28th December 2005, 22:49 | #241 | Link | |||||||||||||
28th December 2005, 22:58 | #242 | Link | |
29th December 2005, 13:27 | #243 | Link | |
n00b in trouble
TextSub is different, because it can work with text subs like SRT, SSA and ASS without losing formatting. VobSub can't do that as far as I know. Last edited by mulrich; 29th December 2005 at 13:32. |
29th December 2005, 15:01 | #244 | Link |
29th December 2005, 17:38 | #246 | Link | |
n00b in trouble
EDIT: Now I just need to be able to add multiple subtitle tracks Last edited by mulrich; 29th December 2005 at 22:58. |
30th December 2005, 00:22 | #248 | Link | ||
30th December 2005, 01:23 | #250 | Link |
In the main menu choose Help and select Send Bug Report.
30th December 2005, 05:05 | #251 | Link |
will not create a report that way either so i will manual enter what it says...
System Exception:AVIFileOpen failed at staxrip.avifile.open(string filename) at staxrip.avisynthdocument.synchronized() at staxrip.avisynthdocument.GetFramerate() at staxrip.globalclass.solvemacros(string value) at staxrip.info.getmacros() at staxrip.globalclass.sendbugreport(exception ex) think thats got it...really hope that helps |
30th December 2005, 13:16 | #252 | Link | |
n00b in trouble
30th December 2005, 15:57 | #253 | Link | |
@Nrmf
Thanks for your endurance, I much appriate it. I can't promise you we will solve it until I got such a system but as long as people send debug info I'll work on it. I just got a report by another 64 bit user. Here is the next build: http://www.planetdvb.net/staxrip/StaxRip_Hotfix.zip Quote:
30th December 2005, 17:19 | #254 | Link |
I've been using Staxrip for a couple days now. Few comments.
- Would be nice if the Staxrip window wasn't "frozen" while the program is running jobs. Hard to tell how many jobs are remaining this way. - Be able to set it to just use 1 audio file instead of two if it detects two in folder. And be able to set it to only use AC3 files. - Staxrip's auto crop is pretty poor. I've seen it crop huge parts of the top/bottom. It seems far too agressive. I've set mine up to use the Autocrop filter in the Filters flow (autocrop(mode=0,wmultof=4,hmultof=4,samples=10, aspect=-1,threshold=34,samplestartframe=1000,leftadd=0,rightadd=0,topadd=0,bottomadd=0) ). I got the latest autocrop too, the one used in AutoGK as well. (Maybe that's what's causing the prog probs?) I used AutoGK's parameters as a guide but set aspect=-1 so it doesn't change the aspect of the input. Using this causes annoying delays when Staxrip accesses the filter stream (autocrop looking at frames), but it's acceptable because it crops extremely well. - I added a "Precise Bicubic" (BicubicResize(x,y,0,0.75)) option. According to avisynth faq it's the same config as VDub's Precise Bicubic. I've actually found it gives a better picture than Lanczos with these noisy TV DVDs and a Xvid HT NTSC setup. Precise Bicubic looks arguably better than using RemoveGrain(mode=2)+Lanczos in my testing. And it's faster. Obviously this is personal pref. Bitrate ~1100. TIVTC is a fantastic filter btw. Might be a good addition. A lot faster than decomb and works very well with hyrids even. Last edited by swaaye; 30th December 2005 at 17:27. |
30th December 2005, 18:39 | #255 | Link | |||||
ConvertToYV12().AutoCrop(mode=2) Quote:
field.Fiters.Add(New AviSynthFilter("Field", "Deinterlace", "FieldDeinterlace()", True)) field.Fiters.Add(New AviSynthFilter("Field", "Fast Deinterlace", "SeparateFields().SelectEven()", True)) field.Fiters.Add(New AviSynthFilter("Field", "IVTC", "Telecide(guide=1).Decimate()", True)) resize.Fiters.Add(New AviSynthFilter("Resize", "Sharp", "LanczosResize(%target_width%,%target_height%)", True)) resize.Fiters.Add(New AviSynthFilter("Resize", "Neutral", "BicubicResize(%target_width%,%target_height%,0,0.5)", True)) resize.Fiters.Add(New AviSynthFilter("Resize", "Soft", "BilinearResize(%target_width%,%target_height%)", True))
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 30th December 2005 at 18:42. |
30th December 2005, 19:48 | #256 | Link | ||
30th December 2005, 19:55 | #257 | Link | |
As to the other parameters he used, I don't know what the exact purpose is. I'm guessing that they optimize the crop to fit better within codec resolution limitations (hence the multiples of 4). He has 'hMultOf' set to 4 instead of the default of 2. His slightly higher threshold of 34 (from 30) is probably to help autocrop be more sensitive with a wide range of sources (dirty/clean). I set the the sample start frame to 1000 because I thought frame 0 would just be blank anyway so would be pointless. Last edited by swaaye; 30th December 2005 at 19:57. |
30th December 2005, 20:14 | #259 | Link | ||
gui, h.264, h.265, hevc, mkv, x264, x265 |
