Go Back   Doom9's Forum > (HD) DVD, Blu-ray & (S)VCD > Advanced authoring
Old 13th November 2019, 19:15   #41  |  Link
stax76
Originally Posted by ChaosKing View Post
I noticed that CTRL+C does not cancel DGDemux in powershell. I have to wait until 100%
I did some research and found this:
https://docs.microsoft.com/en-us/win...ndler-function
Old 13th November 2019, 20:14   #42  |  Link
videoh
Useful n00b
"Do you need the mpls or some other files?"
I need the full decrypted BD structure (send PM for FTP details), or a link to purchase the exact same BD. Thank you.
Old 13th November 2019, 20:23   #43  |  Link
ChaosKing
PM send.
This is maybe not a DGDemux problem, but I can not import/open the extracted .pcm audio file in mkvtoolnix.
Tools like DVDFab can save to mkv with pcm audio.
Or maybe DGDemux could save it as wav? pcm = raw wave audio without a header, correct?
EDIT:
The audio filenames have a space before the name " PID 1101 fra DELAY 0ms.pcm"
VapourSynth Portable FATPACK || VapourSynth Database || https://github.com/avisynth-repository
Old 13th November 2019, 20:45   #44  |  Link
videoh
Useful n00b
Great, thank you. I can look into all those things when I have the BD.
Old 13th November 2019, 22:58   #45  |  Link
videoh
Useful n00b
I figured out the problem with the missing video. You can get it with -demux 1011 (for example). Will make a quick fix. I'd still like the BD for the other issues. Thank you.
Old 13th November 2019, 23:03   #46  |  Link
videoh
Useful n00b
OK, please re-download 1.0.0.1 to get the video demux fix.
Old 13th November 2019, 23:17   #47  |  Link
videoh
Useful n00b
You need to have a name appended to the -o path as described in the user manual. Suggestions for improved syntax are welcome.
Old 13th November 2019, 23:39   #48  |  Link
videoh
Useful n00b
You can use
taskkill /IM DGDemux.exe /F
for now until I do something about it. Or just use a CMD shell.
Old 13th November 2019, 23:55   #49  |  Link
stax76
or:
stop-process -name dgdemux
Old 14th November 2019, 03:48   #50  |  Link
videoh
Useful n00b
Much more elegant. Thank you.
Old 14th November 2019, 10:55   #51  |  Link
hubblec4
Matroska find' ich toll
Hi videoh
I had forgotten to ask for the most important feature which I need for chapterEditor to create Mulit-Edition-mkvs.
With eac3to is it possible to use the m2ts files as input and only so I can create such mkvs.
Your info about a mpls file need an extension to show all the used m2ts files.
In eac3to I can append all the m2ts-path with a "+".
chapterEditor || Matroska-Playback || hSplit || DiscShare
Old 14th November 2019, 13:22   #52  |  Link
redbtn
redbtn's Avatar
1) It would be nice to have some indication of completed process, like "done". Just "100" a little weird IMO.
4) It would be nice to have option to demux files to directory where cmd is located (instead of setting output directory directly). Like "E:\Films>dgdemux -i input-dir\00800.mpls -newoption" demuxing to E:\Films
5) What is it means (it doesn't return E:\Films\Endgame>), that i open a project? Why i can't use just -demux 1101 then? This is a bit confusing.
Ps: sorry for my English, it may be a little confusing, I'm still learning.
redbtn is offline   Reply With Quote
Old 14th November 2019, 15:11   #53  |  Link
videoh
Useful n00b
Originally Posted by redbtn View Post
2) Why video file named ".265", not " PID xxxx"?
3) Why space simbol at the beginning of all other names except the video file? Like " PID 12a0 eng.sup"
Please give the exact command line that produced that. I remind you that the -o path is not just a directory path. It is a directory path plus a name. See the manual.
I cannot understand you and the pngs are not approved. Please use a hosting site and explain much better. Thank you.
Old 14th November 2019, 15:57   #54  |  Link
redbtn
redbtn's Avatar
My mistake, I missed it, now it works fine.
It doesn't return "E:\Films\Endgame>" I don't know how to explain that better)
Old 14th November 2019, 16:27   #55  |  Link
videoh
Useful n00b
Thank you for the clarification. You are noting that the shell prompt is not issued after DGDemux terminates. This has been addressed earlier in the thread. DGDemux runs asynchronously to the shell.
@all
I am noting your UI and feature requests, for which thank you very much. I remain focused short term on sync matters.
Old 17th November 2019, 02:57   #56  |  Link
videoh
Useful n00b
Version 1.0.0.2 is released. For details and a link see here:
http://rationalqm.us/board/viewtopic...p=10246#p10246
Old 17th November 2019, 11:29   #57  |  Link
hubblec4
Thanks for the new version.
"* Added a -sf option to skip the first M2TS (and adjust the chapters) for disks such as Naked Alibi."
This sound interesting. I use such function in chapterEditor, because many BDs have a "fake" first or/and last m2ts which has different stream settings.
What does DGDemux if the last m2ts file is a fake m2ts file?
Maybe is a new flag a good idea
-sl -> skips the last m2ts
-sfl -> skips the first and the last m2ts file
Old 17th November 2019, 13:54   #58  |  Link
videoh
Useful n00b
Last M2TS is always accepted. Can you point me to such a disk?
Old 17th November 2019, 14:55   #59  |  Link
hubblec4
I have seen a lot of BDs with a very short last M2TS with one video stream only.
I check the duration of such M2TS files, but I guess you has a better function to check the differences between the other files.
Here is a sample full BD structure with 2 M2TS files. 00004 is a 20mb chunk of the main file and 00005 is the last M2TS(untouched).
Here an Amazon link.
Old 17th November 2019, 17:21   #60  |  Link
videoh
Useful n00b
Thank you. I will probably add a -sl (skip last) option as you suggested.
