Old 3rd July 2019, 01:22   #6881  |  Link
benwaggoner
Originally Posted by filler56789 View Post
I know that. But it seems you don't know that it WORKS
Up to a point. Maybe. But a second long cross dissolve would need either a really big VBV or really high QP. And weighted prediction is EXACTLY for this kind of use case.
Ben Waggoner
My Compression Book
Old 5th July 2019, 14:30   #6882  |  Link
Barough
Barough's Avatar
x265 v3.1+4-4f6dde51a5db (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.1.0)
Old 9th July 2019, 11:36   #6883  |  Link
birdie
Artem S. Tashkinov
birdie's Avatar
x265 3.1.1 is out.
https://bitbucket.org/multicoreware/...5_3.1.1.tar.gz
Old 10th July 2019, 02:34   #6884  |  Link
MeteorRain
結城有紀
From 9612a000cb26748e62833dcd9e47d890af0e3dec Mon Sep 17 00:00:00 2001
Date: Tue, 9 Jul 2019 21:30:15 -0400
Subject: [PATCH] icc: fix compiling and linking issue under ICC
 source/common/x86/asm-primitives.cpp | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/source/common/x86/asm-primitives.cpp b/source/common/x86/asm-primitives.cpp
index 3948c4b97..abd3665f8 100644
--- a/source/common/x86/asm-primitives.cpp
+++ b/source/common/x86/asm-primitives.cpp
@@ -5429,7 +5429,7 @@ void setupAssemblyPrimitives(EncoderPrimitives &p, int cpuMask) // Main
 } // namespace X265_NS
 extern "C" {
-#ifdef __INTEL_COMPILER
+#if defined(__INTEL_COMPILER) && EXPORT_C_API
 /* Agner's patch to Intel's CPU dispatcher from pages 131-132 of
  * http://agner.org/optimize/optimizing_cpp.pdf (2011-01-30)
@@ -5440,7 +5440,7 @@ int __intel_cpu_indicator = 0;
 // CPU dispatcher function
 void PFX(intel_cpu_indicator_init)(void)
-    uint32_t cpu = x265::cpu_detect(false);
+    uint32_t cpu = X265_NS::cpu_detect(false);
     if (cpu & X265_CPU_AVX)
         __intel_cpu_indicator = 0x20000;
@@ -5467,7 +5467,7 @@ void PFX(intel_cpu_indicator_init)(void)
  * that backs up all the registers. */
 void __intel_cpu_indicator_init(void)
-    x265_safe_intel_cpu_indicator_init();
+    PFX(intel_cpu_indicator_init)();
 #else // ifdef __INTEL_COMPILER
2.19.1.windows.1
Fixes #487 and #488. For those who'd like to use ICC. Anyone is free to submit this patch to the official with any amount of modification.
Projects
x265 - Yuuki-Asuna-mod Download / GitHub
TS - ADTS AAC Splitter | LATM AAC Splitter | BS4K-ASS
Neo AviSynth+ filters - F3KDB | FFT3D | DFTTest | MiniDeen | Temporal Median
MeteorRain is offline   Reply With Quote
Old 10th July 2019, 07:25   #6885  |  Link
chenm001
Thank you point out this bug, I have been forward message to project manager.
chenm001 is offline   Reply With Quote
Old 11th July 2019, 13:51   #6886  |  Link
Stereodude
What happened to x265 from 2.9 to 3.x? The bitrate dropped (and the QP increased) and the visual output quality has suffered at the same crf with the same command line. I read the release notes here: https://x265.readthedocs.io/en/defau...easenotes.html but they don't shed a ton of light. I know they made the old veryslow = new slower and effectively made a new preset between placebo and the old veryslow, but I've been using placebo so that doesn't explain it.
My typical 1080p command line switches for 8 bit 4:2:0 input.
--crf 16.0 -p placebo --no-sao --aq-strength 1.15 --vbv-maxrate 25000 --vbv-bufsize 25000 --level 5.0 --keyint 120 --open-gop -D 10 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1
Old 11th July 2019, 15:05   #6887  |  Link
Preset "placebo" as your "typical" 1080p parameter ... seriously?! I hope you use solar power to operate your PC.
The meaning of the placebo preset didn't change in the last years. So it must be a change in the general default behaviour.
I can hardly imagine anyone actually seeing an obvious loss of quality in a CRF 16 result played at normal speed. I hope you don't compare single frames with a magnifier to produce this claim. Are you able to provide clips to compare?
Old 11th July 2019, 15:15   #6888  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
The default AQ mode has been changed to auto-variance (aq-mode 2) in version 3.0.
Try setting --aq-mode 1 (the old default) in your command line.
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 11th July 2019, 15:26   #6889  |  Link
Stereodude
It's quite easy to see in motion without magnification. Watch how fine grain dances and changes over time compared to the source (or doesn't dance and change like it should). With 2.9 the presets faster than placebo did not give satisfactory results even with significantly more bitrate.
Okay, thanks I will try this.
Old 11th July 2019, 17:59   #6890  |  Link
Barough
Barough's Avatar
x265 v3.1+7-147fb92c5ed5 (32 & 64-bit 8/10/12bit Multilib Windows Binaries) (GCC 9.1.0)
Old 11th July 2019, 18:43   #6891  |  Link
Stereodude
Why hasn't direct AVIsynth input been added to the windows builds of x265 like x264 has? I'm rather sick of having to pipe video into it.
Old 11th July 2019, 20:23   #6892  |  Link
Natty
Noob
which one is latest ?
Natty is offline   Reply With Quote
Old 11th July 2019, 21:37   #6893  |  Link
Barough
Barough's Avatar
V3.1+7 is from the Default channel and includes what the v3.1.1 have and some more
Skickat från min SM-G975F via Tapatalk
Do NOT re-post any of my Mediafire links. Download & re-host the content(s) if you want to share it somewhere else.
Old 12th July 2019, 00:34   #6894  |  Link
qyot27
qyot27's Avatar
Use x265-Yuuki or ffmpeg.
Old 12th July 2019, 00:38   #6895  |  Link
stax76
stax76's Avatar
Or Wolfberry
Old 12th July 2019, 01:24   #6896  |  Link
Stereodude
Is there some trick to making x265-Yuuki work with avisynth+?
C:\HDTV Tools\x265_Yuuki>x265-gcc-multilib-full.exe -f 1500 --crf 16.0 -p placebo --no-sao --aq-strength 1.15 --vbv-maxrate 25000 --vbv-bufsize 25000 --level 5.0
--keyint 120 --open-gop -D 10 --colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 -o HZLIP_p_1.15_16.0_nosao_D10_dith_p1_t_10in.265
"E:\TempBD\HZLIP\HZLIP_comb_1.avs"
[avs2 @ 00000000037d8300] Format avs2 detected only with low score of 1, misdetection possible!
[avs2 @ 00000000037d8300] Could not find codec parameters for stream 0 (Video: avs2, none): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[NULL @ 0000000004e14700] No codec provided to avcodec_open2()
lavf [error]: could not find decoder for video stream
x265 [error]: unable to open input file <E:\TempBD\HZLIP\HZLIP_comb_1.avs>
Edit: Wolfberry works with the same command line (changing only the name of the executable).
Old 12th July 2019, 03:46   #6897  |  Link
qyot27
qyot27's Avatar
Yuuki is the patchset/branch (the patch itself is just generic LAVF input); whether the particular build was linked against a libavformat that itself was built with --enable-avisynth is up to the one building it. 'avs2' is not AviSynth (it's the Chinese AVS2 format), and the only reason libavformat would jump to that when given an AviSynth script is that FFmpeg hadn't been built with --enable-avisynth.
Old 12th July 2019, 11:43   #6898  |  Link
Stereodude
So why doesn't the Wolfberry build of x265 honor affinity restrictions? Using
START "Enc #1" /NORMAL /NODE 0 /AFFINITY 00FF
in front of the x265 command line still results in the same number of threads being spawned as no affinity restrictions or /AFFINITY 000F. It always sees the full processor which is the same problem I have with piping.
Old 13th July 2019, 01:20   #6899  |  Link
Stereodude
--seek doesn't work correctly with the Wolfberry build with an avisynth+ input either.
x265.exe" --pools 4 -F 1 --crf 16.0 -p veryslow --no-sao --aq-mode 1 --aq-strength 1.15
--vbv-maxrate 40000 --vbv-bufsize 40000 --level 5.1 --keyint 120 --open-gop -D 10
--colorprim "bt709" --transfer "bt709" --colormatrix "bt709" --sar 1:1 --seek 16609
--frames 16678 -o out_2.265 "source.avs"
I get this output in the console: (which says all the right things)
lavf [info]:
 Format    : avisynth
 Codec     : rawvideo ( raw video )
 PixFmt    : yuv420p10le
 Framerate : 24/1
 Timebase  : 1/24
 Duration  : 2:18:31
lavf [info]: 1920x1080 fps 24/1 i420p10 sar 1:1 frames 16609 - 33286 of 199487
raw  [info]: output file: out_2.265
x265 [info]: HEVC encoder version 3.1.1+1-04b37fdfd2dc
x265 [info]: build info [Windows][GCC 9.1.1][64 bit] 10bit
x265 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
x265 [info]: Main 10 profile, Level-5.1 (Main tier)
x265 [info]: Thread pool created using 4 threads
x265 [info]: Slices                              : 1
x265 [info]: frame threads / pool features       : 1 / wpp(17 rows)
x265 [info]: Coding QT: max CU size, min CU size : 64 / 8
x265 [info]: Residual QT: max TU size, max depth : 32 / 3 inter / 3 intra
x265 [info]: ME / range / subpel / merge         : star / 57 / 4 / 5
x265 [info]: Keyframe min / max / scenecut / bias: 12 / 120 / 40 / 5.00
x265 [info]: Lookahead / bframes / badapt        : 40 / 8 / 2
x265 [info]: b-pyramid / weightp / weightb       : 1 / 1 / 1
x265 [info]: References / ref-limit  cu / depth  : 5 / off / off
x265 [info]: AQ: mode / str / qg-size / cu-tree  : 1 / 1.1 / 32 / 1
x265 [info]: Rate Control / qCompress            : CRF-16.0 / 0.60
x265 [info]: VBV/HRD buffer / max-rate / init    : 40000 / 40000 / 0.900
x265 [info]: tools: rect amp rd=6 psy-rd=2.00 rdoq=2 psy-rdoq=1.00 rskip
x265 [info]: tools: signhide tmvp b-intra strong-intra-smoothing deblock
[0.3%] 54/16678 frames, 0.16 fps, 6617.67 kb/s, 1.77 MB, eta 29:46:47, est.size 548.21 MB
But the actual out_2.265 output file starts from frame 0 in the source, not frame 16609.
Old 13th July 2019, 01:56   #6900  |  Link
MeteorRain
結城有紀
AviSynth support came from LAVF input filter.
LAVF input filter was ported from x264.
x264 didn't support seeking.
So this input filter never had seeking feature.
As a side note, LAVF was never designed to take AVS script (and that's exactly the reason I did not include AVS support in my build).
I'd hope one day someone can add a proper AVS native input. But on the other hand my scripts are on 32-bit so I have no choice but to use piper anyway.
Projects
