Old 14th November 2019, 14:47   #8021  |  Link
FreaQ
Starfish
FreaQ's Avatar
I hope someone can help me here:
I am authoring a Blu-Ray with a static menu which plays fine in VLC on Win10.
When I am trying to start the BD in Kodi on Amazon Fire TV 4k Kodi just hangs. It does not matter if it is an ISO or a folder structure.
FreaQ is offline   Reply With Quote
Old 8th March 2020, 21:48   #8022  |  Link
rs008f
I get this error when loading AVS scripts. [AVS] Cannot detect script properties!
I followed this tutorial on installing multiavchd on Windows 7 64bit. http://multiforum.deanbg.com/viewtopic.php?f=7&t=17
multitest passes all tests. The avs script loads fine on VirtualDub.
How do I get multiavchd to work with avisynth?
rs008f is offline   Reply With Quote
Old 9th March 2020, 19:40   #8023  |  Link
malimuc
malimuc's Avatar
Open multiAVCHD with administrators rights.
best regards
malimuc is offline   Reply With Quote
Old 12th May 2020, 18:41   #8024  |  Link
DMD
DMD's Avatar
Good evening.
I ask if multiAVCHD supports the UHD standard.
because when I import the folder "BDMV" I don't see the message if I want to "switch to the Blu-reay re-author mode"
Any advice, thanks.
DMD is offline   Reply With Quote
Old 28th June 2020, 22:08   #8025  |  Link
digicube
best regards
I still get same error. [AVS] Cannot detect script properties!
I will install Windows XP in a virtual machine and run multiavchd there to see if it'll solve my problem.
digicube is offline   Reply With Quote
Old 29th June 2020, 01:07   #8026  |  Link
digicube
Same error in virtual machine Windows XP, even though the script runs fine in VirtualDub. I get missing opencl.dll, msvcp110.dll, msvcr110.dll when running multitest, even though it pass all tests except VC-1. What's a good AVCHD authoring software that supports Avisynth scripts these days?
Old 30th June 2020, 04:42   #8027  |  Link
digicube
multiavchd crashes when authoring MKV with subtitles. Any idea what's causing it? I tried both avisynth 2.5.8 and 2.6. 2.5.8 crashes with Kernelbase.dll error.
Problem Event Name: APPCRASH
Application Name: avs4x264.exe
Application Version: 0.0.0.0
Application Timestamp: 4b508a64
Fault Module Name: avisynth.DLL
Fault Module Version: 2.6.0.6
Fault Module Timestamp: 551a3368
Exception Code: c0000005
Exception Offset: 000130b1
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Got multiavchd to work by deleting my avisynth plugins folder.
Old 30th June 2020, 05:11   #8028  |  Link
digicube
Spoke too soon. avs4x264 still crashes but muiltiavchd can still continue if I click the error message away.
Old 30th June 2020, 05:45   #8029  |  Link
digicube
Got multiavchd to work on a fresh install of windows 10, no crashes so far. Must be my avisynth setup on my Windows 7 machine that is causing the crashes.
Old 4th July 2020, 20:49   #8030  |  Link
fezaterka
hello dean, how i make to the srt or sup not delay the subs?
fezaterka is offline   Reply With Quote
Old 31st December 2020, 03:09   #8031  |  Link
oopsie
Problems installing multiAVCHD under WIndows 10
I have used multiAVCHD under Windows 7 but that machine died. I got a new machine that is Windows 10 based, installed multiAVCHD and all its requisite tools using (METHOD 1) http://multiforum.deanbg.com/viewtopic.php?f=7&t=17 as a guide. I have also tried (METHOD 2) http://adubvideo.net/how-to/setup-pr...-chain-windows as a guide.
I cannot enable top menus (via Author tab) and I fail multiTEST's VC-1 check.
I have reset the machine (Settings / Update & Security / Recovery / Reset this PC / Remove everything) to this version:
Edition Windows 10 Pro
Version 20H2
Installed on ‎12/‎26/‎2020
OS build 19042.685
Experience Windows Feature Experience Pack 120.2212.551.0
and tried installation from this clean install (avisynth, ffdshow, haali, multiAVCHD using both METHOD 1 and METHOD 2, resetting the machine each time, with the same result: cannot enable top menus nor pass multiTEST's VC-1 check.
I suspect that if I can pass multiTEST's VC-1 check, I can enable top menus in multiAVCHD but I have no clue what multiTEST is trying to do or what it is looking for, so no idea what is missing in my system.
Has anyone out there had this problem and managed to resolve it?
Thanks in advance.
oopsie is offline   Reply With Quote
Old 2nd January 2021, 21:13   #8032  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
What is your VC-1 decoder ?
You may use Win7DSFilterTweaker to find out.
Using LAVFilters here.
Hm, depending on your settings multiAVCHD might use ffms2.dll, I have ticked that.
Old 15th February 2021, 11:45   #8033  |  Link
tebasuna51
tebasuna51's Avatar
Maybe the 00000.mpls is corrupt, upload the file.
Old 16th February 2021, 15:30   #8034  |  Link
tebasuna51
tebasuna51's Avatar
Because forum rule 6 we can't help over downloaded content.
Old 17th February 2021, 13:34   #8035  |  Link
tebasuna51
tebasuna51's Avatar
Here is a mp related to my previous answers to deleted post by the user:
Originally Posted by alex74.744
thanks, I understood what you meant about point № 6
here is a copy from a licensed disk, the same problem:
license disk:
I sugest to alex74.744 upload the problematic 00001.mpls
Maybe any multiAVCHD user can help.
Old 2nd March 2021, 16:10   #8036  |  Link
alex74.744
alex74.744's Avatar
File 00001.mpls
File Type: zip 00001.zip (511 Bytes, 42 views)
alex74.744 is offline   Reply With Quote
Old 3rd March 2021, 15:42   #8037  |  Link
Emulgator
Emulgator's Avatar
220 playlists. Playlist obfuscation ? Cyrillian letters in path ?
Old 4th March 2021, 22:44   #8038  |  Link
alex74.744
alex74.744's Avatar
thank you, I removed the Cyrillic alphabet and the error disappeared. But I noticed this, the program does not see some audio roads:
Old 4th March 2021, 22:48   #8039  |  Link
alex74.744
alex74.744's Avatar
but it happens that audio tracks are not detected and it is not possible to understand which audio track needs to be deleted, since there is no country designation
Old 5th March 2021, 00:25   #8040  |  Link
Emulgator
Emulgator's Avatar
Maybe it is better to let MakeMKV handle the fixing of playlists, then go from that MakeMKV remux.
Will try that with my disc soon (if it is about MIB 3, that is).
Ah, I see, my disc is different, only 3 audio languages, and a comparable huge number of playlists.
It does not look like obfuscation, the many copyright stills, warnings and other nags just make up for that.
00800.mpls is the main feature here.
Which MIB disc are we talking about ?
avchd, blu-ray hd-dvd, mkv, multiavchd, re-author
