Old 4th December 2008, 19:32   #21  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
mencoder -vf harddup,crop=320:176:0:0,scale=288:160 -sws 2 -aspect 1.7727 -of rawvideo -o autox264.h264 -nosound -ovc x264 -x264encopts crf=18:threads=auto:bframes=3:direct_pred=auto:me=hex:subq=6:frameref=3:weight_b:trellis=2:mixed_refs:level=4 -sub "/home/****/Desktop/test.srt"  "/home/****/End of the World 1.MP4.m4v"
mencoder -mc 0 -noskip -aid 1 "/home/****/End of the World 1.MP4.m4v" -ovc copy -oac faac -faacopts br=96:mpeg=4:object=1 -channels 2 -af volnorm=2 -of rawaudio -o autox264.aac
MP4Box -add autox264.h264 -fps 30.000 -add autox264.aac "/home/****/Desktop/test.mp4"
And it seems that my player was reading the subtitle files from the same directory, because the name was the same for both files. That would explain why I thought it was working earlier. I just have to rename my output mp4 to something different and the subs are no longer picked up externally.
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline   Reply With Quote
Old 8th December 2008, 17:42   #22  |  Link
khaoohs
I get an error when trying to pass a VIDEO_TS.ifo file to autox264.
http://pastebin.ca/1279739.
offtopic:
I'm just setting up a linux box for x264 encoding, so I"m new to this. I'm looking for single app encoding, so I'm also playing with handbrake.
khaoohs is offline   Reply With Quote
Old 8th December 2008, 18:59   #23  |  Link
buzzqw
HDConvertToX author
your mencoder build is probably outdated
please add the job to queue, then paste here the job
maybe b-adapt or psy-rd
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
Old 12th December 2008, 03:14   #24  |  Link
khaoohs
buzz,
Sorry for not explaining it better. My initial problem was that I selected a VIDEO_TS.ifo file I had previously ripped to my hd. Then it autocropped the enitre frame, taking 720 from the top and 480 from the right. I have now manually cropped it am running an encode. We'll see what happens.
This may have *too* many options for me as I'm a noob to x264 encoding.
Is it possible for me to select a mkv container instead of mp4?
Old 12th December 2008, 08:27   #25  |  Link
buzzqw
HDConvertToX author
autox264 "actually" support only mp4
maybe in a future update i will support even mkv
BHH
Old 19th December 2008, 11:30   #26  |  Link
buzzqw
HDConvertToX author
update windows AND linux version (same link as above)
a little better resizing
added mkv support
added info on mencoder build used
BHH
Last edited by buzzqw; 23rd December 2008 at 11:30. Reason: update linux build too
Old 23rd December 2008, 11:29   #27  |  Link
buzzqw
HDConvertToX author
(actually for windows.. later for linux)
added support for MeGui X264 profile's
in the same place as autox264.exe create a folder "profiles", copy in "profiles" all xml files from megui x264 profiles's
BHH
Old 24th December 2008, 09:57   #28  |  Link
buzzqw
HDConvertToX author
windows update
rearranged gui
added support for saving program path
linux build will follow later
BHH
Old 24th December 2008, 10:52   #29  |  Link
yeye69
is it open source?
yeye69 is offline   Reply With Quote
Old 24th December 2008, 11:30   #30  |  Link
buzzqw
HDConvertToX author
yes, gpl v3
source code, in purebasic, is avaiable on request
BHH
Old 24th December 2008, 15:08   #31  |  Link
buzzqw
HDConvertToX author
update the linux build too
BHH
Old 25th December 2008, 01:03   #32  |  Link
Adub
Adub's Avatar
Sweet!! Thanks for the MeGUI profiles support. I can't wait to get back home after break and play with this thing on my 64-bit Sabayon build.
Site:Adubvideo
Old 25th December 2008, 09:31   #33  |  Link
buzzqw
HDConvertToX author
please report any errors
BHH
Old 25th December 2008, 09:53   #34  |  Link
mocham
Thanks for the MeGUI presets addition. Why aren't the presets listed in alphabetical order in your drop down list?
mocham is offline   Reply With Quote
Old 25th December 2008, 10:06   #35  |  Link
buzzqw
HDConvertToX author
.. maybe i must rework the parsing profile directory
EDIT: update the linux build, fixed the alphabetical order of profiles
BHH
Old 25th December 2008, 13:25   #36  |  Link
yeye69
If I create a shortcut on the desktop and/or run autox264 from other directory than where autox264 installed, there is no profiles. This is a bug or a feature?
Old 25th December 2008, 14:48   #37  |  Link
buzzqw
HDConvertToX author
it's look like a bug to me
windows or linux ?
BHH
Old 25th December 2008, 23:39   #38  |  Link
mocham
Same issue here. Linux version, with Gnome desktop environment. If I make a launcher in the Gnome menu then I don't see the presets, if I run it from the directory I put the binary then the presets are there.
Thanks for fixing the preset drop down sort order! This is an awesome frontend!!
Old 26th December 2008, 09:57   #39  |  Link
buzzqw
HDConvertToX author
fixed not profiles found when lauching auto264 from a link (thanks to yeye69 and mocham)
BHH
Old 26th December 2008, 14:58   #40  |  Link
yeye69
It works, thanks!
But I'm confusing with a cropping. If I want to omit crop values, do I put 0 in these values or width x height? I need some clarity on this question.
gui, linux, mencoder, windows, x264
