlanarHack && !vi.IsYV12()) {
    plane1 = PLANAR_U;
    plane2 = PLANAR_V;
  else {
    // Set default VFW output plane order.
    plane1 = PLANAR_V;
    plane2 = PLANAR_U;
pinterf is offline
Old 10th January 2017, 21:39   #2827  |  Link
shekh
"XYUV64 output is not implemented" is message from output (dubbing) part, why you see it?
Has nothing to do with raw/avs input.
I think there is misunderstanding, Y3[10][16] is not 16-bit YV16, it has YUV plane order while YV16 has YVU plane order.
ConvertToYV16()
works (YV16)
ConvertToYV16().ConvertBits(16)
swapped
correct
There is no reason for Y3[10][16] to be affected by VDubPlanarHack since it is brand new fourcc.
VirtualDub2
shekh is offline
Old 10th January 2017, 21:50   #2828  |  Link
pinterf
I just had a look at the log window after clicking on play.
pinterf is offline
Old 10th January 2017, 21:56   #2829  |  Link
shekh
Thanks, I too often forget about play button.
VirtualDub2
shekh is offline
Old 10th January 2017, 22:04   #2830  |  Link
pinterf
O.K. I will then use (vi.IsYV16() || vi.IsYV24())
instead of !vi.IsYV12()
In the 8 bit world the latter was enough.
What about YV411? (Y41B)
pinterf is offline
Old 10th January 2017, 23:42   #2831  |  Link
ajp_anton
ajp_anton's Avatar
Question: why are there two versions of RGB, planar and packed? Does the user really have to know/care which one is used?
ajp_anton is offline
Old 11th January 2017, 01:07   #2832  |  Link
jpsdr
Something came to my mind, i've checked in avisynth.h and didn't see any information about it.
Standard/normal YUV mode is 16..235 for Y and 16..240 for UV. You can have a "full range" mode, but it's "unusual" or not the standard.
VDub has in its color mode a difference for the YUV mode between full range or limited range. I didn't see anything like this in avisynth. Have i missed it (in that case where is it), or is it just that there is not a such thing ?
If there is not something to chose between full or limited range, can we assume that the behavior in this case is the standard/common behavior, meaning the limited range ?
What are the specifications for the extended bit range ? Are they also limited, or are they just only full range by default ?
If limited, how is the range ? Is it proportional (16-240 becomes 4096-61440 in 16 bits) or fixed (16-240 becomes 16-65520 in 16 bits) ?
That make me realise that since the begining, at least the resample and nnedi3 filters are prone to produce incorrect results, as they clip only to 0-255, meaning they can produce out of range values in case of YUV data (but not in case of RGB data, of course).
So, what is exactly the situation about these points ?
jpsdr is offline
Old 11th January 2017, 01:54   #2833  |  Link
TheFluff
Excessively jovial fellow
Avisynth has functions to convert between full and limited range (just pointing that out, because it does seem like you might have somehow missed this) but does not have metadata flagging to keep track of which range a given clip has.
YUV limited range ("TV range") numerical limits for bitdepths above 8 are quite well-defined (see f.ex. the H.264 standard). For any bitdepth, the luma offset is
16 * (2^(bitdepth - 8))
while the range is
219 * (2^(bitdepth - 8))
For chroma, the offset is the same, but substitute 224 for 219 to get the range.
Full range YUV on the other hand isn't well defined at all. It's been discussed extensively in this thread before, see here and a number of posts forward.
TheFluff is offline
Old 11th January 2017, 09:42   #2834  |  Link
jpsdr
Argh.... That is very troublesome, it's a shame something like this have been missed when it should have been present since the begining...
Thanks for the others informations.
jpsdr is offline
Old 11th January 2017, 13:35   #2835  |  Link
pinterf
Originally Posted by tuanden0 View Post
Can someone help me the filter fft3dGPU crashed if I use SetFilterMTMode("FFT3dGPU", 3)
Here is my script:
Reproduced, but cannot help with it.
I tried with this simplified script:
Colorbars(pixel_type="YV12")
FFT3DGPU(sigma=4,bt=3)
Prefetch(6)
Debug log shows, that sometimes this filter requests negative frames.
This was already mentioned, related link:
https://forum.doom9.org/showthread.p...25#post1671525
Debug log with Prefetch(6) until the sad finish, which occured in fft3dgpu.dll when frame number 7 was requested from it.
ColorBars::GetFrame 0
ColorBars::GetFrame 3
ColorBars::GetFrame 2
ColorBars::GetFrame 1
ColorBars::GetFrame -1
ColorBars::GetFrame 5
ColorBars::GetFrame 4
ColorBars::GetFrame 6
ColorBars::GetFrame 7
ColorBars::GetFrame 8
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     2 child=007302F8 frame=0A4BF9E8 vfb=0900AEF8 videoCacheSize=0 SeekTime            :0.068393
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     1 child=007302F8 frame=0A4BF8B0 vfb=006B6D20 videoCacheSize=0 SeekTime            :0.069542
ColorBars::GetFrame 13
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     6 child=007302F8 frame=0A4BFAB8 vfb=0900AEB8 videoCacheSize=0 SeekTime            :0.075657
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     0 child=007302F8 frame=0A4BFA50 vfb=0900C178 videoCacheSize=0 SeekTime            :0.077987
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     4 child=007302F8 frame=0A4BF918 vfb=0900A4F8 videoCacheSize=0 SeekTime            :0.078408
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     3 child=007302F8 frame=0A4BF980 vfb=0900C1B8 videoCacheSize=0 SeekTime            :0.078792
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     5 child=007302F8 frame=0A4BFB20 vfb=0900ADF8 videoCacheSize=0 SeekTime            :0.078573
Exception thrown at 0x02DF1FDA (FFT3dGPU.dll) in AVSMeter.exe: 0xC0000005: Access violation reading location 0x00000000.
Although this filter is set for serialized mode in MT, the frame requests are not sequential in a multithreaded environment. Requested frame numbers can jump randomly back and forward. Maybe this situation is not handled too well in the code, but seeing no source for it I cannot make any further assumption.
This post got a bit long, but interesting to see what happens in the background:
Without Prefetch (non-MT):
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     0 child=090A34B0 frame=005CF580 vfb=08E3F838 videoCacheSize=0 SeekTime            :0.025495
ScriptEnvironment::GetNewFrame NEW METHOD EXACT hit! VideoFrameListSize=      1 GotSize= 460831 FrReg.Size=     1 vfb=08E3F838 frame=005CF580 SeekTime:0.000010
                                          frame 005CF580 RowSize=640 Height=480 Pitch=640 Offset=24
ScriptEnvironment::GetNewFrame returning frame. VideoFrameListSize was 1
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     1 child=090A34B0 frame=005CF580 vfb=08E3F838 videoCacheSize=0 SeekTime            :0.006794
ScriptEnvironment::GetNewFrame NEW METHOD EXACT hit! VideoFrameListSize=      1 GotSize= 460831 FrReg.Size=     1 vfb=08E3F838 frame=005CF580 SeekTime:0.000006
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     2 child=090A34B0 frame=005CF580 vfb=08E3F838 videoCacheSize=0 SeekTime            :0.006903
ScriptEnvironment::GetNewFrame NEW METHOD EXACT hit! VideoFrameListSize=      1 GotSize= 460831 FrReg.Size=     1 vfb=08E3F838 frame=005CF580 SeekTime:0.000016
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     3 child=090A34B0 frame=005CF580 vfb=08E3F838 videoCacheSize=0 SeekTime            :0.006695
ScriptEnvironment::GetNewFrame NEW METHOD EXACT hit! VideoFrameListSize=      1 GotSize= 460831 FrReg.Size=     1 vfb=08E3F838 frame=005CF580 SeekTime:0.000005
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     4 child=090A34B0 frame=005CF580 vfb=08E3F838 videoCacheSize=0 SeekTime            :0.005836
Cache::GetFrame LRU_LOOKUP_NO_CACHE: [FFT3DGPU] n=     5 child=090A34B0 frame=005CF580 vfb=08E3F838 videoCacheSize=0 SeekTime            :0.006020
pinterf is offline
Old 11th January 2017, 15:12   #2836  |  Link
pinterf
New dev build
Avisynth Plus r2380-dev
20170111 r2380
  • Overlay: Modes "Blend", "Luma" and "Chroma" now support all bit depths and 444 conversionless (use444=false) mode
  • Overlay: fix SSE2 Blend for mask+opacity for 10-16 bits
  • VfW: (vdubmod14 VfW test)
    Fix: YUV444P16 or YUVA444P16 to fourcc Y416
    if alpha channel is present, it will we copied, else filled with FFFF
    Fix: VDubPlanarHack is checked only for 8 bit YUV planar sources
Now practically all color formats can be shown in vdubmod. If a specific bitdepth does not exist, it will be converted on-the-fly, and some alternative output formats can be hinted with OPT_xxx variables.
For details see readme.
(I'd like to separate github releases from these 'daily' builds. Albeit this version is quite usable, there were huge refactorizations and earthquake e.g. in Overlay, so I'd like to wait a bit more)
pinterf is offline
Old 11th January 2017, 18:50   #2837  |  Link
The "user" may not care. But a programmer has to. Planar formats have an important advantage to process video filters fast, but it is completely different to the way the video memory stores pixels displayed on screen.
Planar RGB (components can be kept in separate memory blocks, the same pixel will have the same offset in all components, needs to be calculated only once per pixel):
RRRR...RRRR
GGGG...GGGG
BBBB...BBBB
Packed RGB24 (please notice that memory addresses aligned to 32-bit structures = DWORD are addressed most efficiently in 32-bit systems):
(R,G,B)(R
G,B)(R,G
B)(R,G,B)
Packed RGB32 (to align pixels with 32-bit addresses, a fourth byte is inserted which may contain an alpha value – or be ignored, which wastes RAM):
(R,G,B,A)
(R,G,B,A)
(R,G,B,A)
LigH is offline
Old 11th January 2017, 19:13   #2838  |  Link
TheFluff
VS only supports packed RGB for backwards compatibility with Avisynth and for output. Internally in a filtering framework there is no reason whatsoever to ever use packed. Just unpack on input and pack on output if you have to - my gut feeling says that for any but the most trivial filters that's going to be insignificantly slower than filtering packed (and you can drop a dumb extra code path too). There are most likely no particularly useful or interesting RGB only filters anyway, so breaking things shouldn't be a big deal.
TheFluff is offline
Old 11th January 2017, 22:45   #2839  |  Link
ajp_anton
ajp_anton's Avatar
But what is the point then in using packed in Avisynth, which is about processing video, not displaying it? If the input serves packed, then immediately "unpack" it. And pack it again for the output if needed.
Is there any reason for the user to ever convert to packed RGB? And if there are rare cases, why not just have one type of planar "ConvertToRGB24" (/32/48/64) function, and require "packed=true" for packed? It's easier to remember from previous experience that RGB48 is 16-bit per component RGB without alpha, than remembering whatever the name of the planar versions are (tried to google them for this post, but didn't find them fast enough). Having everything the same type (planar?) makes things easier for the user.
Old 11th January 2017, 23:09   #2840  |  Link
Many VfW compatible tools don't support planar RGB. They can't handle it. It was not supported by Microsoft in a blank installation of most Windows versions (I am not even sure if there are any supporting VfW codecs as of today). I would even believe, if the semi-pro home users did not insist in it, hardly any professional software company would have cared about it... So, for ancient compatibility's sake, AviSynth still must be able to output packed RGB. The most compatible way of displaying images in Windows, DIB = "Device Independent Bitmaps", was invented with packed-pixel RGB and palette formats only, AFAIK. Planar RGB is a rather recent invention, I believe...
YUV based formats are useful for real-life content, whereas RGB based formats are common for computer generated content. Just imagine screen recordings of a game or an application's user interface. Recording that in a YUV based format, especially with the most common 4:2:0 chroma subsampling and TV range, would limit the color saturation and chrominance resolution, blurring and fading 1-pixel wide colored lines.
LigH is offline
