Old 21st July 2018, 14:53   #1  |  Link
ThePi7on
ThePi7on's Avatar
output with wrong aspect ratio
Hi, VapourSynth beginner here, and also fist time poster, so I hope I'm in the right section.
So I was experimenting a bit, and I realized the output has the wrong aspect ratio, even if ClipInfo reports the correct resolution.
Problem also persists if I only output the source without any filer applied.
As you can see, the the dragon ball in the center appears deformed.
Here's my script
import vapoursynth as vs
import havsfunc as haf
core = vs.get_core()
video = core.lsmas.LWLibavSource(r"G:\DOWNLOAD TORRENT 2\01. Son Goku Saga\[Pendekar] Dragon Ball - 001 [Dragon Box] [Dual Audio].mkv.!ut").text.ClipInfo()
src=video
super = core.mv.Super(video, pel=2, sharp=1)
backward_vec3 = core.mv.Analyse(super, blksize = 4, isb = True, delta = 3, overlap=2)
backward_vec2 = core.mv.Analyse(super, blksize = 4, isb = True, delta = 2, overlap=2)
backward_vec1 = core.mv.Analyse(super, blksize = 4, isb = True, delta = 1, overlap=2)
forward_vec1 = core.mv.Analyse(super, blksize = 4, isb = False, delta = 1, overlap=2)
forward_vec2 = core.mv.Analyse(super, blksize = 4, isb = False, delta = 2, overlap=2)
forward_vec3 = core.mv.Analyse(super, blksize = 4, isb = False, delta = 3, overlap=2)
video = core.mv.Degrain3(video, super, backward_vec1,forward_vec1,backward_vec2,forward_vec2,backward_vec3,forward_vec3, thsad=400)
#video = haf.EdgeCleaner (video, 10)
#video = haf.DeHalo_alpha (video)
video = haf.ContraSharpening(video, src, radius=1)
## double video
#out=core.std.StackHorizontal([video, src])
#out.set_output()
video.set_output()
Thanks in advance for the help
ThePi7on is offline
Old 21st July 2018, 16:29   #2  |  Link
Wilbert
Please have a look at the forum rules. Especially rule 6. Thanks. Thread closed.
Wilbert is offline
aspect ratio, wrong
