#7361 | Link | |
![]() Join Date: Oct 2001
I can't tell from the image -- are those values in the "Wow6432Node" area or the other one? You may also want to try right-clicking on the streams and attempting to play them back. If the CODEC is set right you should be able to view them when MPC gets executed. I worry a little that you'd been editing the REGISTRY before -- not sure what impact that could have on this whole thing. Last edited by jdobbs; 20th March 2010 at 20:05. |
#7362 | Link |
I have a Sony BVD-E300 and use BD-RB as described in the top post of the bug thread, I have done STAR TREK and 2012 to Optical Quantum BD-25 and TDK DVD+R DL as BD/9 both run great. I did movie only english only sub strict AVCHD. About 20 hrs to do each. The only changes I have made is to check all in the Blu Ray audio. Love the Program and thanks for you hard work JDobbs!!
Win 7 Ultimate 64-bit AMD Phenom II X6 1090T 3.20GHz Gigabyte 890PA-UD3H 4 GB RAM Pioneer BD-RW BDR-205 Win 7 Ultimate 64-bit AMD Athlon 5050e 2.60 4 gig ram Pioneer BD-RW BDR-205 |
#7363 | Link | |
#7364 | Link | |
Meanwhile, if you understood my problem was fixed it is not - even with the keys correctly setted as posted, it is still not working... I posted a log just above that shows that and i am re-posting it here: ----------------------- [16:36:10] BD Rebuilder v0.32.08 (beta) - Source: THE_MUMMY - Input BD size: 29,42 GB - Approximate total content: [02:04:53.235] - Target BD size: 23,93 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 - Resuming from previously started job. [16:36:12] PHASE ONE, Encoding - [16:36:12] Reencoding: VID_00000 (1 of 1) - [16:36:12] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23,976fps, 179*658 frames - Bitrate: 19*550 Kbs - [16:36:12] Reencoding: VID_00000, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. <- Observe that there is no complain anymore about VC-1 or MPEG2 not being correctly setted up for FFDSHOW - FFDSHOW Revision: (3133) [16:36:13] - Failed video encode, aborted --------------------------------------------- BD-RB is probably doing its job but the codec seems to be innaccessible. Why can it BD-RB access AVC or H264, but not VC1 ? Answering that question would probably fix the problem. I'll probably have to re-install Windows 7 (again) ... Expecting things won't stop working at the first new program install. Maybe one solution would be to include the VC-1 codec somewhere in next BD-RB package (under 'Tools' folder like the other utilities) and if it doesn't infringe any copywright so it doesn't have to rely on so flakey / obscure registry things. My point: One cannot stop using his machine fearing that the next program he installs will comprmise what is already working. A computer generally runs more than one program everyone will agree. |
#7365 | Link |
@PhilippeB
I recommend that if you want it to work, you start from scratch and completely reinstall Win7. I have no way of knowing what has or has not been modified on your system. There are thousands of others using it on Win7/64 -- including me -- and it simply works as-is. There's obviously something different on your system -- but there's just no way I can put my finger on what it is long distance. As for including the VC-1 CODEC in the package... that's an extremely tall order, and considering the total of two BD-RB donations I've received in the last month (combined to add up to $27) -- and the fact that I've spend four times that much buying discs in the same period so that I can repeat reported issues -- it isn't likely that I'm going to go any route that adds additional programming time/expense. Frankly it's all I can do in my mind to justify continuing the project at all. Last edited by jdobbs; 20th March 2010 at 23:45. |
#7366 | Link |
Penguin Power
I had the same issue as PhilippeB
Manually using the Last Command in a Console, the x264 1st pass encode was just "quitting" almost immediately. I downloaded another x264 compile with the options BDRB uses from another site and it works fine. I am not certain if it is because I am running BDRB in VMWare XP, or because my CPU is old (A64 3000+) so certain compiler optimizations are unavailable, like SSE4. The debug info given by BDRB has always been enough to troubleshoot what is causing the problem. It has never been BDRB itself, but some of the helper programs distributed with it. |
#7367 | Link | |
I never had problems with previous versions of bdrebuilder. It may not be a fault of bd rebuilder itself, but one of the other applications it uses. Rob |
#7368 | Link | |
Rob |
#7369 | Link | |
What version of BD-RB are you using? If it isn't the latest, download v0.32.08 and try again. What you are describing was a known issue on an earlier version that was fixed. |
#7370 | Link |
I ran the bdrebuilder last command manually from a command prompt and it seems x264 is aborting with an error:
avs [info]: 1920x1080p 1:1 @ 24000/1001 fps (cfr) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2 SSE3 Cache64 x264 [error]: ratecontrol_init: can't open stats file x264 [error]: x264_encoder_open failed Could this be a sign that the first pass did not complete correctly? The file is there, but I suppose it may be damaged/truncuated. Rob Last edited by Rob_G; 21st March 2010 at 01:07. |
#7371 | Link |
I've got the same issue under Win 7 64bit also. BR-Rebuilder gives me no warning or messages about changing settings. Have tried as admin and re-installing codecs and avi synth.
[00:02:32] PHASE ONE, Encoding - [00:02:32] Extracting A/V streams [VID_00181] - [00:02:35] Reencoding: VID_00181 (1 of 46) - [00:02:35] Collecting video information - Source Video: VC-1, 1920x1080 - Rate/Length: 23.976fps, 3,485 frames - [00:02:36] Reencoding: VID_00181, Pass 1 of 1 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3322) [00:02:42] - Failed video encode, aborted |
#7372 | Link | |
#7373 | Link | |
Sorry if I sound rude, but this is about the 9000th time I've posted this exact same answer. It fixed 8998 of the previous issues. |
#7374 | Link | |
#7375 | Link | |
Rob |
#7376 | Link | |
About half the versions released since then have issues of one sort or another that make them stop working with BD-RB. I don't know why -- I just know that going back to that version fixes it. I tell people to stick with one that works or else its just a crapshoot. I'm testing 3326 now, and when I feel comfortable there are no issues I'll recommend it. Last edited by jdobbs; 21st March 2010 at 05:48. |
#7377 | Link |
I am having a little trouble with the fluidity of some scenes. T
I reencoded a Jamiroquai live concert. The original was extremely smooth when panning around the stage. When I watched the reencoded version it was slightly and jerky and blurry during the same panning scenes. The picture itself was fine with regards to sharpness - pretty much the same as the original - it was just during movement. It was a little similar to the old days with CCE when you encoded with the wrong field first, although not anywhere near as bad - I'm just trying to describe it a bit better. I noticed the same thing happening when I reencoded Monsters Inc, although this time it was during the scrolling on the menu. I thought that reencoding would not affect the picture in this way, only perhaps slight blockiness or grain. I tried the Jamiroquai concert full disc and movie only and got the same result - slight motion blur |
#7378 | Link | |
#7379 | Link |
Mr. JOBBY I tried this version fd 3326 everything seems ok perfect video and audio encoding 15:12:29] BD Rebuilder v0.32.08 (beta)
- Source: UNDERWORLD_EXT.CUT_[FULL_BLU-RAY_AVC_1080P_LPCM_5.1] - Input BD size: 36,25 GB - Approximate total content: [02:13:37.009] - Target BD size: 22,90 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [15:12:29] PHASE ONE, Encoding - [15:12:29] Extracting A/V streams [VID_00011] - [15:19:13] Reencoding: VID_00011 (1 of 1) - [15:19:13] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 192.216 frames - Bitrate: 17.021 Kbs - [15:19:13] Reencoding: VID_00011, Pass 1 of 2 - [17:04:20] Reencoding: VID_00011, Pass 2 of 2 - [23:35:06] Video Encode complete - [23:35:06] Reencoding audio tracks (if req'd) - [23:35:06] Multiplexing M2TS [23:43:50]PHASE ONE complete [23:43:50]PHASE TWO - Rebuild Started - [23:43:50] Rebuilding BD file Structure [23:57:31] - Encode and Rebuild complete [23:57:31] BURNING BD structure to disc - ImgBurn completed successfully - WORKFILES folder removed. [01:19:48]JOB: UNDERWORLD_EXT.CUT_[FULL_BLU-RAY_AVC_1080P_LPCM_5.1] finished. |
#7380 | Link |
Pass 1 completes, pass 2 fails to start still.
[22:35:44] BD Rebuilder v0.32.08 (beta) - Source: GOOD_LUCK_CHUCK - Input BD size: 27.53 GB - Approximate total content: [01:41:18.113] - Target BD size: 7.72 GB - Windows Version: 5.1 [2600] - MOVIE-ONLY mode enabled - Audio Settings: AC3=1 DTS=1 HD=0 Kbs=640 [22:35:47] PHASE ONE, Encoding - [22:35:47] Extracting A/V streams [VID_00000] - [22:49:31] Reencoding: VID_00000 (1 of 1) - [22:49:31] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 145,729 frames - Bitrate: 9,315 Kbs - [22:49:32] Reencoding: VID_00000, Pass 1 of 2 - [02:19:49] Reencoding: VID_00000, Pass 2 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. - FFDSHOW Revision: (3133) [02:19:56] - Failed video encode, aborted |
