Old 28th July 2007, 20:05   #61  |  Link
microchip8
ffx264/ffhevc author
microchip8's Avatar
no problemo
Old 28th July 2007, 20:27   #62  |  Link
dansus
11 did the trick, good sync, crop working, nice quality and twice as fast as 8-10.
12 was fast too, quality ok, sync ok... crop bad. Black bars are back.
11 will work for me.
Thanks for your speedy responses and efforts.
ps mediainfo dies on 11 + 12.
dansus is offline   Reply With Quote
Old 28th July 2007, 21:58   #63  |  Link
buzzqw
HDConvertToX author
mediainfo failed even before... but i haven't added any message
try this update http://www.64k.it/andres/data/a/AutoMen13.exe
fixed: modified the new algo of cropping with dvr-ms
fixed: better mp4 muxing
tell me if crop problem are gone
BHH
HDConvertToX: your tool for BD backup
MultiX264: The quick gui for x264
AutoMen: The Mencoder GUI
AutoWebM: supporting WebM/VP8
buzzqw is offline   Reply With Quote
Old 28th July 2007, 23:04   #64  |  Link
dansus
The crop is fine with 13, but now its spitting out tiny files.
I tried with two sources, i set the output to 60mb and 250mb, I got a 10mb and 55mb file. I retested with 11 and that seems ok.
Strange.
Old 29th July 2007, 07:52   #65  |  Link
buzzqw
HDConvertToX author
i have encoded the long sample (77mb) to xvid with 2 pass (7' tick) aiming for 30MB and i got a 30.5MB final file
are you using what quality level and what profile ?
BHH
Old 29th July 2007, 09:07   #66  |  Link
Schrade
Schrade's Avatar
Originally Posted by buzzqw View Post
I'm getting a 404 on that...
Schrade is offline   Reply With Quote
Old 29th July 2007, 09:51   #67  |  Link
buzzqw
HDConvertToX author
thanks! fixed
retry the download
BHH
Old 30th July 2007, 00:22   #68  |  Link
killerhex
is there an option for hardcoding subs to the video
killerhex is offline   Reply With Quote
Old 30th July 2007, 01:37   #69  |  Link
dansus
BHH
Xvid, 7 or 8, cant remember for sure, Autocrop only.
It seems to be inconsistent, happens sometimes but not every time.
On a side thought, is it possible to make the size slider more sensitive, its really hard to get certain sizes ie it jumps from 29 to 59mb.
Be great to be able to manually type in the number.
thanks.
Old 30th July 2007, 02:00   #70  |  Link
glb
thanks.
Just click on the slider and then use your keyboard arrow keys.
glb is offline   Reply With Quote
Old 30th July 2007, 02:03   #71  |  Link
dansus
edit. fixed.
Old 30th July 2007, 02:04   #72  |  Link
dansus
Ahha !
Old 30th July 2007, 07:31   #73  |  Link
buzzqw
HDConvertToX author
update http://www.64k.it/andres/data/a/AutoMen14.exe
added possibility to specify Final Size
@killerhex
no.. i don't know (well haven't researched too much) how mencoder handle subs...
i am open to suggestions/hints/tips
@dansus
done... download the update 1.4
Keep forgetting to ask, the drop down box, is that to tell it what it is or what i want it to be?
from the drop list you must select if your movie is
none = progressive or no need to deinterlace
Progressive NTSC (29.97->23.976) = mencoder must convert to 23.976 from 29.97 (decimate)
Interlaced = and mencoder will deinterlace (i used this options on your sample)
Telecine= and mencoder will telecine it
Mixed progressive and telecine AND Mixed progressive and interlaced are hybrid preset for soft telecine and deinterlace
BHH
Old 30th July 2007, 10:09   #74  |  Link
microchip8
microchip8's Avatar
MEncoder by default hardcodes subs. You have to select the sub you want with the -sid option where this option is a number. You can also alternatively choose the anti-aliasing method with the -spuaa option
if you want to dump subs, then use mencoder with the -vobsubout option, eg
mencoder dvd://1 -sid 5 -vobsubout subtitle_file_name
you have to use -sid with -vobsubout when dumping subs to select which one to dump
BTW, I checked the mencoder docs again, you were right, the harddup filter should be placed at the beginning, sorry for mistake, so use....
-vf harddup,scale=512:384,blablabla
Old 30th July 2007, 12:51   #75  |  Link
buzzqw
HDConvertToX author
update 1.5 LINK on first post
fixed harddup
better bitrate handling
better use of denoise
better handling of unknow source
BHH
Old 30th July 2007, 19:50   #76  |  Link
dansus
BHH
Sweeet, thanks.
Old 6th August 2007, 00:36   #77  |  Link
gonwk
Hi buzzq,
Just FYI ...
I just saw your application and was playing around with it ... and I noticed the following using a short VOB test clip:
1) I think the "MPEG2" application on "AutoMen GUI" does not work. It encodes and it shows the file size getting larger but at the end of conversion ... the converted file size goes to "ZERO" !?!?!
2) The MP4 conversion ... works fine as far as Video and Audio decoding ... but when it is muxed up the final AVI ... the Audio does not play back. BTW, this conversion yielded the BEST Video ... however, I don't care for H.264 since currently is not playable on stand-alone dvd players.
3) The .WMV conversion yields an "Unrecognizable" output ... since Windows Media Player or VLC can not play it back and it gives me error.
4) I tried the XviD ... and it worked Good. It did gave a AVI output that it was playable and sound & video were fine. However, even with Quality set at 10 (Max) ... the output Video was so, so.
I did not try the other stuff.
Thanks,
G!
gonwk is offline   Reply With Quote
Old 6th August 2007, 02:03   #78  |  Link
dansus
mencoder keeps crashing with dvr-ms input now, was stable all week so i imagine its more to do with the source, but seems strange as im using the same cap card.
I converted it to mpeg2 and encoded to xvid but the output was unplayable and avi fixers would only produce a file that was 75% of the original length, so i guess it got corrupted around that point.
Old 6th August 2007, 07:18   #79  |  Link
buzzqw
HDConvertToX author
@gonwk
i hope you have used latest version
1)
here is working well. so.. tell me what quality you have used and audio bitrate. also, from dos box launch mpeg2.bat and look at any errors
2)
the final file is the MP4 , the AVI is the file made by mencoder!
3)
again... what quality preset ? and what audio ?
here the wmv is perfectly playable with mpc
4)
what bitrate ??? (look at xvid.bat)
@dansus
look here
...\My Videos\TV R
ecordings\Encoding\F1.2007.Round11.Hungary.Race.mpg
isn't a dvr-ms files! since its extension is .mpg i don't use the special "-demuxer 35" option!
rename to dvr-ms and retry!
BHH
Old 6th August 2007, 16:13   #80  |  Link
dansus
oops, sorry that was the wrong log.
automen, ffmpeg, handbrake, mencoder, x264
