Old 15th May 2010, 13:48   #1321  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@nevragain
let me know if it ends properly
@bagheera1
you can find the Vertical Resize command button in 'Title Edit'/'AviSynth'. Just play a little bit with it. For further info press F1 on that window.
About the uncorrect RAM and OS detection, do not mind, it is just a label. Probably I have to update the quite old (32 bit only) system diag routine to support latest 64 bit hardware and software configurations.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 15th May 2010, 23:17   #1322  |  Link
nevragain
Ok the result was perfect filling the disc to 98% according to imgburn. Encode looks great even on the large lcd I use. Thanks very much you saved me from having to create my own script and I learned that ffmpeg can demux from an mpeg 2 program stream.
Oh for the authoring I meant DVDauthorGUI not DVauthorGUI.
nevragain is offline   Reply With Quote
Old 20th May 2010, 02:54   #1323  |  Link
hlrsnd
Hello, a question about the new 2.3.0. I noticed that according to GSpot, it encodes my 640x480 progressive Canon camera avi's as interlaced. I prefer them to stay progressive and simply be resized to the correct 720x480 (I'm in the US). Version 2.2.6 kept them as progressive.
Is the intent to make everything interlaced? Is there any way to force the program to work as it used to? Maybe I'm missing something here.
Thanks again for the great program, btw. It works even faster now that I've substituted the SSE4 version of HCEnc.
hlrsnd is offline   Reply With Quote
Old 20th May 2010, 03:31   #1324  |  Link
hlrsnd
Here is some additional info about my previous post, that progressive video is encoded as interlaced according to GSpot. The log file states that this was supposed to be encoded as progressive:
*MAXBITRATE 9000
*BITRATE 6156
*PROFILE BEST
*ASPECT 4:3
*PROGRESSIVE
*TFF
*BIAS 60
*DC_PREC 10
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
GSpot indicates this is encoded as interlaced, TFF. (Does it make sense that progressive video would be TFF? I thought TFF/BFF was only for interlaced).
Elsewhere in the same project, I have some mini DV footage which is correctly picked up as interlaced. Log file indicates that this should be encoded as interlaced:
*MAXBITRATE 9000
*BITRATE 6156
*PROFILE BEST
*ASPECT 4:3
*INTERLACED
*BFF
*BIAS 60
*DC_PREC 10
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY IDLE
*WAIT 2
GSpot agrees that this is encoded as interlaced, BFF.
So, either AVStoDVD somehow didn't encode progressive as it was supposed to, or GSPot is wrong. In the past, GSpot has always agreed with what was supposed to happen in the encodes. Suggestions?
Old 20th May 2010, 04:49   #1325  |  Link
qyot27
qyot27's Avatar
Take one of the .VOB files that's supposed to be progressive and open it in DGIndex. Press F6. What does the 'Frame Type' field say?
But in any case, it's in HCenc, because that's what's doing the encoding (and as I use HCenc separately of AVStoDVD, I know what its configuration files look like) - the new betas allow both *PROGRESSIVE and *TFF to be set, to help compatibility with some players (at least, that's how I understand it). The .ini you posted first contains both of them, but the video should still register as progressive, or mostly progressive, in DGIndex.
Old 20th May 2010, 10:03   #1326  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@hlrsnd
if GSpot detect that stream as interlaced, it makes a mistake. Use the more reliable Mediainfo. Progressive mpeg2 streams accept the fields order flag (TFF or BFF), so do not bother. The reason why I (and hank, author of HCenc) have added that flag is exactly in qyot27 post (thanks).
See here for more details.
Bye
MrC
AVStoDVD Homepage
Old 21st May 2010, 03:54   #1327  |  Link
nevragain
I have another question, It seems that the option to keep dvd compliant video is grayed out in the latest version. I would like to be able to author the mpegs from my dvd recorder without re-encoding. As far as I know these files should be dvd compliant.
Old 21st May 2010, 08:25   #1328  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@nevragain
'Keep dvd compliant video' is grayed only if the input video stream is not compatible with the DVD video standard (PAL/NTSC) you have choosen in Preferences.
If that matches, could you please post here a screenshot of main AVStoDVD form after you have added your mpeg2 clip? Or better, save the project (.a2d file) and copy&paste here the content.
Bye
MrC
AVStoDVD Homepage
Old 21st May 2010, 12:41   #1329  |  Link
hlrsnd
Both DGIndex and MediaInfo show the files as progressive, so it looks like GSpot is confused.
Thanks for your help, MrC also.
Old 21st May 2010, 19:36   #1330  |  Link
nevragain
Ok I've started with a blank project, selected NTSC as the output TV standard and added an ntsc compliant mpeg elementary stream. Despite this I'm still encountering the same issue. Does the use of DGIndex affect this issue?
** Project Settings **
Project_PathName: K:\recorder\ts mov crp dvd-5\DVD.a2d
Output_Folder: C:\Documents and Settings\Owner\My Documents
EditEncoderParams: 0
DeleteTemp: 1
DeleteWorking: 1
MultiThread: 1
DVD_Label: DVD
Post_Process: Show Progress Status window (default)
Output_Size: 4450
DVD_Size: DVD-5
Output_Setup: DVD Folder
Video_Standard: NTSC
** Title 1 **
[General]
TitleName: ts mov crp dvd5 bitrate_0_totally spies the movie
TimeTrimmed: 5052
InputVideoPathName: K:\recorder\ts mov crp dvd-5\ts mov crp dvd5 bitrate_0_totally spies the movie.d2v
InputVideoDescription: DGIndex - 6814 kbps - 720x480 - DAR 1.778 - 29.97 fps (CFR) - Interlaced (TFF) - 1:24:12 hours - 151419 frames
InputAudioPathName1: K:\recorder\ts mov crp dvd-5\ts mov crp dvd5 bitrate_0_totally spies the movie.ac3
InputAudioDescription1: AC3 - 384 kbps - CBR - 2ch - 48000Hz - 1:24:12 hours - External
InputAudioTrackNum1: 0
InputSubsPathName:
[MediaInfo]
FileName: ts mov crp dvd5 bitrate_0_totally spies the movie
FileExt: d2v
FileSize: 4267862465
Format: D2V
VideoTracksCount: 1
AudioTracksCount: 1
TextTracksCount:
Time: 5052347
VideoTime: 5052347
VideoCompression: DGIndex
VideoBitRateMode: VBR
VideoAvgBitRate: 6814297
VideoMinBitRate:
VideoMaxBitRate:
VideoWidth: 720
VideoHeight: 480
VideoDAR: 1.778
VideoPAR: 1.185
VideoStandard: NTSC
VideoFrameRateMode: CFR
VideoFPS: 29.97003
VideoFrameCount: 151419
VideoScanType: Interlaced
VideoScanOrder: TFF
AudioID(1,0):
AudioTime(1,0): 5052448
AudioCompression(1,0): AC3
AudioAvgBitRate(1,0): 384000
AudioBitRateMode(1,0): CBR
AudioChannels(1,0): 2
AudioSampleRate(1,0): 48000
AudioResolution(1,0):
AudioLanguage(1,0):
AudioDelay(1,0):
ChaptersList:
[Video]
VideoAutoSetup: 1
VideoIsToBeKept: 0
VideoProfile: QuEnc CBR 1-pass
VideoHCencAQ: 1
VideoHCencLumgain: 1
VideoHCencMatrix: MPEG
VideoHCencProfile: BEST
VideoResolution: 1
VideoAspectRatio: 1
VideoDVSource: 0
VideoInterlacedEncoding: 1
VideoFieldOrder: TFF
VideoCloseAllGOPs: 0
VideoBitRate: 6864
VideoAutoBitRate: 1
[Audio]
AudioAutoSetup1: 1
AudioIsToBeKept1: 1
AudioFormat1: 0
AudioChannelsMode1: 2.0
AudioLanguage1: EN - English
AudioBitRate1: 384
AudioNormalize1: 0
AudioFixAC31: 1
AudioAftenPad1: 0
AudioAftenDRC1: 5
AudioAftenBWFilter1: 0
[Subs]
SubsAutoSetup: 1
SubsLanguage: EN - English
SubsHardEncode: 0
[AVS]
AVSAutoSetup: 1
AVSAutoScript:
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
LoadPlugin("C:\Program Files\AVStoDVD\DGIndex\DGDecode.dll")
LoadPlugin("C:\Program Files\AVStoDVD\Lib\LeakKernelDeint.dll")
Video = MPEG2Source("K:\recorder\ts mov crp dvd-5\ts mov crp dvd5 bitrate_0_totally spies the movie.d2v")
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("K:\recorder\ts mov crp dvd-5\ts mov crp dvd5 bitrate_0_totally spies the movie.ac3", CacheFolder = "K:\avs2dvd temp")
Video = Video.ConvertToYV12(interlaced = true)
AudioDub(Video, Audio)
AVSScript:
AVSCrop: 0
CropDx: 0
CropSx: 0
CropUp: 0
CropDo: 0
AVSVerticalResize: 0
VResize: 100
AVSDeInterlace: 0
DeIntThreshold: 10
AVSTrim: 0
FrameStart: 0
FrameEnd: 151408
AVSTweak: 0
Hue: 0
Saturation: 1
Brightness: 0
Contrast: 1
AVSSharpen: 0
Sharpness: 0
AVSDelayAudio: 0
AudioDelay: 0
AVSAmplifyAudio: 0
AudioAmplify: 1
AVSFadeIO: 0
FadeIOFrames: 0
[Chapters]
ChaptersAutoSetup: 1
ChaptersList: 9000 18000 27000 36000 45000 54000 63000 72000 81000 90000 99000 108000 117000 126000 135000 144000
AVStoDVD Release 2.3.0 - by MrC
AVStoDVD Job <K:\recorder\ts mov crp dvd-5\DVD.a2d> created on date 5/21/2010 2:33:06 PM
Old 21st May 2010, 20:32   #1331  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@nevragain
bug found in release 2.3.0: NTSC dvd compliant stream are not kept (PAL is OK). Thanks for the report.
It seems that a 2.3.1 release is needed sooner than I was planning...
Bye
MrC
AVStoDVD Homepage
Old 22nd May 2010, 01:37   #1332  |  Link
nevragain
Thank you for your attention to this issue, I await your update and will test once released.
Old 22nd May 2010, 22:33   #1333  |  Link
rendez2k
rendez2k's Avatar
I left my PC encoding a 720p MKV tonight. I've come back to find aften had crashed? Anyone else had this? Should MKVs convert OK? I'm running Win 7 64bit if that makes a difference.
QuEnc appears to have taken over now.
rendez2k is offline   Reply With Quote
Old 23rd May 2010, 08:04   #1334  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
As usual, please post the log file
Sometimes there are some problems with Wavi+Aften when processing long 5.1 AAC/DTS-ES tracks, mainly if they are secondary audio tracks. Switching to QuEnc is often a good workaround.
Take a look at Help/FAQ/General/Q1.5
Bye
MrC
AVStoDVD Homepage
Old 23rd May 2010, 17:05   #1335  |  Link
winmaster
Text Nerd
winmaster's Avatar
MrC:
Thank you for your help. My videos now have audio as they should.
winmaster is offline   Reply With Quote
Old 26th May 2010, 09:36   #1336  |  Link
whiskey
Drunken munky
Recently discovered this program and must say, so far I love it... thx Keep up th great work !
whiskey is offline   Reply With Quote
Old 30th May 2010, 07:17   #1337  |  Link
whiskey
Drunken munky
...and I'm back with the issue, no idea whats causing it, was working fine so far but not anymore
ERROR DURING OPERATIONS ('Generate AviSynth script file' Section): 0 -
<2010-05-30 00:59:19>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4480/4480 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: DVD
DVD Menu: No Menu
Output Folder: E:\New folder
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
AVS Source Filter: AVISource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline64Resize
Video Resolution: 1
Video BitRate Min: 2500
Video BitRate Level 1: 6500
Video Profile Level 2: 4500
Video BitRate Max: 8500
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
DVD Audio Format: 0
DVD Audio BitRate: 192
Keep DVD Compliant Audio: 1
Normalize Audio: 0
DVD Audio Language: EN - English
DVD Subs Language: EN - English
Chapters Interval: 5
Use Source Chapters: 0
DVD Burning Drive: F: TSSTcorp DVD+-RW TS-L632D DE04
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Save Log file: 1
Unload ActiveMovie library: 0
Adjust ffdshow mixer: 1
TITLE 1 SOURCE FILES
Video: D:\Ond.avi
Info: XviD - 814 kbps - 624x336 - DAR 1,857 - 23,976 fps (CFR) - Progressive - 1:42:56 hours - 148089 frames
Audio 1: D:\Ond.avi
Info: MPEG-1 Audio layer 3 - 124 kbps - VBR - 2ch - 48000Hz - 1:42:56 hours - Internal
Subs:
[MediaInfoLib - v0.7.32]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("D:\Ond.avi", CacheFolder = "E:")
Audio = A2DAudioSource("D:\Ond.avi", CacheFolder = "E:")
#Using DGPulldown/HCenc to upsize FPS
Video = Video.AddBorders(0,7,0,7)
Video = Video.Lanczos4Resize(720,480)
Audio = Audio.EnsureVBRMP3Sync()
PROCESS ABORTED.
Log file created by AVStoDVD Release 2.3.0
Basically enocder wont even start anymore and i get this error message in log
Old 31st May 2010, 16:16   #1338  |  Link
trabanom
Hi there, I'm having problems with special characters in portuguese language using 2.3.0. For exemple: "", "" and so on had change to "?". I tryed to change language to PT but nothing happend.
I open SubtitleCreator and convert it manualy using defaut configuration and get the same result. After change "select character encode" in "formatting" menu to "Latin 1" it works perfect. How can I set AVstoDVd to work with Latin 1?
trabanom is offline   Reply With Quote
Old 1st June 2010, 21:04   #1339  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@whiskey
I would say to trace back your actions to understand what you did to make AVStoDVD unworkable... but I am sure you have already done it (have you? ).
Quick workaround could be to uninstall AVStoDVD, saying to remove registry entries, and then reinstall it.
A suggestion: before starting your project, use the 'Preview Clip' feat: if preview works, 99.9% the project will work too.
@trabanom
what AVStoDVD release are you using? If your subs are in srt UTF-8 format, latest release (2.3.0) correctly handles that format, preserving special chars. If you are already using 2.3.0 and/or your subs are not srt, then send me the subs file (avstodvd@gmail.com).
Bye
MrC
AVStoDVD Homepage
Old 2nd June 2010, 13:31   #1340  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@trabanom
your subs file is a ANSI format srt. Right now AVStoDVD does not handle special chars from ANSI files (next release will do). Simple workaround: open your srt files with Notepad and "save as" UTF-8 format. That's all.
Bye
MrC
AVStoDVD Homepage
[IMG] code is Off
