Old 22nd December 2008, 19:00   #21  |  Link
Smurf1127
Thanks. I was wondering, is anyone else having an audio sync issue when doing mkv to avi? The mkv that I am trying to convert has two audio streams (jpn and eng). I want to keep the eng audio, so in the Detected Audio Tracks drop down I select the eng track, and hit encode to avi. Once everything is done, I play the newly created avi file and the video looks good, but there is a big sync issue (the audio is off ~ 10 sec.). Please advise if I could have a setting incorrect somewhere, or the best course of action to fix this issue. If you need to log that is created, please let me know and I can provide that too. Thank you again for your help, and thanks to the coder of this application for their hard work.
Smurf1127 is offline   Reply With Quote
Old 3rd January 2009, 10:52   #22  |  Link
oldjoe911
You should upload your tool to some free upload website, even rapidshare would work better than this. It's impossible to download and try your tool as it is now.
oldjoe911 is offline   Reply With Quote
Old 3rd January 2009, 11:37   #23  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
I uploaded it to rapidshare.
Old 10th January 2009, 12:16   #24  |  Link
Glorioso
I'm going to do some use of your tool, seams very nice. The AVCHD tool also adds subtitles?
Glorioso is offline   Reply With Quote
Old 10th January 2009, 18:41   #25  |  Link
deank
deank's Avatar
You better use multiAVCHD for MKV files. Yes, subtitles are supported.
Old 10th January 2009, 19:24   #26  |  Link
Glorioso
And it converts the file to 720p or 1080p 16:9?
Old 10th January 2009, 19:37   #27  |  Link
deank
deank's Avatar
What is it that you ask exactly?
Feed it with 40 MKV files and you will get AVCHD folder to copy to USB and play in your Playstation/BD player.
Old 10th January 2009, 20:35   #28  |  Link
Glorioso
I'm Portuguese and sometimes it's difficult to me...
Imagen i have a file, 720p but it is 1280x688, the program convert it to 1280x720 and makes bluray subtitles from the srt files?
Old 10th January 2009, 20:49   #29  |  Link
deank
deank's Avatar
It won't make it x720... But if you're using PS3 it will play.
You have 2 options: reencode with mkv2avi to AVi with subtitles via AVIADDXSUBS or create AVCHD folder with multiAVCHD.
Old 10th January 2009, 22:24   #30  |  Link
Glorioso
Didn't know PS3 accepted files without x720. I'll try it latter, MKV2 AVI works fine, only problem is the subs, it wont star aviaddxsubs, i had to star it manualy.
Old 15th January 2009, 11:48   #31  |  Link
Sharro
Xvid Tribalistic Fan
I'm always getting calclib.dll cannot be found/loaded error even though it's in the program folder "Tools".
Any help appreciated.
I've downloaded and installed the full package as per "readme.txt" and I'm running on Windows XP SP3.
All the best,
Sharro
Sharro is offline   Reply With Quote
Old 15th January 2009, 16:57   #32  |  Link
deank
deank's Avatar
calclib.dll needs to be in your executable path or in your windows path. check its file size - it has to be 1*525*760 bytes.
Old 20th January 2009, 03:13   #33  |  Link
Crono141
Stupid Question: how do I pick the subtitle track to use to make sure it comes out on the target avi?
Crono141 is offline   Reply With Quote
Old 17th March 2009, 13:03   #34  |  Link
deank
deank's Avatar
Does anyone still use this tool?
Old 18th March 2009, 09:31   #35  |  Link
bigdaddykane
deank i just came across it and gonna try it out m8.thanks.
bigdaddykane is offline   Reply With Quote
Old 11th April 2009, 23:12   #36  |  Link
deank
deank's Avatar
Full download is now updated to latest build 2.2.101.
--- If you got problems with previous download - RE-DOWNLOAD. (12-April-2009).
Old 2nd June 2009, 16:16   #37  |  Link
deank
deank's Avatar
For questions and support please visit:
http://multiforum.deanbg.com/viewtopic.php?f=4&t=4
Old 16th March 2010, 17:57   #38  |  Link
deank
deank's Avatar
I think it is time to add mkv2avi.exe to multiAVCHD package... It got some nice 'upgrades' like ETA and preview... There is no need to download 20-30MBs when it can be part of the whole package with all of my tools:
Current version is 2.3 build 104.
Download multiAVCHD 4.0 - mkv2avi is included in the package.
Dean
Old 23rd January 2011, 03:10   #39  |  Link
Ingram
About to try this tool I hope it works for me. Want to convert some 720P MKV's to AVI for playback on my grandmothers DVD Player which does AVI.
Ingram is offline   Reply With Quote
mkv2avi, mkvtoavi, multiavchd, tsmuxer
