Old 18th January 2010, 23:16   #21  |  Link
Nemesis7
Does matroska support tagging like mp4box does? It would be great to be able to put all of the movie information (title, director, plot, rating, etc.) and the movie poster into 1 file.
Nevermind: it does support tagging. Any manual on this?
Peace.
Nemesis7 is offline   Reply With Quote
Old 19th January 2010, 05:23   #22  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
Foobar2000 is able to write mkv tags. But no cover. But I think support for this tags in mediaplayers is not so good.
Keiyakusha is offline   Reply With Quote
Old 24th February 2010, 19:47   #23  |  Link
blackEyEz
Could the OP be updated for HD audio like true-hd and DTS-HD? More mkv's are released with hd-audio and im having big problems with Haali in this matter.
blackEyEz is offline   Reply With Quote
Old 24th February 2010, 22:32   #24  |  Link
Inspector.Gadget
Doom9 FAQs don't cover pirated content as a rule.
Inspector.Gadget is offline   Reply With Quote
Old 21st July 2010, 16:18   #25  |  Link
jasonwc
MKVMerge can now merge SUP subs as well.
Also, you can remux your own purchased BDs with TrueHD and DTS-HD MA, so such discussions don't necessary relate to piracy. Not all countries have laws similar to the US, such that breaking a DRM scheme to make a personal copy isn't necessary a violation of the law.
jasonwc is offline   Reply With Quote
Old 21st July 2010, 16:22   #26  |  Link
Inspector.Gadget
Key word: "released". Nobody here disputes the right of people to back up media they own, and in fact such an update would be useful for dealing with such files made legitimately.
Old 21st July 2010, 18:05   #27  |  Link
SeeMoreDigital
Life's clearer in 4K UHD
SeeMoreDigital's Avatar
The FAQ could do with information about HD audio stream compatibility in hardware playback devices.
Particularily clarification regarding the, one audio stream per audio track limitation.
Cheers
Old 21st July 2010, 18:13   #28  |  Link
Keiyakusha
契約者
Keiyakusha's Avatar
You mean that we can't have THD+core as one track? This is mkvmerge limitation, not matroska.
Old 11th October 2010, 07:46   #29  |  Link
szabi
Hi
Are there any program to edit tag info in mkv?
Of course with no remuxing necessity.
Bye
szabi
szabi is offline   Reply With Quote
Old 21st October 2010, 07:49   #30  |  Link
szabi
It looks like no way.
Old 21st October 2010, 09:01   #31  |  Link
sneaker_ger
You can do it using mkvtoolnix.
Use mkvmerge GUI > File > Header Editor or "mkvpropedit" over the command line.
Old 21st October 2010, 18:28   #32  |  Link
szabi
Yeah, it is working.
Thanx.
Old 6th November 2010, 04:02   #33  |  Link
Lincoln Burrows
Lincoln Burrows's Avatar
Have you guys had a hard time trying to put any MPEG-2 contents into a MKV container? I think Youtube is not recognizing these kinds of files, and I am unable to convert this thing properly. In this case, it was some extra featurette from a DVD converted by MakeMKV. I will look into this thoroughly, but I was wondering if MKV really supports MPEG-2.
"Whoever has not known himself has known nothing. But whoever has known himself has simultaneously achieved knowledge about the depth of all things."
Lincoln Burrows is offline   Reply With Quote
Old 6th November 2010, 06:29   #34  |  Link
szabi
I did it some months ago and there was no problem with it, but i did not check whether youtube can use it or not.
bye
szabi
Old 8th November 2010, 16:57   #35  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Yes, it does.
Older versions of Haali Media Splitter had no problems with MPEG-video in Matroska.
Old 22nd November 2010, 08:41   #36  |  Link
DMD
DMD's Avatar
Good morning.
Briefly explain the problem I have found
My goal is to be included in the MKV container stream of the DVD.
To do this I am currently experimenting PGCDemux to extract video and audio stream, use DVDSubEdit also to extract forced subtitles. After use mkvmerge to make the final muxing
I noticed this problem:
Why is the subtitle stream format ".sup" demuxed from DVD (DVDSubEdit) is not loaded and that on the Blu-ray disc is loaded normally?
sup file from DVD demuxed
sup file from Blu-ray demuxed
thanks
my PC with Ryzen 7950X
DMD is offline   Reply With Quote
Old 22nd November 2010, 17:48   #37  |  Link
sneaker_ger
Those are essentially different formats. mkvmerge can use .idx/.sub style subs, though.
Have you taken a look at makemkv?
It decrypts and copies the main movie (with all audio and subtitle tracks) to an mkv container in a single step and it's free for DVDs.
Old 23rd November 2010, 08:24   #38  |  Link
DMD
DMD's Avatar
This is true, however, one must consider an important question:
As far as forced subtitles, these are inserted nell'autoryng in two different ways,
A-independent stream
B-integrated stream
MakeMKV only works well with an independent stream.
As for the integrated stream, they are integrated into the main stream of the subtitles, you must follow a different procedure.
1 - to perform the procedure with completav MakeMKV selecting subtitles.
2 - demux the streams with MKVExtractorGui2
3-Drawing of the forced flow with BDSup2Sub
4 - remuxing with mkvmerge Streams
Performing the test I noticed that integrating the subtitles in srt format, instead sub / idx,
the quality of the subtitles is better.
What say you should follow the standard DVD (sub / idx) srt or you can enter without problems?
sub/idx Original DVD
srt
THANKS
Old 23rd November 2010, 08:30   #39  |  Link
sneaker_ger
Yes, too bad players don't allow to play only the forced part of a subtitle track in mkv, while they can do it for dvds.
Old 23rd November 2010, 08:35   #40  |  Link
DMD
DMD's Avatar
Sorry for the off topic question, if you want to answer I posted here
http://forum.doom9.org/showthread.php?t=158023
faq, matroska
