Old 26th March 2010, 01:35   #4981  |  Link
claymic
Hi dean. I enconde a movie in mpeg2 for blu-ray and a avc. The movie was The lord of the rings 1. The image in avc was much better than in mpeg. I have a projector panasonic pt ae4000, its a excelente projector, and i test this file in 112" (AR 2.40). The avc file was very best than mpeg.
If you need help with language-translation (english x portuguese-Brazil), i can help.
Clayton
claymic is offline   Reply With Quote
Old 26th March 2010, 03:01   #4982  |  Link
flaviometal
By creating ONLY TITLE-LIST menu.
Untick [x] Create top menu and select only [x] Add title list menu (or the classic one) (AUTHOR tab)
Dean
Thanks for the reply, dean, but it doesn't work. If I untick this options, it will create only a title list menu. I want the XMB menu, but without the buttons (and with the selectable thumbs).
If I can remember well, in earlier versions (3.0) this was possible.
flaviometal is offline   Reply With Quote
Old 26th March 2010, 03:04   #4983  |  Link
laserfan
Aging Video Hobbyist
In case you wish to transcode - always 'visit' the [transcode] window.
I see. Yes, that is part of what I've been missing.
Supported subtitles for SD-DVD are external + internal (mkv). If you import BD/HD-DVD/AVCHD structure you need to import subtitles manually as external tracks.
Apparently also one needs to convert subtitles (to 720x480p/29.97/etc) also before attempting to use, at least, it's not working and I'm ending-up with (for this short 5 min cartoon) a single VOB file and zero byte VIDEO_TS.IFO and no other files.
[20:54:03] Creating SD-DVD structure...
[20:54:03] Converting subtitles to DVD format...
[20:54:03] Converting D:\multiAVCHD Temp\multiTEMP-20100325\00002 - 4 - Subtitle (PGS), English, 99 captions.sup to SUP (java:BDsup2sub)...
[20:54:03] *** Imported subpictures: 99/99 at offset 0x00
[20:54:03] Applying pulldown...
[20:54:08] Authoring DVD structure...
[20:54:11] Cannot detect file size: (E:\multiAVCHD\AVCHD-20100325-203941\[DVD]\PRESTO\VIDEO_TS\VIDEO_TS.IFO) (RS:0)
[20:54:11] SD-DVD muxing failed!
[20:54:11] SD-DVD muxing completed!
Will try it again without subs tomorrow...
Old 26th March 2010, 04:11   #4984  |  Link
Adub
Fighting spam with a fish
Adub's Avatar
deank,
Quick question. Does the output "TV System" under the General section of the Author tab have any affect when dealing with HD to SD-DVD conversions?
Edit: Question number 2!: What would you recommend for a user to do when converting to from HD to SD-DVD when the main movie is split up over multiple files?
(ex: 01.m2ts and 02.m2ts contain the main movie)
Should I load up the sources using the "AVCHD / BDMV / DVD folders" import, or is there an even easier way of doing it without having to remove all of the unnecessary playlists after import?
FAQs:Bond's AVC/H.264 FAQ
Site:Adubvideo
Adub is offline   Reply With Quote
Old 26th March 2010, 05:42   #4985  |  Link
setarip_old
setarip_old's Avatar
@Adub
Hi!
You could use "tsMuxeR" to first join the 2 .m2ts files...
Old 26th March 2010, 06:31   #4986  |  Link
Adub
Adub's Avatar
Yeah, I thought about that, but I wondered if there was a way to do it purely in multiAVCHD. The reason is that I'm writing up a tutorial on encoding Blu-ray material to DVD and I want the reader to be able to handle pretty much any content through the main program.
If there is not an easy way, then oh well.
In addition, I know that this splitting happens a lot with HD-DVD's, which I'm not sure if tsmuxer can handle. I do know that multiAVCHD handles HD-DVD's so I was wondering if it was possible to automatically join main movie files.
Edit: Okay, well another attempt at converting Inglorious Bastards Blu-ray to DVD has failed. Here are the logs.
[20:09:11] Initialising...
[20:09:11] Checking for new version...
[20:09:11] You have the latest build.
[20:09:11] Consistency check finished!
[20:09:11] Initialization finished. multiAVCHD is ready!
[20:09:11] 1 year and 89 days since multiAVCHD was published.
[20:09:11] 263 people supported it with donations
[20:09:11] and you are the 1335472 one to launch the program...
[20:09:11] Support multiAVCHD to extend its features and keep it going!
[20:09:11] multiAVCHD.dat version: [04000733]
[20:49:04] Checking for available space and drive types (FAT32/NTFS)...
[20:49:05] Destination [C:]: NTFS, 101109.08 MiB (98.739 GiB) free space
[20:49:05] Temp folder [c:]: NTFS, 101109.04 MiB (98.739 GiB) free space
[20:49:05] Log started for multiAVCHD v4.0 (build 741)
[20:49:05] Selected output mode: DVD player (DVD R/RW disc)
[20:49:05] Processing one title...
[20:49:05] Processing (D:\Multimedia\BluTemp\ING_BASTERDS\BDMV\STREAM\00010.m2ts)...
[20:49:05] This title is marked for reencoding / uncropping...
[20:49:05] Encoding process may take 10 min to 10 hours, so be patient...
[20:49:05] *** Initiating video encoding:
[20:49:05] *** Original : 1920x1080
[20:49:05] *** Crop : 0
[20:49:05] *** Resize : 720x480
[20:49:05] *** Uncrop to : 720x480
[20:49:05] *** Sharpen : 0
[20:49:05] *** Bitrate : 3096 kbps
[20:49:05] *** Frame rate: Original (23.976)
[20:49:05] *** Profile : SD-DVD (MPEG-2)
[20:49:05] *** Encoding : One pass - content: [02:32:59] (MPEG-2 encoder: QuEnc)
[22:46:58] *** Speed : 31.11 fps (elapsed: 01:57:53 - Realtime x 1.3)
[22:46:58] *** Transcoding successful!
[22:46:58] Detected video: ID#0:V_MPEG-2 720x480, fps=23.976
[22:46:58] Display properties: 853x480 (AR:1.78)
[22:46:58] DTS-HRA, DTS-MA will not be reencoded.
[22:46:58] Encoding dts audio to AC3...
[22:47:11] Retrying...
[22:47:21] eac3to refused to convert audio!
[22:47:21] Trying to demux audio...
eac3to v3.16
command line: "C:\multiAVCHD\tools\eac3to\eac3to.exe" "D:\Multimedia\BluTemp\ING_BASTERDS\BDMV\STREAM\00010.m2ts" 3: "c:\multiavchd\_temp\multitemp-20100325\00010.m2ts.t2.ac3" -resampleTo48000 -384
M2TS, 1 video track, 3 audio tracks, 5 subtitle tracks, 2:33:00, 24p /1.001
1: Chapters, 34 chapters
2: h264/AVC, 1080p24 /1.001 (16:9)
3: DTS Master Audio, English, 5.1 channels, 24 bits, 48khz
(core: DTS, 5.1 channels, 24 bits, 1509kbps, 48khz)
4: DTS, Spanish, 5.1 channels, 24 bits, 768kbps, 48khz
5: DTS, French, 5.1 channels, 24 bits, 768kbps, 48khz
6: Subtitle (PGS), English
7: Subtitle (PGS), Spanish
8: Subtitle (PGS), French
9: Subtitle (PGS), Spanish
10: Subtitle (PGS), French
[a03] The ArcSoft and Sonic decoders don't seem to work, will use libav instead.
[a03] The libav DTS decoder doesn't decode the full DTS-HD information. <WARNING>
[a03] Extracting audio track number 3...
[a03] Extracting DTS core...
[a03] Decoding with libav/ffmpeg...
[a03] Remapping channels...
[a03] Resampling to 48khz...
[a03] SSRC doesn't like these resampling parameters. <ERROR>
[a03] You can switch to r8brain instead by using the "-r8brain" option.
Aborted at file position 1048576. <ERROR>
Tsmuxer is now running, and going nuts. The image below is just a sample, but imagine it scrolling past and super high speed.
Site:Adubvideo
Old 26th March 2010, 08:45   #4987  |  Link
deank
Programmer (or just 教务长)
deank's Avatar
Originally Posted by Adub View Post
deank,
1) TV system setting defines the framerate and the resolution for the transcoding. With PAL you'll get 720x576@25fps and with NTSC you'll get 720x480@23.976.
2) You can load the playlist (.mpls file) for the movie in multiAVCHD just like you do it in tsMuxeR.
Dean
Old 26th March 2010, 10:21   #4988  |  Link
pixiesoft
Originally Posted by pixiesoft View Post
Sorry about the first post guys. You can delete it as I am a dumb ass and didn't see this thread!!!
I am using MultiAVCHD to make a compilation BD-R of recorded WWII footage and have followed the online tutorial but I cannot get it to play on my Blu Ray Player.
Here are my steps.
1. Start MultiAVCHD
2. Click on AVCDH/BDMV/DVD Folders Tab and add 10 .mkv files.
3. Author Tab has Stricter AVCDH Folder Format Ticked (Also tried unticked).
4. Everything else left as default.
5. Click Start
6. Let it build the folders BDMV, CERTIFICATE, HDAVCTN & files details.txt, multiAVCHD.log, multiAVCHD.mpf.
7. Burn all folders and files with IMGBURN
8. Put BD-R in BD Player and looks like it is going to play but then just stops with a blank screen.
Have I missed something here? My BD Player is a Panason DMP-BD35
Update on my problem!
Strangest thing is I used the Create AVCHD Stricter mode and NOT any Blu Ray Player and burned the files and hey presto all is fine! Happy Days, I just wish I didin't have 10 coasters sitting around here. wrap em up for chrimbo prezzies I think!
pixiesoft is offline   Reply With Quote
Old 26th March 2010, 11:12   #4989  |  Link
daberti
Deank, i keep on having an eac3to error....
[18.08.03] Log started for multiAVCHD v4.0 (build 740)
[18.08.03] Selected output mode: DVD player (DVD R/RW disc)
[18.08.03] Processing one title...
[18.08.03] Existing I:\MultiAVCHD\AVCHD\AVCHD\ cannot be used as destination folder!
[18.08.03] Output will be written to: I:\MultiAVCHD\AVCHD\AVCHD-20100325-180803
[18.08.04] Processing PLAYLIST (full mode) (split/join) (I:\BluRay\Il Gladiatore\BDMV\PLAYLIST\00002.mpls)...
[18.08.04] Generating meta file for tsMuxer...
[18.08.04] M2TS stream split set at 45000MiB...
[18.08.04] SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
[18.08.04] Detected resolution: 1920x1080
[18.08.04] Detected video: V_MPEG4/ISO/AVC (TID#4113)
[18.08.04] Only this video track will be used!
[18.08.04] Detected media file: 00135.m2ts
[18.08.04] Detected media file: 00146.m2ts
[18.08.04] Detected media file: 00137.m2ts
[18.08.04] Detected media file: 00149.m2ts
[18.08.04] Detected media file: 00138.m2ts
[18.08.04] Detected media file: 00151.m2ts
[18.08.04] Detected media file: 00140.m2ts
[18.08.04] Detected media file: 00150.m2ts
[18.08.04] Detected media file: 00139.m2ts
[18.08.04] Detected media file: 00154.m2ts
[18.08.04] Detected media file: 00145.m2ts
[18.08.04] Detected media file: 00155.m2ts
[18.08.04] Detected media file: 00132.m2ts
[18.08.04] Detected media file: 00148.m2ts
[18.08.04] Detected media file: 00141.m2ts
[18.08.04] Detected media file: 00157.m2ts
[18.08.04] Detected media file: 00136.m2ts
[18.08.04] Detected media file: 00156.m2ts
[18.08.04] Detected media file: 00142.m2ts
[18.08.04] Detected media file: 00158.m2ts
[18.08.05] Detected media file: 00143.m2ts
[18.08.05] Detected media file: 00159.m2ts
[18.08.05] Detected media file: 00144.m2ts
[18.08.05] Detected media file: 00152.m2ts
[18.08.05] Detected media file: 00147.m2ts
[18.08.05] Detected media file: 00153.m2ts
[18.08.05] Detected main PI#000: 00135.m2ts, Duration: [00:17:13.782], [PTS: 00:00:11.650 / 00:17:25.433]
[18.08.05] Detected main PI#001: 00146.m2ts, Duration: [00:00:35.702], [PTS: 00:00:11.650 / 00:00:47.353]
[18.08.05] Detected main PI#002: 00137.m2ts, Duration: [00:13:52.248], [PTS: 00:00:11.650 / 00:14:03.898]
[18.08.05] Detected main PI#003: 00149.m2ts, Duration: [00:00:29.362], [PTS: 00:00:11.650 / 00:00:41.013]
[18.08.05] Detected main PI#004: 00138.m2ts, Duration: [00:20:27.559], [PTS: 00:00:11.650 / 00:20:39.210]
[18.08.05] Detected main PI#005: 00151.m2ts, Duration: [00:00:35.285], [PTS: 00:00:11.650 / 00:00:46.935]
[18.08.05] Detected main PI#006: 00140.m2ts, Duration: [00:00:27.944], [PTS: 00:00:11.650 / 00:00:39.595]
[18.08.05] Detected main PI#007: 00150.m2ts, Duration: [00:00:31.406], [PTS: 00:00:11.650 / 00:00:43.057]
[18.08.05] Detected main PI#008: 00139.m2ts, Duration: [00:12:14.024], [PTS: 00:00:11.650 / 00:12:25.675]
[18.08.05] Detected main PI#009: 00154.m2ts, Duration: [00:00:35.076], [PTS: 00:00:11.650 / 00:00:46.727]
[18.08.05] Detected main PI#010: 00145.m2ts, Duration: [00:10:31.464], [PTS: 00:00:11.650 / 00:10:43.114]
[18.08.05] Detected main PI#011: 00155.m2ts, Duration: [00:00:29.863], [PTS: 00:00:11.650 / 00:00:41.513]
[18.08.05] Detected main PI#012: 00132.m2ts, Duration: [00:15:51.408], [PTS: 00:00:11.650 / 00:16:03.059]
[18.08.05] Detected main PI#013: 00148.m2ts, Duration: [00:00:45.879], [PTS: 00:00:11.650 / 00:00:57.529]
[18.08.05] Detected main PI#014: 00141.m2ts, Duration: [00:04:27.976], [PTS: 00:00:11.650 / 00:04:39.626]
[18.08.05] Detected main PI#015: 00157.m2ts, Duration: [00:00:37.245], [PTS: 00:00:11.650 / 00:00:48.896]
[18.08.05] Detected main PI#016: 00136.m2ts, Duration: [00:12:30.916], [PTS: 00:00:11.650 / 00:12:42.567]
[18.08.05] Detected main PI#017: 00156.m2ts, Duration: [00:00:54.554], [PTS: 00:00:11.650 / 00:01:06.205]
[18.08.05] Detected main PI#018: 00142.m2ts, Duration: [00:04:01.658], [PTS: 00:00:11.650 / 00:04:13.308]
[18.08.05] Detected main PI#019: 00158.m2ts, Duration: [00:03:14.986], [PTS: 00:00:11.650 / 00:03:26.637]
[18.08.05] Detected main PI#020: 00143.m2ts, Duration: [00:09:13.261], [PTS: 00:00:11.650 / 00:09:24.911]
[18.08.05] Detected main PI#021: 00159.m2ts, Duration: [00:00:32.240], [PTS: 00:00:11.650 / 00:00:43.891]
[18.08.05] Detected main PI#022: 00144.m2ts, Duration: [00:05:44.344], [PTS: 00:00:11.650 / 00:05:55.994]
[18.08.05] Detected main PI#023: 00152.m2ts, Duration: [00:02:23.351], [PTS: 00:00:11.650 / 00:02:35.002]
[18.08.05] Detected main PI#024: 00147.m2ts, Duration: [00:09:34.073], [PTS: 00:00:11.650 / 00:09:45.724]
[18.08.05] Detected main PI#025: 00153.m2ts, Duration: [00:07:03.131], [PTS: 00:00:11.650 / 00:07:14.781]
[18.08.05] Using audio: A_DTS (ID#4354 / language: ita / delay: 0)
[18.08.05] Creating clip and playlist info (tsMuxeR)...
[18.18.02] This title is marked for reencoding / uncropping...
[18.18.02] Encoding process may take 10 min to 10 hours, so be patient...
[18.18.02] *** Initiating video encoding:
[18.18.02] *** Original : 1920x1080
[18.18.02] *** Crop : 0
[18.18.02] *** Resize : 720x480
[18.18.02] *** Uncrop to : 720x480
[18.18.02] *** Sharpen : 0
[18.18.02] *** Bitrate : 6000 kbps
[18.18.02] *** Frame rate: Original (23.976)
[18.18.02] *** Profile : SD-DVD (MPEG-2)
[18.18.02] *** Encoding : One pass - content: [02:34:58] (MPEG-2 encoder: QuEnc)
[23.07.14] *** Speed : 12.85 fps (elapsed: 04:49:11 - Realtime x 0.54)
[23.07.14] *** Transcoding successful!
[23.07.15] Detected video: ID#0:V_MPEG-2 720x480, fps=23.976
[23.07.15] Display properties: 853x480 (AR:1.78)
[23.07.15] Encoding DTS audio to AC3 (eac3to)...
[23.07.27] Retrying...
[23.07.38] eac3to refused to convert audio!
[23.07.38] Trying to demux audio...
[23.16.14] Demux failed!
[23.16.14] Second attempt to demux...
[23.27.15] Encoding to AC3 (second try)...
[23.40.18] Encoding succeeded! Adding AC3 encoded audio track...
[23.40.18] Total of 2 tracks found in this file.
[23.40.18] Copying audio to source folder for re-use...
[23.40.26] Creating SD-DVD structure...
[23.40.26] Applying pulldown...
[23.52.49] Authoring DVD structure...
[00.08.37] SD-DVD muxing completed!
[00.08.37] SD-DVD title saved:
[00.08.37] I:\MultiAVCHD\AVCHD\AVCHD-20100325-180803\[DVD]\Il Gladiatore
[00.08.37] Compilation contains 1 (HD)DVD titles and no AVCHD/Blu-ray titles!
[00.08.37] Preparing menu pages...
[00.08.38] Setting main menu for 0 titles...
[00.08.38] Selected TV system: [NTSC]
[00.08.42] Done!
DTS Audio decrypting is done via Arcsoft libraries BTW.
Hints?
daberti is offline   Reply With Quote
Old 26th March 2010, 13:42   #4990  |  Link
deank
deank's Avatar
I don't understand your question.
Old 26th March 2010, 14:01   #4991  |  Link
daberti
I've got this from log....
Why does it encode audio only on second attempt?
Old 26th March 2010, 18:12   #4992  |  Link
flaviometal
Dean, I have another problem: I'm trying to convert a PAL video (MKV) with external SRT subs to play on my NTSC PS3. Here my results:
- Select NTSC in Author Tab (Tv System): MAVCHD keeps warning me that the video is PAL and after conversion, DVD doesn't works on my PS3;
- Select PAL 24 in Author Tab (TV System): The conversion works, DVD play on PS3, but only menu works, and when a try to play the video or select a chapter, goes back to top menu;
- Select PAL in Author Tab (TV System): conversion works, but doesn't play on my PS3;
And if I change the FPS in video properties (Alter Detected Properties button), the subs keeps out of sync.
Just to remember, on my PC, DVD works well with PowerDVD 9 (using PAL24).
How do I proceed?
Old 26th March 2010, 18:17   #4993  |  Link
deank
deank's Avatar
If you get it to play in your PS3 then re-sync the subtitles using SubtitleWorkshop.
Old 26th March 2010, 18:31   #4994  |  Link
deank
deank's Avatar
Few new things in the latest 741+ update:
* Fixed: Hard-burning subtitles during transcoding didn't work with external VOBSUB (sub+idx) subtitles. Now all ok.
* Added: If you import .m2v file for SD-DVD processing and mark it as [x] SD Compliant, multiAVCHD will still check it if it is 29.97. If not it will apply pull-down to get it to 29.970 fps
* Added: Something I wanted to do for long time now:
In title properties / Audio tab / [add] external audio button will allow you to add VIDEO files, too. multiAVCHD will try to use all audio tracks from: AVI, MKV, M2TS/MTS, TS, MPEG/MPG. The functionality is similar to tsMuxeR ability to add streams from different files/containers.
* Added: in case of SD-DVD mux failure, muxman log will be printed in the LOG box.
Dean
Old 26th March 2010, 19:01   #4995  |  Link
Adub
Adub's Avatar
@deank,
Any thoughts on my problem?
Site:Adubvideo
Old 26th March 2010, 19:15   #4996  |  Link
deank
deank's Avatar
Update with multiUPDATE.exe and try again...
You can try with [x] Convert DTS-MA/HRA switch, too.
Old 26th March 2010, 19:17   #4997  |  Link
Adub
Adub's Avatar
Yeah, I just thought it was curious that eac3to was erroring out because of this:
Site:Adubvideo
Old 26th March 2010, 19:18   #4998  |  Link
deank
deank's Avatar
Yes.. I added -r8brain for SD-DVD and HD audio.
Old 26th March 2010, 19:25   #4999  |  Link
Adub
Adub's Avatar
Ah! Fantastic then! I'll try it when I get home tonight! 3rd times the charm!
In the mean time, I plan on having the HD->SD-DVD guide up by tonight, so I'll have you go over it before I finalize and post it.
Site:Adubvideo
Old 26th March 2010, 19:34   #5000  |  Link
deank
deank's Avatar
If you want to do some tests, set [CUT END] in title properties to 300 (seconds). That way you'll know if it will work, without waiting few more hours.
You can also reuse the .m2v if you wish and add the audio from the m2ts file of the bluray (if it is non-branched).
Dean
avchd, blu-ray hd-dvd, mkv, multiavchd, re-author
