9th March 2009, 12:47 | #61 | Link | |
Matroska find' ich toll
i have tested somthing an found 0 errors. In the Box "Mode" SUP->SUP better you call this SUP->DVD.SUP maybe hubble Last edited by hubblec4; 9th March 2009 at 12:51. |
9th March 2009, 17:01 | #62 | Link | |
Author of BDSup2Sub
It's a "BD-SUP to BD-SUP" conversion actually. As discussed in the online help, it's meant to e.g. convert a BD-SUP from 1080p to 720p. Since BD-SUPs are the only SUPs supported by BDSUp2Sub, I thought this was pretty obvious. I'll edit the history though. |
9th March 2009, 17:49 | #63 | Link | |
I test your new version again and when i found some bugs i report this... hubble |
10th March 2009, 21:09 | #65 | Link |
Special SeeD
The program works great .
I just have a little request, the option to resize subs to 1440x1080p, it's a Bluray compilant resolution helpful for movies too hard to compress at FullHD 1920x1080p (if you don't want to use 720p). . Thanks for your hard work. |
10th March 2009, 22:43 | #66 | Link | |
Author of BDSup2Sub
10.03.2009 1.6 -> 1.7
11th March 2009, 23:40 | #67 | Link |
Author of BDSup2Sub
Me again...
11.03.2009 1.7 -> 1.8
12th March 2009, 02:16 | #68 | Link | |
Special SeeD
13th March 2009, 13:52 | #69 | Link |
Author of BDSup2Sub
13.03.2009 1.8 -> 1.9
13th March 2009, 15:10 | #71 | Link |
Thanks for the sup to sup conversion however I haven't gotten them to display while playing when muxing with tsmuxer. I've tested both resizing and not resizing, powerdvd 8 and mpc-hc. The sup I posted earlier also shows this issue. Could you look into this?
SupRip before the rewrite (I think it was 1.10 or earlier) handles these same sup files ok except some characters are skipped over and I gave up tweaking suprip after about 10 minutes. SupRip versions after rewrite crash on these files but I've seen this happen quite often with the later versions. Also any chance of a wildcard string for input via command line? e.g. java -jar bdsup2sub.jar C:\sups\* /res:720 would resize all sup files in C:\sups\ to 720 and adding 720 to each filename during output rack04: there's an example .sup I posted in this thread from a full movie you can mux that with any video as a test if that's what you are looking for. p.s. as megaupload seems to be gaining popularity is there any specific reason for preferring it with a silly captcha and wait times, which reminds me of old rapidshare without the speed limiting which raipdshare still has, over one without all this extra stuff like sendspace or mediafire? |
13th March 2009, 15:32 | #72 | Link | ||||
Author of BDSup2Sub
java -jar bdsup2sub.jar C:\sups\*.sup c:\sups\*_720.sup /res:720 Quote:
13th March 2009, 16:18 | #73 | Link |
Maybe you could compare what BDSup2Sub at 720p outputs from the sup I uploaded earlier to what BD-Rebuilder outputs at 720p to help debug it? (beware that BD-Rebuilder has bad alignment while BDSup2Sub has good alignment)
Even a lot of retail sups I've tried crash the latest SupRip versions, have you tried SupRip 1.01 or earlier? Your wildcard suggestion makes more sense. Sendspace I prefer these days, it seems to have very good routing throughout the world and no captcha, wait, speed limit (it says it does but it doesn't), 300 MB max file size, basic online file manager and a standalone app that supposedly can resume and upload multiple files but I've never tried it. Mediafire is another good one but it has a popup window, 100 MB file limit (if it ever matters), not the greatest routing, probably < 95% uptime, and it has just a basic online file manager. I've come across some other ones that are 'clean' but I can't remember the names. Last edited by turbojet; 13th March 2009 at 16:20. |
13th March 2009, 19:53 | #74 | Link | |
Author of BDSup2Sub
Besides, BD-Rebuilder cheats around this issue by not touching any important data at all. It only patches the screen size and offsets and doesn't even touch the image data. Since it doesn't change any package length with this attempt, it doesn't need to recalculate the PTS/DTS time stamps and simply copies them. Anyway, this of course means that the subtitles appear quite a bit larger in a downscaled 720p, because they are scaled up together with the video picture. Apart from the fact that I mixed SubRip and SupRip, I think I know what crashes SupRip, but I honestly think that this is an issue with the RLE decoding there (accepts EOL only if the line is complete - which contradicts the idea of RLE compression). So while I think I could change my exports to satisfy SupRip, I'd rather see SupRip fixing this issue. Last edited by 0xdeadbeef; 13th March 2009 at 21:54. |
14th March 2009, 06:50 | #75 | Link |
Yup BD Rebuilder texts are huge after resizing to 720p which is annoying, hopefully that's fixed soon.
Ya I agree that it's SupRip's responsibility to fix it as the issue goes way beyond BDSup2Sub output. My current fix is to not upgrade, unfortunately this is a fix that is becoming more and more common these days with various software. |
15th March 2009, 08:00 | #76 | Link | |
Special SeeD
Original Sub: http://rapidshare.com/files/209412308/BRSup.rar IDX/VobSub: http://rapidshare.com/files/209412099/VobSub.rar MKVMerge Error Code: Code:
Warning: spu_extraction_duration: Encountered broken SPU packet (next_off < start_off) at timecode 00:55:09.556. This packet might be displayed incorrectly or not at all. Warning: spu_extraction_duration: Encountered broken SPU packet (next_off < start_off) at timecode 01:07:35.676. This packet might be displayed incorrectly or not at all. |
15th March 2009, 15:41 | #77 | Link |
too much lurking
Same here.
http://forum.doom9.org/showthread.php?t=145416 I thought it was an issue with mkvmerge. It doesn't seem to affect playback though. |
15th March 2009, 16:48 | #78 | Link | |
Special SeeD
15th March 2009, 19:17 | #79 | Link |
Author of BDSup2Sub
Hm, I converted the "Spanish.sup" and loaded it into SubtitleCreator. Can't see any overlaps there. Can you? Does any other SUB/IDX tool display overlaps?
Then again, this problem might be related to the fact that BDSup2Sub currently is a little relaxed when it comes to creating time stamps. Indeed, BDSup2Sub currently doesn't care for the target frame rate and simply uses a millisecond time stamp, no matter what the output frame rate is. A multiplexer might stumble over this as the timestamps (and display durations) are supposed to be multiples of a frame duration. If they are not, rounding up an end time and rounding down a start time to the next multiple of the frame duration might indeed lead to the same value of start and end. Which however is still no overlap. Anyway, I already started reworking BDSup2Sub to always work with the 90KHz time ticks and synchronize the time stamps to the target frame rate. I'm not completely convinced though that this will resolve this issue in all cases (especially when there's also a speed up/down involved). |
16th March 2009, 17:08 | #80 | Link |
I haven't had any luck converting .sup to .idx using the command line. Here is the command line that I'm using:
java -jar "C:\Program Files\BDSup2Sub\BDSup2Sub.jar" "C:\Personal\Videos\DELSCENE1.sup" "C:\Personal\Videos\DELSCENE1.idx" /lang:en /res:480 However if I use the user interface I'm able to convert the .sup to .idx no problem. |
