#16125 | Link | |
Since I use BD RB 0.42.04, I have this problem : Quote:
Thanks ![]() |
#16128 | Link |
The programs didn't rip it, your drive did
#16129 | Link |
![]() Join Date: Oct 2001
The rebuild is using the original audio and video. Try the rebuild by hand (using the demuxed streams) and see what error TSMUXER is giving you. It looks like the stream may not have any video???
#16130 | Link |
I am trying to reencode Friends, but I have a problem with BD Rebuilder about the size it shows. I have not seen this before the file is over 35 GB big, but shows only 2.64 GB. Can I do something about that?
http://img72.imageshack.us/img72/198/problemms.jpg |
#16131 | Link | |
If you want a "full backup", you need to enable it so the entire disc will be displayed. ![]() |
#16132 | Link | |
![]() Last edited by hifreak; 28th November 2012 at 21:17. |
#16133 | Link | |
Also I can't play .264 with Windows Media Player and FFDShow coder :-/ Edit : When I demux with TSMuxer Gui, I have this message : "H.264 stream does not contain fps field. Muxing fps=24" Edit 2 : I have found the problem. In the meta file, I have this line : "V_MPEG4/ISO/AVC, "E:\RIPS\WORKFILES\00001.track_4113.264"+"E:\RIPS\WORKFILES\00000.track_4113.264", fps=24" and in the folder I have file "00000.track_4113.264" and "VID_00001.AVS.264" instead of "00001.track_4113.264". When I rename, it's OK to manual remux ![]() Is it a bug in BD Rebuilder ? Last edited by Nico8583; 29th November 2012 at 01:12. |
#16134 | Link |
@Nico8583;
You will need to provide more information to receive help... what does inspect show? The first file, VID_00001, is only 339 frames. The second file, VID_00000, is keeping the original file per the log, "Keeping original video (no reencode)". Have you ripped the Bluray to your hard drive? Running BD-RB with Anydvd and Bluray disc in Bluray drive? |
#16136 | Link | |
For Cosmopolis, I've ripped with AnyDVD HD. For Ice Age 3, I've ripped with DVDFab 8. For both, I don't let Bluray disc in Bluray drive. do you want a screenshot of Inspect ? With other movie like Fast & Furious 4 or Underworld 3, no problem... |
#16137 | Link | |
Yes, this appears to be a bug in BD Rebuilder. |
#16138 | Link | |
#16139 | Link |
Nobody else is reporting this issue. I'd suggest you uninstall BD-RB and all helper apps and then reinstall using only the links in the first post of this thread and following those instructions exactly.
Are you using any weird settings in the ripper? It is very odd that all these titles seem to be a combination of two (a short and a long) M2TS files. That just doesn't happen very often. It is even stranger that BD-RB isn't finding a playlist that matches it -- if it did then both files would be either reencoded or kept intact (not a mix). Can you run INSPECT.EXE and post the results? I'll look around for ICE AGE 3 and give it a run -- I don't remember if I did that one. Last edited by jdobbs; 30th November 2012 at 01:44. |
#16140 | Link |
@Nico8583
A reasonable amount of time has now passed that I feel comfortable in asking an obvious question: Is your source material a commercial Blu-ray disc, or "something else" that may have had an extra little file ("creator's file") added to the beginning? |
