5th November 2019, 00:30 | #17661 | Link | |
2.0 * 8 = 16 In this case i would choose higher clock .
5th November 2019, 00:45 | #17662 | Link | |
10.10.10.10 the other ip detected in client IP combobox. Adapter description includes two options regardless of ip chosen in client IP combobox: 1.Intel(R) I211 Gigabit Network Connection 2. TheGreenBow Virtual Miniport Adapter |
5th November 2019, 01:42 | #17663 | Link | |
5th November 2019, 03:29 | #17664 | Link |
Grumpy Old Man.
4K demuxing time test's (if anyone's interested)
So I have noticed a few posts about very long times to start a 4K job, so I thought I'd do a couple of tests for myself.
I chose Harry Potter #1, which is a remux 4K, 60.7Mb/s, 84.5Gb mkv. I also ran it thru MKVToolnix to rip out EVERYTHING but the video, which took 4:30 mins (Raid-0 to nvme) Also wanted to see what difference there was between LSmash & FFMS2. So, chose the untouched mkv to start with, and it took 4:30 mins to demux, and a further 4:20 mins until the job creation was ready, with LSmash. Using FFMS2 it took 4:30 mins to demux, and further 3:50 mins 'til job was ready. Then the stripped mkv took 0 mins to demux, and a total of 3:25 mins with LSmash. Same file using FFMS2 took 0 mins to demux, and a total of 3:12 mins. Once they were queued up, it was time to see how long it took to copy the file, get the chunks created, etc, etc. The untouched job took 12:00 mins 'til the chunks were all ready to go. With the stripped mkv, it took 8:45 mins...not forgetting the it took 4:30 mins to strip out the file in the first place, so it's close'ish. All these figures are having the original file on a RAID-0 of 2 x Seagate 3Tb 7,200 rpm spinners, copying to an ADATA NVM'e, using a single Xeon 12c cpu. Now, I cannot provide any final muxing, etc info at this time, as that will take a couple of days for me to get around to do that, but I WILL post my results. So regardless of how long that's going to take, there WILL be a reasonable amount of time that all DE servers aren't doing anything.
5th November 2019, 10:05 | #17665 | Link |
@Atak_Snajpera
i noticed that in the latest update, you included an option for user to select decoding method. although Lmash is slow, on my NvMe it's still fast for demuxing, indexing etc. but my question is, is there any real speed difference in using GPU for "decoding" method? btw, i see a lot of folks are discussing about NvMe here. i was an early adapter of NvMe for my 4K workflow, trust me, invest in a couple good NvMe drives. it's worth it. and do yourself a favor, don't go below 1TB. my current 4K workflow, nothing takes longer than 4 mins for initial demux, indexing, gathering information altogether. most 4K UHD sources take 3~4 mins total to do all that. if you have the source sits on the same NvMe drive, it'll only take 3~4 mins. the trick with shopping for NvMe drives is look for TLC drives and avoid QLC drives at all cost. QLC's raw writing speed is less than 100 MB/s. i've tried them all and went through them all and experience all of it the hard way. once the SLC cache run out, QLC's raw writing speed will fall below 100 MB/s sometimes 70 MB/s, that's slower than most high end 7200rpm spindle. and smaller the drive, smaller the SLC casche will be. on a 1TB QLC drive, your SLC cache is probably gonna be about less than 20GB when it's filled at 50%. the intel 660P 2TB drive, theoretically, if you over provision it and treat it as a 1.5TB drive, theoretically you'll always have more than 50GB of SLC caching. but just do yourself a favor, avoid all the QLC drives out there. go for a fast TLC drive from Corsair, Sillicon power, Samsung, and you'll be a lot happier. most TLC's raw writing speed, provided if the onboard processor is of recent version, will be around 600~800 MB/s even after it runs out of its SLC caching. so when doing 4K UHD workflow working with large 60~70 GB files, you're going to be counting on the raw writing speed. when shopping around, look for reviews that do tests on large 25~50 GB file "write" tests, and the chart will show you the speed difference once those SLC cache runs out. if money is of no object, Samsung is the way to go. but otherwise get one of those Corsair MP510, or silicon power TLC drives. 1~2TB will be most ideal. and make sure that your mobo supports PCIe 3.0 x4 M.2, even though realistically, ripbot workflow will never really exceed 1500 MB/s throuput, just under the max bandwidth of PCIe 2.0 x4 Last edited by howzz; 5th November 2019 at 10:07. |
5th November 2019, 10:21 | #17666 | Link | |
5th November 2019, 10:33 | #17667 | Link | |
Grumpy Old Man.
But why would there be a big difference ?? Is it the ripping process that takes so long ?? Do you rip it first, or let RB do that (if it can) ?? Ripping Bluray disk's was a PITA, I'm guessin' 4K are SO much worse.
Not poorly done, just doin' it my way !!! Live every day like it's your last, because one day, it will be !! (M$B) Last edited by Pauly Dunne; 5th November 2019 at 10:36. |
5th November 2019, 12:22 | #17668 | Link | ||
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 5th November 2019 at 15:18. |
5th November 2019, 14:24 | #17669 | Link | |
When you connect to remote LAN via VPN then shouldn't home-pc get the same three sections of IP? My common sense tells me that after connecting to remote LAN Client IP should be starting from 192.168.2.xxx
5th November 2019, 16:52 | #17670 | Link | |
ByteShare
5th November 2019, 17:33 | #17671 | Link |
Just use builtin in windows.
5th November 2019, 19:38 | #17672 | Link |
Not sure if this is a known issue but on a few of my recent 4k UHD Mkvs, the file Demuxing and indexing are normal. Then during "gathering information" it fails with the message "FFAudioSource: No audio track found
(C:\Temp\RipBot264temp\job1\getinfo.avs, line 4)" So using MKVToolNix I made a shorter version of the same file 1min of the file and then another with 10min of the file. The 1min version works but the 10min version fails with the same error. Then I made a full version of the file with the video only and no audio track and that is working okay as well. I used XMedia Recode to encode just the audio and that worked correctly. So I am not sure what the issue is. The audio is Dolby TrueHD 7.1 both movies in question are from Disney. |
5th November 2019, 19:52 | #17673 | Link | |
5th November 2019, 20:01 | #17674 | Link | |
For example, I use OpenVPN for and Fortigate for my VPNs. The IP block that you use for the VPN users should be almost a random block because you do not want your VPN users to have the same block as you are running on your networks. In fact, to go further, any networks that are behind your VPNs, you will not want them to be commonly used for home networks. I try and stay away from the 192.168.*.* blocks for business use. Most likely the home users are using 192.168.0.* and 192.168.1.*, but not always. An example set up simple corporate network. Internal Networks: 10.20.10.0/24 DMZ: 10.20.30.0/24 Secured Development: 10.20.40.0/24 VPN Network: 172.27.99.0/24 A road warrior or home user would connect to the VPN. They will get a 172.27.99.* for their VPN address. If I have configured a split VPN, then only the networks behind the VPN gateway will have routes added to the VPN client. The VPN client will still be able to access their local traffic and get access to the Internet without going through the VPN. If I configured Tunnel Mode VPN, and can force ALL traffic to go through the VPN or just allow the client to have access to their local network, but any traffic outside of their local network gets tunneled down the VPN. There are some VPNs that will bridge traffic and make the VPN client seem like their are on one of the local work networks, but these are not done much any more. Does RipBot assume everything is flat network (Layer2) or does it allow routing to take place (Layer 3) and jump networks to appropriate routed destination. Does RipBot bind to single IP address or does it bind to all the local addresses on the machine. I wondering if that could be causing issues if it is binding to a single address as this will cause issues with VPNs. Did I understand the question right? As for what VPN I recommend, that would be OpenVPN. I would look at using a Raspberry Pi and a firewall distro, or a wireless router that comes bundled with a OpenVPN gui. Learning OpenVPN, especially, with everything it can do, is not for the faint of heart. |
5th November 2019, 20:57 | #17675 | Link | |
According to mparade post here https://forum.doom9.org/showthread.p...85#post1889585 other ip is 10.10.10.10 - TheGreenBow Virtual Miniport Adapter. Does not look like anything useful...
5th November 2019, 22:10 | #17676 | Link | |
my suggestion for the TLC was because realistically, for cost reasons. But if money is no object, the Samsung Pro really is the way to go. but for those building large capacity 1TB/2TB drives for NvMe, TLC is a pretty fast compromise imo. edit: are there even any 2TB samsung MLC NvMes? at least i can't find any. Last edited by howzz; 5th November 2019 at 22:15. |
5th November 2019, 22:57 | #17678 | Link |
No quality penalty. GPU just provides frames to encoder.
6th November 2019, 04:01 | #17679 | Link | |
6th November 2019, 05:50 | #17680 | Link |
Grumpy Old Man.
Greatly improved muxing times :)
So today I was able to test a reasonably sized 4K movie..
I chose to do "Frozen", which I stripped out the audio, as I don't need/want TrueHD (turned out the thd track was corrupted anyway). So the file ended up being 42.5Gb @ 56.8Mb/s, NO audio, or subs !! After the encoding if was 35.25Gb @ 47.1Mb/s, using CRF 12. After the initial loading of the job, it took a further 3 hrs:37 m to complete the encode. The combining took 1:45 mins, and the muxing took 2:55 mins for a total of only 4:40 mins. A lot better than this :- ..the combining of the chunks took 10 minutes 30, then the muxing process took a further 15 minutes 30 .. (from post #17533) which was admittedly a larger file with all it's tracks, but on slow SSD's. Now I would think that "Frozen" would have taken a little longer if it had to do EVERYTHING, but I did the final "mux" with MKVToolnix, to add audio & subs.
