#28061 | Link | |
![]() Join Date: Oct 2001
I'd prefer to stick with X265, but if I can't find a solution in the near future I may be forced to dump it. Too bad. It's really good software that just seems to be incapable of outputting a UHD-BD compliant stream. I would seem to me that they would make that a priority considering the number of UHD-BDs being produced out there. [Edit] I just looked at the pricing of NVidia cards in the GTX 1060/1070 category... the price is ridiculous, that ain't happening any time soon. I'd rather park the software without UHD support than pay that much and force my user base to do the same. Last edited by jdobbs; 15th November 2018 at 00:00. |
#28062 | Link | |
Not good quality though even with slower compression. No option to remove unwanted streams to save space for video quality. |
#28063 | Link | |
#28064 | Link |
Oh, just another thought...
![]() ![]() I REALLY would just like to be able to shoot some money over to some e'mail address so that you can get it when I happen to have it. Like, "Oh, I have an extra $20, I think that I'll just shoot it over to JD at 'IwishIhadaBiggerxxx@gmail.com'?", DONE! It would be SO much easier and I just about can guarantee that more people will send you money if they can do it that easily. For some odd reason, I just don't like the Amazon thing, IDK why... If there is honestly some good reason you can't do that, could you please tell me so that I will understand and stop bothering you...? Thanks! |
#28065 | Link | |
#28066 | Link | |
https://ecommerce-platforms.com/arti...l-alternatives |
#28067 | Link | |
#28068 | Link | ||
There are some deals on GTX1060 6gig cards, like BB has an EVGA GTX1060 SSC 6GB card for $280 (sale, regular price has ranged between $340-370 range). But GTX1060 3GB non-OC cards can be as low as $240 regularly. Its still a lot, if you are otherwise not in need of upgrading, or if these cards aren't as "fast" as your current card for "day to day" work. BUT you have to keep in mind, which you already alluded to... There is NVENC, QS and even an AMD variant if you decide to look at it... so woudln't BD-RB get more complex to manage? You'd have to build routines for each of the 3 variants, add a method for selecting the method, etc. No to mention debugging... having to be sure the user tells you if they are using NVENC, QS, AMD, or software when it fails... I mean sure you could pick one (that works with what hardware you already have) and add that first... and go from there, but still... Is that getting beyond the scope of BD-RB? Quote:
#28070 | Link | |
I'm still sporting a GTX 570 lol. I've been told a 1050 would be a fair upgrade for me. But I'm afraid it may not handle GTA V @ 4k well enough. I believe a 1070 ti would give me 2+ years of contentment. I've seen a few under $400. Strongly considering black friday purchases of a monitor, and GPU. I'm a tight wad... we'll see if something tempts me lol
#28071 | Link | |
Interestingly, you can output to an MKV and play it back on a UHD player that supports an MKV just fine (since an MKV file doesn't have to be UHD-BD compliant). So the issue is (apparently) just getting X265 to create a compliant stream. |
#28072 | Link | |
#28073 | Link | |
#28076 | Link |
Yes, that's why that function was created... but more recent versions of X264 made that feature less useful, as they use multiple processors much more effectively. Are you running lower than 90% processor utilization?
#28077 | Link | |
#28079 | Link | |
Still testing this function but seems to be more than fantastic using Ryzen Threadripper. Last edited by mparade; 17th November 2018 at 12:26. |
#28080 | Link |
There are a lot of hidden options to rerender video, to change video, but I don't see anything for changing BD menu(s) that have 4:3 set when 16:9 should be. I got a hold of a compilation BD, and the movies are fine in 16:9, if I play the .TS files (or convert them to MKV from BD-RB). MPC-HC plays them as should be. But through PDVD 12 and Player, naaaah. Every video "displays" as 4:3 until the menu. Which is 16:9. Pick a movie, and menu for it is displayed with an clip from the movie. In 4:3 with Subtitles On/Off, or back to menu...a cheap menu. Pick Play and the movie starts..in 4:3. For PDVD 12 I have to change "Keep Aspect Ratio" and select "Stretch to Fit Screen". Solved, but I'd like to not have to do that. Is there an option I haven't come across yet, or some other tool? I don't use TSMuxeR outside of BD-RB..so I'm not sure. I don't want to rerender the videos, so I suspect it's as "simple" as editing a DVD and changing a flag and saving back (DvdRemakePro) and is non-destructive to video. :-)
