28th June 2017, 05:55 | #1641 | Link |
HI , I am new to tsMuxeR and it tried to remove some audio tracks from M2TS file to edit my bluray. After i remove the track i just made .ISO. It played on my computer but did not play on bluray player. No video.
I used default settings . Is there any setting i should select, I just want to remove unwanted audio tracks from M2TS file. leave others untouched. thanks |
22nd July 2017, 03:05 | #1642 | Link |
Try with tsmuxer to create bluray folders, and replace m2ts, clpi, mpls, inserting them into the original bluray structure, renaming the files as originally, using hexadecimal editor for the playlist mpls, writing the original m2ts number inside
31st July 2017, 17:24 | #1643 | Link |
Broadcast Encoder
I have an Apple ProRes master that I have to encode to HEVC 50fps progressive 20'000 kbit/s 10bit, audio AC3 384 kbit/s stereo to broadcast.
I now have both the .hevc video file and the .ac3 audio file, but when I try to mux it to .ts using tsmuxer it says "frame rate not found" and specifies 23.976fps by default. Unfortunately, I can't change it in the GUI, 'cause it offers me 24, 25, 30, 23.976 or 29.970 fps only. I would like to mux it to 50 fps. |
31st July 2017, 21:13 | #1645 | Link |
Broadcast Encoder
Yep, I know, I generally send XDCAM 50Mbit/s .mxf for 1080i contents (MPEG-2) but in this case they want a .ts with HEVC and some specific settings. I guess that their workflow isn't ready for the conversion (yet) and they just have playout ports to play contents and air them. Anyway, I remuxed it with ffmpeg.
21st August 2017, 15:00 | #1646 | Link |
Hi everybody
I'm trying to remux the Prometheus 3D bluray into "main movie only"-iso. I'm using tsMuxeR version 2.6.9. as I've learned in another thread that the later versions should have certain issues. Anyways, as a lot of you know, the left-right eye order is swapped on this particular disc. So I check the "Use base videostream for right eye" box, but the result still has the wrong eye order. Now I can swap the order manually during playback of course, but maybe someone knows why this does not work? I thought this option was to be able to correct swapped eye order? Thanks in advance |
21st August 2017, 18:49 | #1650 | Link |
I appreciate your help, but can you do a little walk-through here? This is the first time I'm using a hex-editor and I don't understand.
I have been able to open the right .mpls file. And I think I understand "hexidecimal 40". Please say, you mean the one addressed between "3F" and "41", right? From here I'm lost. Please can you explain further what to do? Thanks in advance Edit: Did you get my reply on the pm, ocean? Can't find any copy in my sent box Last edited by von Suppé; 21st August 2017 at 19:58. |
12th October 2017, 10:20 | #1654 | Link |
Life's clearer in 4K UHD
Indeed... It's such a shame. I hope he's happy, well and okay...
7th December 2017, 22:27 | #1659 | Link |
Matroska find' ich toll
Today I have installed a clean Linux Mint 18.3 and tsMuxeR(2.6.11) don't run anymore.
In Linux Mint 18.1 it works. To be sure I have installed a Linux Mint 18.2, and tsMuxeR also don't work. Can someone confirm these? |
