Old 11th September 2018, 15:47   #61  |  Link
Kn0X
komisar down?
Hey!
I have a question .. is http://komisar.gin.by gone or is it just down right now?
It's been down for a couple of days now.
Kn0X is offline   Reply With Quote
Old 14th September 2018, 17:01   #62  |  Link
Midzuki
Unavailable
Midzuki's Avatar
Originally Posted by Kn0X View Post
Hey!
His site is back.
But maybe unfortunately, since he doesn't provide fresh x264.exe builds anymore :-/
Old 15th September 2018, 10:44   #63  |  Link
Shevach
Video compressionist
In nvenc (Nvidia encoder) there is a parameter enableConstrainedEncoding. This parameter is relevant for multi-slice mode and if it's set then motion vectors are restricted to not cross slice boundaries. That mode is useful in error resilience (to constrain error temporal propagation within the boundaries of a corrupted slice) and in delivery of 360 video.
My query - is there a similar mode in libx264?
Shevach is offline   Reply With Quote
Old 15th September 2018, 23:24   #64  |  Link
Hmm, I know that x265 has a choice between WPP and other parallelism modes, also a slice oriented mode. But I don't remember x264 having a choice.
Old 20th September 2018, 13:42   #65  |  Link
Wishbringer
Silent Reader
Wishbringer's Avatar
@LigH: for x264 = this?
--slices
Default: 0
Sets the number of slices per frame, and forces rectangular slices. (Overridden by either --slice-max-size or --slice-max-mbs if they are set.)
If you are encoding for Blu-ray, set this to four. Otherwise, don't use this unless you know you need to.
but imho nothing about "enableConstrainedEncoding" except:
--constrained-intra
Default: Not Set
Enable constrained intra prediction, which is required for the base layer of SVC encodes. Since Everyone ignores SVC you can likewise ignore this switch.
Wishbringer is offline   Reply With Quote
Old 20th September 2018, 14:04   #66  |  Link
Possible, if enabling slices also ensures that MV's are constrained to each slice. I hope the developers in #x264 on Freenode know more, just asking... I'm no developer.
BugMaster mentioned a guess that --sliced-threads may have such a side-effect.
Old 26th September 2018, 00:51   #67  |  Link
benwaggoner
WPP is new and so for unique feature to HEVC. The next gen VVC (probably H.266) currently plans to not include WPP.
Ben Waggoner
My Compression Book
Old 26th September 2018, 16:31   #68  |  Link
sneaker_ger
x264 r2935 Windows binaries now up on the videolan server.
Old 8th October 2018, 00:23   #69  |  Link
Now available in my archive too: x264 0.157.2935 545de2f (compiled already 2018-09-29 but forgot to pack and upload).
Today I wanted to recompile again with updated FFMS2 and L-SMASH ... but suddenly ffmpeg fails compiling libavdevice, seems to be a GCC 8 specific issue (expecting an explicit cast to (void) in a #define).
Old 17th December 2018, 02:10   #70  |  Link
Dogway
I found that current x264 builds for some reason don't include libswscale, I was going to perform some speed tests comparing it to multithreaded avs+ resizers, even if the quality is not as great. If anyone knows someone who build them specially 10bit x64 please let me know.
Old 17th December 2018, 02:28   #71  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Which specific build are you referring to?
As far as I can tell, the latest Ligh, msystem.waw.pl and videolan.org builds all do include libswscale, i.e. the "resize" filter is available. See download links in first post.
BTW: For quite some time now, there are no separate "8-Bit" and "10-Bit" builds anymore. You can set '--output-depth' at runtime now (details).
Old 17th December 2018, 02:56   #72  |  Link
Dogway
Thank you it works! I was testing with x264 tMod (jpsdr), x264 Ymod (YamashitaRen), x264 videolan. tMod warns about the merge between 8 and 10bit builds so I thought it was important.
Old 17th December 2018, 03:06   #73  |  Link
asarian
Cool. Because I was just going to 'complain' that the 10-bit versions of x264 don't appear to be compiled with OpenCL support.
Old 17th December 2018, 03:06   #74  |  Link
LoRd_MuldeR
Software Developer
Well, the person maintaining "tMod" build obviously did not bother to port all of the "custom" patches to latest x264 after the "8/10 bits unification" (Dec 2017), which was quite a big change in x264 codebase.
Instead "tMod" build seems now to be based on an old version of x264, just before the big "8/10 bits unification" happened – with a some fixes cherry-picked from x264 master...
Old 17th December 2018, 03:15   #75  |  Link
asarian
P.S. Are there any advantages using LigH's x264 over the regular one? (at videolan)
Old 17th December 2018, 03:22   #76  |  Link
LoRd_MuldeR
Software Developer
Videolan.org build does not have FFmpegSource2 support enabled.
Also latest Videolan.org build was built using GCC 6.3.0, whereas latest LigH build was built using GCC 8.2.1 – which could be faster or slower, but probably doesn't make much of a difference.
LigH build includes a somewhat newer libavformat version.
Old 17th December 2018, 03:26   #77  |  Link
asarian
K, thank you!
Old 17th December 2018, 08:26   #78  |  Link
It's just what the media-autobuild_suite produces, no additional changes. Look here for download link and version details.
Old 17th December 2018, 09:06   #79  |  Link
asarian
Cool. Thx. I took the one from the start-post link (the one I'm encoding with now). It is dated Dec 13, 2018, so it looked pretty recent to me.
P.S. Yours -- apart from being compiled with a later compiler -- also appears to be a lot smaller (~14 MB vs. ~22 MB).
Old 17th December 2018, 09:12   #80  |  Link
Maybe the other one forgot stripping compiler symbols.
