Go Back   Doom9's Forum > General > Newbies
Old 23rd March 2011, 06:50   #1  |  Link
creedo
Why does my movie displayed thinner than the width given in its properties?
I think I tried this in the wrong forum before.
I have an avi, I crop the top and bottom black bars in virtualdubmod. I save it as mkv.
The final resolution is 640 x 352. But it displays as ~444 x 352.
It shows (5:4 aspect ratio) also in the properties. Why? I didn't manually set that. But it's probably why the video is tall and thin instead of displaying the way I wanted.
I did finally fix it in mkvtoolnix by manually assigning a wider aspect ratio. But what is it that made virtualdub assign that odd AR in the first place?
creedo is offline   Reply With Quote
Old 23rd March 2011, 09:38   #2  |  Link
7ekno
Cause it's VirtualDubMod that is old, depriciated and no longer updated ...
Upgrade to current VirtualDub releases and Bob's ya Aunty
7
Old 24th March 2011, 00:30   #3  |  Link
slipknot!
slipknot!'s Avatar
why don't you try this:
play hard go pr0
dmg / slipknot!
slipknot! is offline   Reply With Quote
Old 26th March 2011, 05:56   #4  |  Link
creedo
Thanks for the replies y'all. I had no idea virtualdub was still being updated, I thought mod was the fresher one Does it support more formats now and hopefully crash less?
aspect ratio, skinny, thin, wide, width
