Old 22nd October 2016, 11:54   #39801  |  Link
jerryleungwh
Sorry guys, my new algo needs some more tweaking time. Maybe 1-2 weeks more, I don't know. Quality is constantly improving, though. Performance seems ok, but will require a decent GPU.
Will be back to answer all open questions/comments when the new algo is completed.
Really looking forward to the next update, but how decent is "decent"? Sadly I only have a 960m GPU so do I get any benefit from the update?
jerryleungwh is offline   Reply With Quote
Old 22nd October 2016, 12:14   #39802  |  Link
A 960 is considered decent. But it all comes down to what exactly it is. If it's post processing then you'll be adding it on if it's an upscaler then you'll be replacing what you're already running (I would assume) so it's hard to know. You may just need to dial things back a tad, it's all just wild speculation at this point, just wait I'm sure he'll comment on the performance of it on release.
Old 22nd October 2016, 13:25   #39803  |  Link
CarlosCaco
I have two systems one laptop with a 930m and a desktop with a GTX 570 overclocked from factory
By what I see in brnchmarks the 960m is similar to my GTX 570, a little bit slower...
I think it's pretty decent on resolutions up to 1080, with some limitations... even with 930m that's a lot weaker I can use sxbr and refinements...
Sadly almost all maxwell mobile versions are stacked to optimus that bottleneck a lot perfomance... but still can do a lot of things...
But if you think in upgrade your system with the money you can buy a gamer laptop you can build a much better desktop rig
Desktop, i5 2500, 8GB, N570 GTX TF III PE/OC
Asus X555LF, i7-5500U, 6GB Ram, Nvidia 930m/HD 5500
Windows 8.1 Pro x64
CarlosCaco is offline   Reply With Quote
Old 22nd October 2016, 17:08   #39804  |  Link
Ignus2
I'm looking for 16-bit RGB fccs, and I also looked inside the madVR.ax binaries to learn something, and I noticed something odd. The order of FCCs and later their namings(?) are as they appear in the file:
FCC  - Meaning(?)
RGB0 - RGB48LE
0RGB - RGB48BE
b48r - b48r
RBA@ - RGB64BE
@RBA - RGB64LE
b64a - b48a
Aren't RGB64BE/RGB64LE mixed up for their fccs?
Just thought I'd report, I might be totally wrong, so if this is a false alarm, just ignore my post.
Greets,
I.
http://magicyuv.com - MagicYUV: a new fast lossless video codec for the 4K and multi-core era...
Ignus2 is offline   Reply With Quote
Old 22nd October 2016, 20:08   #39805  |  Link
bcec
I am getting ~8ms hit when using latest nvidia drivers in Windows 10 x64 with anniversary update (nvidia driver version 375.57). 368.81 is the latest driver I've found that doesn't have that extra hit. Is this a known issue? I downloaded the drivers from nVidia's site.
bcec is offline   Reply With Quote
Old 22nd October 2016, 21:31   #39806  |  Link
AngelGraves13
Change from Optimal to Adaptive for Power Management.
AngelGraves13 is offline   Reply With Quote
Old 22nd October 2016, 21:51   #39807  |  Link
bcec
^ that did it, thank you!
Old 23rd October 2016, 00:09   #39808  |  Link
TimAhKin
Anyone has memory leaks when going full screen? I'm using PotPlayer.
I have a 390x GPU with 16.10.2 driver version.
TimAhKin is offline   Reply With Quote
Old 23rd October 2016, 03:00   #39809  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
I started getting jagged and aliased edges... no idea why...
I'm not sure what I updated, did an entire windows reinstall. Nvi drivers official, and latest windows. Some edges are jagged / there is a ton of image error that wasn't there before the reinstall and it's persistent with all madVR settings (even though some settings seem to alleviate it).
Should I install the nvidia driver from official manufacturer, or what would solve this?
Georgel is offline   Reply With Quote
Old 23rd October 2016, 07:40   #39810  |  Link
I probably wouldn't use the very latest nvidia drivers. Try one or two versions back using a clean install. Reset madVR to defaults if you must.
Old 23rd October 2016, 08:25   #39811  |  Link
Betroz
Is this for real?
Betroz's Avatar
The 368.81 drivers from nVidia are good.
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
Old 23rd October 2016, 09:02   #39812  |  Link
well known.
http://bugs.madshi.net/view.php?id=431
Old 23rd October 2016, 23:12   #39813  |  Link
foozoor
foozoor's Avatar
Some 4chan morons would like to sue madshi:
http://boards.4chan.org/g/thread/57186738
And it seems that another one released all the madshi's algorithms for fun:
http://boards.4chan.org/g/thread/57186738#p57194586
foozoor is offline   Reply With Quote
Old 23rd October 2016, 23:29   #39814  |  Link
sneaker_ger
http://boards.4chan.org/g/thread/57186738#p57207398
*yawn*
Now madshi will waste time reading 4chan instead of developing next version thanks to you...
Old 23rd October 2016, 23:34   #39815  |  Link
pirlouy
_
Nothing serious in there. And they don't have Madshi's algorithms, but just Open Source algorithms Madshi put in madVR, and I'm quite sure he respects licences since there have already been discussion about it in the past.
Old 23rd October 2016, 23:58   #39816  |  Link
foozoor
foozoor's Avatar
Did you look at this archive?
https://0x0.st/eqp.txz
There is everything, even the deringing algo!
Old 24th October 2016, 01:20   #39817  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
Sometimes I think Madshi should open a thread just for updates and info but keep it locked so only he can post in it.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
Sparktank is offline   Reply With Quote
Old 24th October 2016, 05:06   #39818  |  Link
jkauff
So what? Is someone going to release a version that costs less than madshi's? It's been free for way too long.
There are thousands of us waiting to send madshi money when he finally releases the 1.0 version. He's not going to suffer.
Old 24th October 2016, 07:21   #39819  |  Link
Looks like they don't even know what they're talking about IMO. Waste of time.
Old 24th October 2016, 09:28   #39820  |  Link
ashlar42
I think it looks too sharp. NNEDI3 isn't the one to beat anyway, it's super-xbr AR.
Do you mean super-xbr anti bloating? What's AR? Sorry for the stupid question.
