Old 12th February 2016, 07:44   #181  |  Link
rock
I get error "Input string was not in a correct format"
file: http://a.pomf.cat/fersvc.mkv (got from mpv issue tracker)
I use gMKVExtractGUI v1.6.4, MKVToolNix 8.5.0 64-bit, on Windows 8.1
I can open it and extract with latest MkvExtractGUI-2
regards
rock is offline   Reply With Quote
Old 12th February 2016, 07:59   #182  |  Link
gpower2
gMKVExtractGUI author
gpower2's Avatar
Thank you very much for the feedback!
I found the bug, it happens when the mkv file has only one chapter entry!
I will shortly release a bug fix version!
Thanks again
P.S.
It looks like it's the same bug that johnsonlam had reported.
gpower2 is offline   Reply With Quote
Old 12th February 2016, 12:04   #183  |  Link
gpower2
gpower2's Avatar
gMKVExtractGUI v1.6.5
New version 1.6.5 is out, fixing a notorious bug that affected all files that contained only 1 chapter entry! It also incorporates new "cues" extraction mode for more advanced users of mkvtoolnix, and also a new chapter type, CUE, that automatically converts XML chapters to CUE sheet format.
Download link:
https://sourceforge.net/projects/gmk....5.7z/download
Changelog:
  • Fix parsing the number of chapter entries in case there is only one chapter entry (thanks johnsonlam, rock)
  • Change gMKVToolnix to gMKVToolNix
  • Add new extraction mode "cues" (thanks bin_ch)
  • Add new Chapter Type "CUE" which transforms XML chapters to Cue Sheet (thanks isidroco)
Enjoy!
Old 14th February 2016, 10:35   #184  |  Link
bin_ch
Thanks for the new version.
One bug report concerning Cue Sheet output:
The INDEX are wrong for chapter entries whose ChapterTimeStart exceed one hour, for example, 01:05:00.0000 should be 65:00:00, but gets written as 05:00:00
bin_ch is offline   Reply With Quote
Old 14th February 2016, 11:35   #185  |  Link
gpower2
gpower2's Avatar
Thanks for the feedback bin_ch!
Indeed I forgot to add the hours from the chapter to the minutes of the cue sheet format. I'll fix it in the new version.
I'd also like to ask you if you checked the new cues extraction mode.
Thanks again!
Old 14th February 2016, 12:04   #186  |  Link
bin_ch
Oh yeah, forgot to mention that. Tried the cues extraction and it's working great. Thank for implementing it.
Old 15th February 2016, 16:23   #187  |  Link
gpower2
gpower2's Avatar
gMKVExtractGUI v1.6.6
New version 1.6.6 is out, fixing a bug in the CUE Sheet format chapters, and also incorporating support for older versions of MKVToolNix (v4.x).
Download link:
https://sourceforge.net/projects/gmk....6.7z/download
Changelog:
  • Fix minutes in Cue Sheet Chapter Format (thanks bin_ch)
  • Add support for older mkvtoolnix versions (v4.x)
Enjoy!
Old 16th February 2016, 14:01   #188  |  Link
hubblec4
Matroska find' ich toll
Hi gpower2
For what these two entries are used?
REM GENRE ""
REM DATE ""
GENRE and DATE are not listed in the specs.
Old 16th February 2016, 14:34   #189  |  Link
gpower2
gpower2's Avatar
Originally Posted by hubblec4 View Post
Hi gpower2
REM GENRE ""
REM DATE ""
According to digitalx.org, "REM" is a recognized command and according to the wikipedia sample here:
https://en.wikipedia.org/wiki/Cue_sh...ting)#Examples
Genre and Date are commonly used comments in cue sheet for CD's.
That's why I included them, in order to make it easier for the user who edits the file afterwards.
Old 16th February 2016, 15:00   #190  |  Link
hubblec4
Thanks for this info. I will implement it too.
Old 6th March 2016, 17:18   #191  |  Link
wanezhiling
dvb sub in mkv is not suuported?
sample: https://www.sendspace.com/file/0s21qa
Old 6th March 2016, 21:01   #192  |  Link
gpower2
gpower2's Avatar
It seems that mkvextract does not like CODEC_ID S_DVBSUB...
It's a question that should be asked in the MKVToolNix thread here: http://forum.doom9.org/showthread.php?t=155732 , since gMKVExtractGUI is just a GUI for mkvextract and doesn't contain the actual demuxing code.
Old 13th March 2016, 19:25   #193  |  Link
TalasNetrag
Enhancement request: Could you use a label at the bottom of the window, to signal that the demuxing was successful (instead of the popupbox) and use the popupbox for errors?
TalasNetrag is offline   Reply With Quote
Old 13th March 2016, 21:06   #194  |  Link
gpower2
gpower2's Avatar
I can't find a valid reason to change the default behavior. What use case do you have in mind?
Old 14th March 2016, 12:04   #195  |  Link
Solon8
I actually had the same thought yesterday. The only reason would be to gain some (very little) time, users are lazy. There's just no need for a popup when it's successful.
Solon8 is offline   Reply With Quote
Old 26th March 2016, 16:15   #196  |  Link
wanezhiling
http://i.imgur.com/1VhyyNH.png
Something is wrong with today's MKVToolNix v9.0.0...
Old 26th March 2016, 16:19   #197  |  Link
gpower2
gpower2's Avatar
It appears that this change:
Originally Posted by Mosu
A change a lot of users of Windows and Mac OS will hopefully welcome is that mkvinfo launches with its GUI by default now unless the option "--no-gui" is given. Users of these two OSes often start mkvinfo by clicking on the executable instead of using start menu entries making adding the parameter "--gui" somewhat difficult. The behavior for other OSes has not been changed.
invokes MkvInfo executable with the GUI and not the cli.
I'll upload a new version fixing the problem ASAP.
Thanks for the instant feedback!
Old 26th March 2016, 20:27   #198  |  Link
Telion
Second this, needing to close a popup every time is becoming a bit irritating. It is a common GUI design guideline that informational messages should go into a status bar in an unobtrusive way. Only errors should invoke a modal dialog box to specifically attract user's attention to the fact that his intent was not accomplished and he must take some further actions.
Telion is offline   Reply With Quote
Old 26th March 2016, 23:29   #199  |  Link
Wildfire
It's not just that it's a pop-up (as a matter of fact, I get two pop-ups), it adds a huge delay to opening a file with gMKVExtractGUI. I have to wait a while for the first mkvinfo to do its work, then I close it, another mkvinfo window pop ups which then takes a while analysing my file...
Well, I'll just wait for the updated gMKVExtractGUI to see if that fixes it.
Wildfire is offline   Reply With Quote
Old 27th March 2016, 11:14   #200  |  Link
alfixdvd
In MKVExtractGui-2 occurs the same.
alfixdvd is offline   Reply With Quote
extractor, gmkvextractgui, matroska, mkv, mkv extract, mkvextract, mkvextractgui
