Old 17th July 2016, 19:42   #1381  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Randy31416, this is because the clean_file_name() function is applied to clean up the file name, before the final file extension is appended. And dots (.) at the end of the file name are forbidden, so they are removed.
I have changed the logic now, so that the clean up function gets applied at a slightly later point:
https://sourceforge.net/projects/mul...6.exe/download
Old 18th July 2016, 14:23   #1382  |  Link
Randy31416
You do support this program exceptionally well. Thanks. Randy
Randy31416 is offline   Reply With Quote
Old 20th August 2016, 18:52   #1383  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.14 Beta-4
Changes between v4.13 and v4.14 [unreleased]:
* Upgraded build environment to Microsoft Visual Studio 2015 with Update-2
* Fixed the location of temporary intermediate files for SoX-based audio effects
* Fixed embedding of meta tags with OggEnc2 when reading directly from OGG/FLAC input file
* Enabled the "built-in" resampler for QAAC encoder
* The "Algorithm Quality" slider now also affects the QAAC encoder
* Added "AVX" (Advanced Vector Extensions) to CPU feature detection code
* Updated Opus encoder/decoder libraries to v1.1.2 and Opus-Tools to v0.1.9 (2016-05-22)
* Updated LAME encoder to v3.100 Alpha-2 (2016-01-29), compiled with ICL 15.0 and MSVC 12.0
* Updated MediaInfo to v0.7.85 (2016-04-29), compiled with ICL 15.0 and MSVC 12.0
* Updated QAAC add-in to the to QAAC v2.58 (2016-01-05)
* Updated FhgAacEnc add-in to "Case" edition (2015-10-24)
* Updated mpg123 decoder to v1.23.4 (2016-05-11), compiled with GCC 5.3.0
* Updated ALAC decoder to refalac v1.58 (2016-01-05)
* Updated GnuPG to v1.4.21 (2016-08-17), compiled with GCC 6.1.0
* Improved auto-update function (faster Internet connectivity check)
Old 11th September 2016, 16:23   #1384  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.14 Beta-5
* Updated Opus encoder/decoder libraries to v1.1.3 and Opus-Tools to v0.1.9 (2016-09-11)
Old 3rd October 2016, 13:55   #1385  |  Link
LoRd_MuldeR
Software Developer
The QAAC Add-in has been updated to QAAC v2.61:
LameXP.qaac-addin.2016-10-03.zip
Old 3rd October 2016, 20:19   #1386  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.14 Beta-7
* Updated MediaInfo to v0.7.88 (2016-08-31), compiled with ICL 15.0 and MSVC 12.0
* Updated QAAC add-in to the to QAAC v2.61 (2016-10-02)
* Updated ALAC decoder to refalac v1.61 (2016-10-02)
* Updated WavPack decoder to v4.80.0 (2016-03-28), compiled with ICL 15.0 and MSVC 12.0
Old 16th October 2016, 16:56   #1387  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.14 RC-1
* Updated Opus encoder/decoder libraries to v1.1.3 and Opus-Tools to v0.1.9 (2016-10-16)
* Updated FLAC encoder/decoder to v1.3.1 (2016-10-04), compiled with ICL 17.0 and MSVC 12.0
Old 21st October 2016, 21:05   #1388  |  Link
LoRd_MuldeR
Software Developer
LameXP v4.14 RC-2
* Updated mpg123 decoder to v1.23.8 (2016-09-27), compiled with GCC 6.2.0
Old 22nd October 2016, 18:35   #1389  |  Link
digitaltoast
Looking good, but if you're after feedback on 4.14RC2, I just have a couple:
During install, it wants to install to folder 4.11 and won't let me change path.
When encoding mp3, even when I override the samplerate and enforce 44.1KHz, it downgrades to 32KHz etc, at anything above VBR compression level 6.
That's it, so far! Do you need screenshots or is that OK? Thanks for a great app!
digitaltoast is offline   Reply With Quote
Old 22nd October 2016, 19:33   #1390  |  Link
LoRd_MuldeR
Software Developer
That's because the installer will "upgrade" the existing installation - which is located wherever you originally installed LameXP.
And that's because of LAME's psycho-acoustic model.
The sampling rate determines the highest frequency that can be retained (cf. Nyquist–Shannon sampling theorem). So, by reducing the sampling rate from 44.1 kHz to 32 kHz, you are effectively low-pass filtering the audio. In other words, the highest frequencies are discarded before the actual encoding. At a sampling frequency of 44.1 kHz the highest audio frequency that can be retained (without aliasing) is 22.05 kHz; at a sampling frequency of 32 kHz, the highest audio frequency that can be retained is 16 kHz. Low-pass filtering the audio makes a lot of sense at very low bitrates (or the lowest VBR quality levels), because loosing the highest frequencies is way less disturbing than the compression artifacts that arise otherwise.
Note: It's possible to "force" LAME to encode at the original sampling rate, by explicitly specifying the "--resample" option with the original sampling rate. But you almost always do not want this!
Old 22nd October 2016, 19:52   #1391  |  Link
digitaltoast
Many thanks for the explanation:
Except of course when it's a particularly archaic piece of hardware which can only cope with multiples of 11.020
Perfect, thank you.
Old 22nd October 2016, 21:16   #1392  |  Link
LoRd_MuldeR
Software Developer
Just for the notes: The original MP3 (actually "MPEG-1 Audio Layer III") specification from 1993 defines three possible sampling rates – 48 kHz, 44.1 kHz and 32 kHz – that any "compliant" decoder must support.
(More sampling rates – 16 kHz, 22.05 kHz and 24 kHz – have been added to MP3 with the MPEG-2 standard in 1995)
Old 25th October 2016, 11:03   #1393  |  Link
RieGo
in the latest version (RC2) it seems that opus isn't working properly. if i encode with the same setting as before (VBR 16kbps; complexity 10; framesize 60) i get valid opus files with correct filesize, but when played back it's just extremely noisy, which sounds like compressed at 1kbps
anyways, keep up the good work!
RieGo is offline   Reply With Quote
Old 26th October 2016, 22:07   #1394  |  Link
LoRd_MuldeR
Software Developer
I see what you mean. I tried encoding a piece of music at ~16 kbps and it came out as total noise. Not that I would expect anything worthwhile at ~16 kbps.
Interestingly, at ~24 kbps it came out "okay". Of course, the ~24 kbps version didn't sound very good either. But considering that it's only ~24 kbps Opus still performed pretty well at that rate. Nothing like the ~16 kbps result.
I'm not sure whether the ~16 kbps result is a bug in latest Opus or just what you have to expect at that ultra-low rate. If you got better result before, with what Opus version was that?
Old 27th October 2016, 09:34   #1395  |  Link
RieGo
yes! i use opus mainly to encode tons of audiobooks (mono), which results in "really good" sound quality starting at 16kbps. it worked just fine on releases before RC2 (or RC1?) and it also works with official opus encoder 1.1.3.
if you say 24kbps came out okay for you, it may be just a problem on my side. i'll try to reinstall LameXP and check.
update:
same problem after reinstalling and removing settings.
i uploaded 2 samples, so you know what i mean:
03_opusenc.opus
03_RC2.opus
i also tried encoding at 24kbps and 128kbps:
24kbps has the same weird artifacts, but not as present as with lower bitrate
128kbps sounds just fine
maybe it's really just a bug in the latest Opus, which effects only lowest bitrates
btw: i have seen that opus files generated by LameXP are always 1kbps lower than set. so i encoded my sample at 15kbps with opusenc
Old 27th October 2016, 21:35   #1396  |  Link
LoRd_MuldeR
Software Developer
Opus binaries have last been updated in RC-1, from Git "master" 2016-09-11 to 2016-10-16. There has not been any change to Opus between RC-1 and RC-2.
I noticed two recent commits/fixes that may be related to this problem:
Will try building latest version soon... (not this weekend though)
By default, Opus uses VBR mode. So, by default, the selected bitrate only "specifies the average rate for a large and diverse collection of audio". It's more a rough estimate.
Your particular audio file may, very well, come out at a somewhat higher or a somewhat lower average bitrate!
If you really whish to hit a specific average bitrate, then you have to add the "--cvbr" option, aka "constrained variable bitrate encoding". Or even use the "--hard-cbr" option.
Old 30th October 2016, 20:22   #1397  |  Link
LoRd_MuldeR
Software Developer
RieGo, can you please try again with the latest LameXP build?
https://sourceforge.net/projects/lam...4.exe/download
(After some testing, it appears that the "noisy" output occurs when SSE2 or AVX compiler-optimizations are enabled for the Opus library, so I keep them disabled for now. The recent fixes in Opus code seem unrelated)
Old 30th October 2016, 22:37   #1398  |  Link
amayra
Quality Checker
amayra's Avatar
i try to convert m4a " dash" but lamexp tell me this is not supported format ?
source form youtube
I love Doom9
Old 30th October 2016, 22:39   #1399  |  Link
LoRd_MuldeR
Software Developer
source form youtube
What does MediaInfo say about that file?
https://github.com/lordmulder/mediai...eleases/latest
Old 31st October 2016, 09:50   #1400  |  Link
RieGo
your new release works just fine. thanks a lot!
