#7341 | Link | |
Of course, it didn't work. One question titling my mind is, if BD-rebuilder is, like jdoobs said, check for it's modification to work befaire displaying is successfully setted up things, how come that same BD-Rebuilder re-asks me for setting it up the next time i run it like 5 seconds after ? As a programmer myself, i can only conclude that the test that he does after doing whatever is necessary to validate his changes is not the same as the test performed at the opening of BD-Rebuilder otherwise things would stick ? Anyone sees a failure in my analysis ? For Gerald, i know VC-1 is working with BD-RB and Windows 7 as i used to have it working before i was forced to upgrade GRRR ! My life was simple at that time lol ! Anyways, anybody (by any chance) have the path of the registry keys that need to be modified so i can try to do it by hand ? Or is it more than a matter of modifying some keys ? ![]() |
#7342 | Link | |
Yes i did your suggestion - it's a one minute try - re-downloaded from the top of this thread, unzipped, ran as admin - said everything was ok, went to proceed with VC1, failed, exited, re-ran it, and asking again for modifying the config... Now everybody trry to follow my thinking: If BD-RD validates its change after doing it, and it says that it was successfull, how come that same BD-RB says it is not configured next time i run it (like 5 seconds after that ?) JDoobs ? Can't be the same test you do at program execution than after modidying whatever has to be modified ? ![]() PS: I don't think the problem is with the direct show registry as Newer MP 12 uses media foundation class, not direct show anymore. So whatever the changes that may be done on the direct show side won't affect unless i re-route thing from mfc to direct show ? (Or am i completely lost ?) PS2: Sorry for the repetition - this Message board said it scrapped my message first time, it seems like it didn't afterall. Last edited by PhilippeB; 19th March 2010 at 22:19. |
#7343 | Link | |
![]() Join Date: Oct 2001
That's just my point. If BD-RB sees the change the first time, and then when run again it isn't there. There HAS to be something changing it back in the mean time... either that or we have to believe start believing in alien intervention. I'm not prepared to do that at this time. I hate to contradict your last post -- but the problem is very definitely the DirectShow registry. That's what is being inspected by BD-RB when it starts... if the correct entry isn't there for VC-1 in the preferred list -- then the wrong CODEC is attempting the decode. BD-RB is looking at it and seeing that (very definitely) the wrong codec is there. The media foundation class has nothing to do with BD-RB -- because it isn't being used, DirectShow is being accessed through the AVISYNTH filter. Last edited by jdobbs; 19th March 2010 at 23:05. |
#7346 | Link |
I noticed you're resizing to 720p. That error (in your circumstance) usually means there is a subtitle stream that just won't resize, deselect the substreams one at a time until you find out which one it is...
#7349 | Link | |
Ouuuu ! Alien intervention ! This is exactly what my problematic VC-1 title is about ! (4th kind). So now we found the bug LOL ! Seriously, can you provide, as i asked before, the registry paths i should be looking into (and what values they should be after BD-RB intervention ?) so at least i can start debugging something ? ![]() |
#7350 | Link |
Hello friends I am here to discuss that today assemble a new PC, with a DP55KG intel i7 860 processor, 2 sata samsung of 1 T, just after installing all the software, install the final BD-RB and gave me my chance the same mistake his friend PhiiipeB, I install everything correctly and set as it should be and also the BD-RB reconfigure.
Solution reinstall software W7 and noticing that was what hurt him, now operate normally, let alone a wonder encoding time. Sorry for my bad English. this is goggle translate |
#7351 | Link | |
@PhilippeB For your problem it appears that there are some keys that should be set but are not. In this registry area: HKLM\Software\Microsoft\Directshow\Preferred These keys: {31435657-0000-0010-8000-00AA00389B71} {31435641-0000-0010-8000-00AA00389B71} {e06d8026-db46-11cf-b4d1-00805f6cbbea} should all be set to {04FE9017-F873-410E-871E-AB91661A4EF7} That tells the system that the preferred DirectShow CODEC for VC-1, AVC, and MPEG-2 should be FFDSHOW. BD-RB looks at these keys when it loads on a Windows 7 system, and tells you when they are incorrect. It then gives you a prompt and attempts to set them correctly. It then looks at them, and if they weren't changed it knows it didn't have privilege to do so, and gives you another "you need to run me as administrator" message. When it successfully changes them, it also creates a batch file in the BD-RB folder that lets you change them back to their original state. Note that on Windows 7 64 bit systems the registry path (in REGEDIT) may be: HKLM\SOFTWARE\Wow6432Node\Microsoft\DirectShow\Preferred Last edited by jdobbs; 20th March 2010 at 17:00. |
#7352 | Link |
BluRay Maniac
Why not just use Win7DSFilterTweaker and set to ffdshow, because is recommended over manual tweaking registry.
#7353 | Link | |
#7354 | Link | |
Aging Video Hobbyist
I just checked my own 64-bit system and the Wow6432Node entries are all {04FE9017-F873-410E-871E-AB91661A4EF7} but the HKLM\Software\Microsoft\Directshow\Preferred are different. And when I run 0.32.08 (beta) there is no mention or complaint about my system at all. |
#7355 | Link | ||
#7356 | Link | |
I tried Win7DSFilterTweaker_1.9 and had put everything in there to ffdshow (under 32 bits tree). I Then started BD-RB and for the 1st time, it didn't complain about anything. So for BD-RB at that point everything was fine. EXCEPT, it will still fail at the CODEC but without complaining about VC-1 and MPEG not being attributed to FFDSHOW. Proof of what i am saying is here: ----------------------- [14:27:40] BD Rebuilder v0.32.08 (beta) - Source: THE_MUMMY - Input BD size: 29,42 GB - Approximate total content: [02:04:53.235] - Target BD size: 23,93 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [14:27:41] PHASE ONE, Encoding - [14:27:41] Reencoding: VID_00000 (1 of 1) - [14:27:41] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 179*658 frames - Bitrate: 19*550 Kbs - [14:27:41] Reencoding: VID_00000, Pass 1 of 2 - Encode failed. Retrying. <- No more VC-1 not configured for FFDSHOW - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3133) [14:27:43] - Failed video encode, aborted -------------------------------------------------- Ok, well, it's a start, that lead me to think JDoobs is looking under the 32-bit keys tree rather than the 64. But my machine is 64 bits. Back to Win7DSFilterTweaker_1.9, under the 64-bit tree, for all codecs, the only option available is MICRO$OFT. Humm.. Does that mean i need to install some set of 64 bits codecs ? Does BD-RB needs 64-bit codecs if my machine is 64 bits ? Or can it uses 32-bit (then how do i tell it to go for 32-bits instead of theses 64-bit that are microsoft only ? Should i install a 64-bit FFDSHOW (Does that exists ?) Then again, i heard JDoobs saying that AVISYNTH doesn't like 64-bit codecs.. Gee - everything was so simple under RC-1 (64 bits still) should never had gone legit with RTM =P I Will try to do a VDO at some point and post it to Youtube to show it to everybody. I seem to have fallen into a void somewhere. But my objective is to clarify this so next versions can address this problem in any situation (32, 64 or whatever the problem is). ![]() |
#7357 | Link | |
If you starting installing 64 bit codecs I can guarantee you will have additional failures. You obviously know more than I do. But do me a favor, if you post videos about how to do this -- please caviat it with "the developer of BD-RB doesn't agree with this". Because all it's going to do is cause me more headaches. Hope you find your problem. I give up. And by the way... my name isn't JDoobs, it's jdobbs. I would appreciate it if you at least got THAT right. Last edited by jdobbs; 20th March 2010 at 19:42. |
#7358 | Link | |
Thank you very much. I will look at this verry slowly tonight. It is okay for the warning, anybody should know it is a risky business playing directly in the registry and don't worry - i won't sue anybody if i screw up ![]() BTW i program under WinCE and have to create / modify / flush keys all the time so this is not a so different world for me. This is the last step i will attempt. If this doesn't work, i plan to whipeout my entire system and re-install it. This takes me about 2 days so maybe it worths it. Thanxs for the support. will come back soon with the results. PhilippeB PS: The alien intervention was a joke - the movie REALLY is about Aliens abductions - if anybody is into that, it is worth listening to ![]() Last edited by PhilippeB; 20th March 2010 at 19:41. |
#7359 | Link | |
#7360 | Link | |
Unfortunatly, everything seems to be ok. See the 3 snapshots of the 3 keys in the order you stated them (not the order they appear in regedit) in attachment. ![]() |
